hello i have a LCT3285TA tv(a 32 inch scott tv made by aki) i have been using it as my monitor on windows vista, but after i upgraded to 7 the tv will only work if i have a actual monitor hooked up to it, in the nvidia panel it shows up under the correct name however under device manager it only shows generic pnp monitor. i have a geforce 8800 gs with 2 dvi ports, and it both tv and video card pass dhcp tests, any ideas?
also the screen size is incorrect it is to big for the tv, i go to adjust that and it simply goes back to the incorrect size
