Windows 7 LEDedit 2012, Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
LmmO
Hey, sorry if this has been covered before :( But I'm really having trouble with running this program:
or
or
All of them is pretty much the same program... And I keep getting this error:
Normally I'm pretty tech-savy, and this is driving me nuts!! :D I've installed numberous netframe versions, and even tried a clean Windows install... I know that it works on a desktop machine with Windows 7 64bit... But it just wont work on my laptop!!
Could it be my CPU that doesn't support this application?? I'm on a i5-3317u.
Hi!
I've got this exact same error with the chinese led edit 2012 software, and because I couldn't find any solutions online, I post my solution here:
(I've installed a .net frameworks first without success.)
Open Internet Explorer (not Chrome, FF or else) and install the Adobe Flash player from it, from Adobe website. It worked for me, because this masterpiece software use some ActiveX components.
Good luck for the people came here by googleing this error!
Hi!
It sounds like it's a poorly written program.
