HarukiHanai
- Joined
- May 5, 2011
Hi there,
I know there are few Limited connectivity threads but ive checked them, non of them have the answer im looking for so ill just tell you the story.
I accidentily downloaded a malware/adware program called Antimalware Doctor, i tried going into safe mode and using multiple programs to delete it (Malware bytes, Spybot - Search and Destroy & AVG command line scanner) they apprently deleted it , i loaded my comp back to normal mode and there it was back in there corner
i managed to get rid of the program by bringing up task manager and removing the process called "sorttm700" (thats what the antimalware doctor program was called in the toolbar when i hovered over it) then going to my computer and searching for sorttm700, i deleted all the folders with sorttm700 in them and rebooted and no more annoying ads to buy fake software
however i still have limited connectivity (it became limited while the malware was on my computer and before i took any action to resolve it)
i am trying to use the same network as the computer i am using now ot send this message, i never get connection problems with my laptop using this connection
i have tried reseting my router and modem as well as uninstalling the driver and reinstalling and now there is a red cross with no options to connect to an access point, my wifi on my laptop is on before you ask
so can anyone solve this riddle for me? id be so happy if someone could
also my laptop is an acer aspire series if that can help in anyway
