cybercore
Product name: Danamics LMX
€280
built around Danamics' groundbreaking liquid metal technology featuring the unique electromagnetic pump which circulates the liquid metal in the LMX system without the use of moving parts. This noiseless propulsion is obtained by creating electromagnetic forces directly inside the liquid metal, causing it to move.
  • Heat sink material: Nickel Plated Aluminium
  • Tubing Material: Nickel Plated Copper
  • Housing Material: Plastic
  • RoHS Compliant: Yes
  • Sockets Supported: All AMD Processors For Socket AM2/AM2+/AM3. All Intel Processors For Socket 775/1156/1366.
  • Dimensions: (LXHXD) 158.2 X 170.5 X 90MM (Heat Sink Only).
  • Motherboard Clearance Height: 30MM
  • Weight: 1180G (Heat Sink Only).
  • Fan Compatibility: 120mm Fan
Fan.
  • Dimensions: (LXHXD) 120 X 120 X 25 MM
  • Speed: 2000 RPM
  • Airflow: 75.7 CFM
  • Noise Level, 1M xyz axes avg: 21.8 DBA
  • Noise Level, 1m z axis: 28.6 DBA
  • Operating Voltage: 6.0 - 14.0V
  • Current Draw: 0.30 A
  • Power Consumption: 3.60W
  • Bearings: FDB, Fluid Dynamic Bearings
Electromagnetic Pump.
  • Power Consumption: <1W
  • Magnet Type: Neodymium Block Magnet
  • Gauss Rating, 0.05m xyz axis: 12 Gauss (0.0012 Tesla)
(27 December 2009)
Danamics LMX Liquid Metal Cooler Review | Reviews - Clunk.org.uk
http://www.hexus.net/content/item.php?item=16157
The Danamics LMX is a liquid metal cooler known for its unique electromagnetic pump technology. Here is a detailed overview of the specifications provided: Product Overview:
  • Price: €280
  • Cooling Technology: Utilizes electromagnetic pump technology to circulate liquid metal without moving parts for noiseless operation.
Heat Sink Specifications:
  • Material: Nickel Plated Aluminium
  • Sockets Supported: All AMD Processors for Socket AM2/AM2+/AM3. All Intel Processors for Socket 775/1156/1366.
  • Dimensions: 158.2mm x 170.5mm x 90mm (Heat Sink Only)
  • Motherboard Clearance Height: 30mm
  • Weight: 1180g (Heat Sink Only)
Fan Specifications:
  • Dimensions: 120mm x 120mm x 25mm
  • Speed: 2000 RPM
  • Airflow: 75.7 CFM
  • Noise Level:
  • Average (xyz axes): 21.8 dBA
  • Z-axis: 28.6 dBA
    • Current Draw: 0.30A
    • Bearings: Fluid Dynamic Bearings (FDB)
    Electromagnetic Pump Specifications:
    • Power Consumption: B] Neodymium Block Magnet
    • Gauss Rating: 12 Gauss (0.0012 Tesla) at 0.05m xyz axis
    Additional Information: This cooler offers innovative technology with its liquid metal cooling system and noiseless operation due to the use of an electromagnetic pump. It is compatible with a range of processor sockets and provides detailed specifications for both the heat sink and fan components.
