Log on to PC using Pen Drive
Is there any software I can download so I can log into my computer using my usb flash drive?
C:\Users\Jack>bump
Bumpity bump
Trouble
Noob Whisperer
Sounds to me like you may be looking for a product similar to "Predator"
I am in no way endorsing or suggesting that you use this product, just attempting to provide a possible option.
I would strongly suggest that you take advanced steps including reading any and all documentation regarding the product as well as making sure that all your critical data is backed up and safe, complete with a current image of the whole computer before using any such product.
Hope this helps.
Randy
Hope this helps.
Randy
Thanks for your advice but I forgot to say that when I used Predator it wouldn't accept my usb key so I had to uninstall it
