Kylethedarkn
So I've never overclocked anything before, so I'm really looking for some detailed help in overclocking my Q6600, which is an Intel 2 Quad Core 2.4GHZ for those who don't know model numbers. Anyways I've been told that multiple cores are really only any good for 64 bit software and seeing as a lot of the software I use is 32 bit its runs on only one core and is fairly slow.
So I would like to get my CPU up to about 2.8-3.2Ghz. However, I am using the the Fan/Heatsink/Thermal Paste that came with the CPU in the box. I have a cooler master case, and I have checked the Core temps occasionally and they are usually running at avg temperatures or below so I think I have a little bit of wiggle room there.
I have tried looking at the bios settings for overclocking and there is an automatic overclocking option there, but I'm wary to apply it, because I know your supposed to raise things by tiny bits at a time. I also have no idea what the voltage/wattage settings mean.
Any help is greatly greatly appreciated.
