unfortunately i can't make this post to 1 problem specific...
heres the deal, i was on XP and i waited for 7, now using Home Premium and i like 7 very much
but some things are realy weird and buggy.
i use untouched (final version) installation, it was fresh after format, my pc is well capable for 7, my drivers are for 7,
i got no BSOD's and via NOD32 (was only one i could install to work normal) report is NO viruses + i use firewall (outpost)
no modification was made on ISO which was burned on 7x speed and installs OS inside 25 minutes.
problems:
1. System Restore, i cant even run it, every time i try i get this:
2. svchost has extreme CPU usage, if i kill it via task manager, system starts to act weird and i lose sound reproduction capability, if i run music player or watch movie in movie player, system is choked:
3. When CD/DVD is inserted and i get that splash screen of choices, and select to open folder to view contents,
every so little i get below folder in explorer added task that is on waiting "to burn desktop.ini" on disk
4. some programs (i came to 3 or 4 in last 2 days) after exit stay as process in task manager, they continue
to drain system resources, they cannot be killed via task manager or cmd taskkill, sysinternals pskill or process explorer,
some if ran again duplicate its process and also cannot be killed, logoff doesn't help, only solution is reboot
5. dont know if this is native so, but if i disable aero snap in control panel, i will lose aero shake too (which is stupid IMO)
problems:
