Windows 7 Many varied BSOD
unstable
System : - intel core i5 2500 @3.30
Mboard :- ASRock H61M/U3S3
Mem :- DDR3 2x2048 pc3-10700 (667 Mhz)
Graphics :- Nvidia Gforce GTX 560 Ti
Since getting my new computer i have had many different and varied blue screen crashes, I have since sent it back to the manufacturer who replace the memory and told me that it was working fine.
I received it back and set to work useing it, only to be confronted by what seemed to be driver issues, so i updated every single driver and now im getting more Blue screens.
Ive done all i can think off. Ive attached my last 8 or so.. Any ideas guys?
I can play high end games for hours at a time with no crashes, but then the computer can be in windows it elf for 5 mins and crash for no reason (i tried turning off all power saving settings, did no good)
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be found later
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here How to ask for help with a BSOD problem
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven't already, please take some time and fill out your system specs in your forum profile area http://windows7forums.com/windows-7...you-filling-your-system-specs.html#post235529 .
Good luck
Randy
View attachment system dump.zip
File attached this time with additional info requested.
Had attached just the dump files last time but the system crashed as it was uploading..so I font think it worked properly..
Let me know if you need anything else,
Thanks.
Top Bottom
