Media player and cpu usage
Discussion in 'Windows 7 Help and Support' started by knaveman, May 11, 2009.
  1. knaveman
    knaveman New Member
    May 9, 2009
    8
    0
    I just installed Windows 7 RC on my main computer. I use it to hold all my music and video files and serve them up to two Xbox360's and a laptop. Windows Media Player has been scanning and updating my library non-stop and eating up all my cpu. Wmpnetwk.exe is the culprit. It makes my computer slow and media streaming almost unusable. Computer is an HP Pavilion with AMD Athlon 64 X2 Dual Core Processor 4600+ 2.40GHz with 2 GB Ram. My music is stored on an external USB hard drive and my video on an internal 500GB hard drive.
    The only solutions I have come across so far are to disable the wmpnetwk service and prevent it from running, but from what I understand I need it to stream to my Xbox's. Does this have to do with the Library feature or is there some kind of bug? Any fixes?
  2. knaveman
    knaveman New Member
    May 9, 2009
    8
    0
    After some deep, deep googling I found that some people had problems with wmpnetwk.exe under vista. One post said that a "corrupt" .avi was causing prblems for him. I searched my fiels and found one .avi. Deleted it. Now all is well. Don't really know if that was the thing that fixed it or not.
  3. Radenight
    Radenight New Member
    Nov 16, 2008
    4,525
    108
    Did you try using a different media player? ;) VLC is an excellent choice, and it's free! :) I use it for all my video needs.. Winamp still holds the crown for all my music needs.. (Both work perfectly in Windows 7).. ;)
  4. knaveman
    knaveman New Member
    May 9, 2009
    8
    0
    Does VLC or WinAmp let me stream to my Xbox360?
  5. Radenight
    Nov 16, 2008
    4,525
    108
Share This Page
Loading...
