Windows 7 Memory management BSOD
usasma
Fantastic Member
SP1 isn't installed, please do the following:
Installing Windows 7 Service Pack 1
1. Visit the PC manufacturer's website and update ALL drivers. DO NOT use Windows Update or the "Update drivers" function of Device Manager.
2. Check Device Manager for any unknown/disabled devices - if there are unknown/disabled devices, fix them with the latest drivers from the device manufacturer's website (not the PC Manufacturer)
3. Visit Windows Update and get all updates (may take repeated visits)
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1: Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1 from the Microsoft Download Center
5. Visit Windows Update and get any other available updates. May take repeated visits, but keep it up until you get several "Windows is updated" results.
If you're having difficulties with installing a Service Pack, please use the SURTool from this link: What is the System Update Readiness Tool?
Also, check out this troubleshooting link from Microsoft: Troubleshoot problems installing Service Pack 1 (SP1) for Windows 7 and Windows Server 2008 R2
I have had limited success in installing updates/Service Packs when using a "clean boot". I suspect that I'm just bypassing the problem - and that it can come back to bite me in the butt later on.
HotSpot Shield has been known to cause BSOD's in some systems. Please un-install it immediately. We haven't seen as many problems with it recently, so feel free to try the latest version once the system has stopped BSODing.
Less than 10% free on your hard drive - Windows works best when each drive has at least 15% free space. Please free up that amount on your hard drive.
You have a D-Link DWA-125 Wireless N 150 USB Adapter(rev.A2)
I do not recommend using wireless USB network devices. Especially in Win7/Win8 systems.
These wireless USB devices have many issues with Win7(and I suspect with Win8) - using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7/Win8 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
Interestingly, the device isn't listed in the systeminfo.txt report - so it may be disabled. In any case, please un-install the software and then physically remove the device from your system.
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Win7 systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Global Provider of Innovative Graphics, Processors and Media Solutions | AMD (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: ATI video cards - DRIVER ONLY installation procedure
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
ManyCam has caused problems with Win7 systems in the past. On your system, you had problems with it back in March/April of 2012. Please un-install it to see if that stops the BSOD's.
lmimirr.sys Tue Apr 10 18:32:45 2007 (461C108D)
RemotelyAnywhere Mirror Miniport Driver or LogMeIn Mirror Miniport Driver
http://www.carrona.org/drivers/driver.php?id=lmimirr.sys
RaInfo.sys Fri Jan 4 13:57:14 2008 (477E818A)
LogMeIn/RemotelyAnywhere Kernel Information Provider
http://www.carrona.org/drivers/driver.php?id=RaInfo.sys
ManyCam_x64.sys Thu Mar 13 03:46:01 2008 (47D8DBB9)
ManyCam Virtual Webcam
http://www.carrona.org/drivers/driver.php?id=ManyCam_x64.sys
LMIRfsDriver.sys Mon Jul 14 12:26:56 2008 (487B7E50)
http://www.carrona.org/drivers/driver.php?id=LMIRfsDriver.sys
hamachi.sys Thu Feb 19 05:36:41 2009 (499D3639)
LogMeIn Hamachi Virtual network interface driver
http://www.carrona.org/drivers/driver.php?id=hamachi.sys
anodlwfx.sys Fri Mar 6 05:10:08 2009 (49B0F680)
ALPHA Networks Filter Driver
http://www.carrona.org/drivers/driver.php?id=anodlwfx.sys
sptd.sys Sun Oct 11 16:55:14 2009 (4AD24632)
SCSI Pass Through Direct Host - Daemon Tools (known BSOD issues with Win7)
http://www.carrona.org/drivers/driver.php?id=sptd.sys
AODDriver2.sys Thu Apr 5 05:23:37 2012 (4F7D6499)
AMD Overdrive; also in EasyTune6 for Gigabyte motherboard [br] Known BSOD issues in Win7
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
hssdrv6.sys Wed Nov 14 20:32:58 2012 (50A4464A)
Hotspot Shield Routing Driver [br] Possible BSOD cause seen in mid-2012
http://www.carrona.org/drivers/driver.php?id=hssdrv6.sys
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Mon Jan 28 20:06:46.804 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012913-36348-01.dmp]
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
[B][COLOR=RED]Missing Windows 7 Service Pack 1[/COLOR][/B]
Built by: [B]7600[/B].16385.amd64fre.win7_rtm.090713-1255
System Uptime:[B]1 days 11:35:50.116[/B]
Probably caused by :[B]memory_corruption ( nt!MiUnlinkPageFromLockedList+298 )[/B]
BugCheck [B]1A, {8886, fffffa8005a0fff0, fffffa8005d580e0, 700}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000001A"]MEMORY_MANAGEMENT (1a)[/URL]
Arguments:
Arg1: 0000000000008886, The subtype of the bugcheck.
Arg2: fffffa8005a0fff0
Arg3: fffffa8005d580e0
Arg4: 0000000000000700
BUGCHECK_STR:  0x1a_8886
PROCESS_NAME: [B]SndVol.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_8886_nt!MiUnlinkPageFromLockedList+298[/B]
  BIOS Version                  1005
  BIOS Release Date             08/24/2010
**************************Sun Jan 27 08:30:27.114 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012713-37393-01.dmp]
System Uptime:[B]3 days 14:00:46.814[/B]
Probably caused by :[B]memory_corruption ( nt!MiRelinkStandbyPage+115 )[/B]
BugCheck [B]1A, {8885, fffffa8006532020, fffffa8005a0fff0, 502}[/B]
Arguments:
Arg1: 0000000000008885, The subtype of the bugcheck.
Arg2: fffffa8006532020
Arg3: fffffa8005a0fff0
Arg4: 0000000000000502
BUGCHECK_STR:  0x1a_8885
PROCESS_NAME: [B]svchost.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_8885_nt!MiRelinkStandbyPage+115[/B]
  BIOS Version                  1005
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]lmimirr.sys                   Tue Apr 10 18:32:45 2007 (461C108D)[/B][/COLOR]
[COLOR=RED][B]RaInfo.sys                    Fri Jan  4 13:57:14 2008 (477E818A)[/B][/COLOR]
[COLOR=RED][B]LMIRfsDriver.sys              Mon Jul 14 12:26:56 2008 (487B7E50)[/B][/COLOR]
[COLOR=RED][B]hamachi.sys                   Thu Feb 19 05:36:41 2009 (499D3639)[/B][/COLOR]
[COLOR=RED][B]anodlwfx.sys                  Fri Mar  6 05:10:08 2009 (49B0F680)[/B][/COLOR]
GEARAspiWDM.sys               Mon May 18 08:17:04 2009 (4A1151C0)
[COLOR=RED][B]amdxata.sys                   Tue May 19 13:56:59 2009 (4A12F2EB)[/B][/COLOR]
[COLOR=RED][B]ajyhvx0f.SYS                  Tue Jul 14 17:12:55 2009 (4A5CF4D7)[/B][/COLOR]
[COLOR=RED][B]ASACPI.sys                    Wed Jul 15 23:31:29 2009 (4A5E9F11)[/B][/COLOR]
VMNET.SYS                     Mon Aug 10 08:04:50 2009 (4A800CE2)
vmnetadapter.sys              Mon Aug 10 08:04:53 2009 (4A800CE5)
vmnetbridge.sys               Mon Aug 10 08:05:58 2009 (4A800D26)
TuneUpUtilitiesDriver64.sys   Thu Sep 17 07:54:52 2009 (4AB2238C)
[COLOR=RED][B]sptd.sys                      Sun Oct 11 16:55:14 2009 (4AD24632)[/B][/COLOR]
amdiox64.sys                  Thu Feb 18 10:17:53 2010 (4B7D5A21)
npf.sys                       Fri Jun 25 12:50:58 2010 (4C24DE72)
vmci.sys                      Thu Nov 11 14:11:58 2010 (4CDC3FFE)
hcmon.sys                     Thu Nov 11 14:44:25 2010 (4CDC4799)
vmnetuserif.sys               Thu Nov 11 14:59:16 2010 (4CDC4B14)
VMkbd.sys                     Thu Nov 11 15:35:18 2010 (4CDC5386)
vmx86.sys                     Thu Nov 11 16:23:08 2010 (4CDC5EBC)
nlndis.sys                    Sun Feb 13 17:07:33 2011 (4D585625)
nltdi.sys                     Sun Feb 13 17:07:35 2011 (4D585627)
speedfan.sys                  Fri Mar 18 12:08:46 2011 (4D83838E)
RzSynapse.sys                 Wed Apr  6 05:29:13 2011 (4D9C3269)
Rt64win7.sys                  Wed Nov 23 10:00:40 2011 (4ECD0A98)
HWiNFO64A.SYS                 Tue Feb  7 08:08:34 2012 (4F312252)
MpFilter.sys                  Fri Mar  9 06:05:26 2012 (4F59E3F6)
mbam.sys                      Tue Mar 20 12:04:48 2012 (4F68AAA0)
[COLOR=RED][B]AODDriver2.sys                Thu Apr  5 05:23:37 2012 (4F7D6499)[/B][/COLOR]
idmwfp.sys                    Mon Apr 23 09:14:15 2012 (4F9555A7)
[COLOR=RED][B]nusb3hub.sys                  Thu May 10 03:33:53 2012 (4FAB6F61)[/B][/COLOR]
[COLOR=RED][B]nusb3xhc.sys                  Thu May 10 03:33:55 2012 (4FAB6F63)[/B][/COLOR]
AtihdW76.sys                  Fri May 11 04:25:40 2012 (4FACCD04)
AtiPcie64.sys                 Tue Jun 12 22:33:31 2012 (4FD7FBFB)
usbfilter.sys                 Tue Jul  3 05:00:02 2012 (4FF2B492)
viahduaa.sys                  Mon Aug 13 06:16:00 2012 (5028D3E0)
atikmpag.sys                  Wed Aug 15 21:13:06 2012 (502C4922)
atikmdag.sys                  Wed Aug 15 21:50:37 2012 (502C51ED)
avgrkx64.sys                  Thu Sep 13 20:41:40 2012 (50527D44)
avgloga.sys                   Thu Sep 20 21:23:51 2012 (505BC1A7)
avgtdia.sys                   Thu Sep 20 21:25:33 2012 (505BC20D)
avgldx64.sys                  Mon Oct  1 21:05:50 2012 (506A3DEE)
avgidsha.sys                  Sun Oct 14 21:22:54 2012 (507B656E)
avgidsdrivera.sys             Mon Oct 22 06:47:11 2012 (5085242F)
[COLOR=RED][B]hssdrv6.sys                   Wed Nov 14 20:32:58 2012 (50A4464A)[/B][/COLOR]
taphss6.sys                   Wed Nov 14 20:38:02 2012 (50A4477A)
avgmfx64.sys                  Thu Nov 15 17:03:50 2012 (50A566C6)
[COLOR=RED][B]aijvett7.SYS                  Tue Jul 14 17:12:55 2009 (4A5CF4D7)[/B][/COLOR]
spbm.sys                      Sun Oct 11 16:55:14 2009 (4AD24632)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
ajyhvx0f.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
http://www.carrona.org/drivers/driver.php?id=VMNET.SYS
http://www.carrona.org/drivers/driver.php?id=vmnetadapter.sys
http://www.carrona.org/drivers/driver.php?id=vmnetbridge.sys
http://www.carrona.org/drivers/driver.php?id=TuneUpUtilitiesDriver64.sys
http://www.carrona.org/drivers/driver.php?id=amdiox64.sys
http://www.carrona.org/drivers/driver.php?id=npf.sys
http://www.carrona.org/drivers/driver.php?id=vmci.sys
http://www.carrona.org/drivers/driver.php?id=hcmon.sys
http://www.carrona.org/drivers/driver.php?id=vmnetuserif.sys
http://www.carrona.org/drivers/driver.php?id=VMkbd.sys
http://www.carrona.org/drivers/driver.php?id=vmx86.sys
http://www.carrona.org/drivers/driver.php?id=nlndis.sys
http://www.carrona.org/drivers/driver.php?id=nltdi.sys
http://www.carrona.org/drivers/driver.php?id=speedfan.sys
http://www.carrona.org/drivers/driver.php?id=RzSynapse.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=HWiNFO64A.SYS
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=mbam.sys
http://www.carrona.org/drivers/driver.php?id=idmwfp.sys
http://www.carrona.org/drivers/driver.php?id=nusb3hub.sys
http://www.carrona.org/drivers/driver.php?id=nusb3xhc.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW76.sys
http://www.carrona.org/drivers/driver.php?id=AtiPcie64.sys
http://www.carrona.org/drivers/driver.php?id=usbfilter.sys
http://www.carrona.org/drivers/driver.php?id=viahduaa.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=avgrkx64.sys
http://www.carrona.org/drivers/driver.php?id=avgloga.sys
http://www.carrona.org/drivers/driver.php?id=avgtdia.sys
http://www.carrona.org/drivers/driver.php?id=avgldx64.sys
http://www.carrona.org/drivers/driver.php?id=avgidsha.sys
http://www.carrona.org/drivers/driver.php?id=avgidsdrivera.sys
http://www.carrona.org/drivers/driver.php?id=taphss6.sys
http://www.carrona.org/drivers/driver.php?id=avgmfx64.sys
aijvett7.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
spbm.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
Top Bottom
