Windows 7 Memory Managemnt BSODs
NidoKing
My girlfriend's computer has been having BSODs for a while now, giving the MEMORY_MANAGEMENT error. I've run Memtest86+ overnight with no errors, so now I'm hoping for any help or ideas.
It doesn't happen TOO frequently or with any pattern, as far as I or my girlfriend can tell it has been pretty random... although it does seem like perhaps one BSOD leads to another in somewhat quick succession, and then longer breaks with no problems.
I've read the stickies and will try to include everything that was mentioned as attachments (CPU-Z screenshots of Memory and SPD, RaMMon SPD info, and the dumps and system info)
*Both RAM sticks are DDR3 1333, recommended timings are 8-8-8-24 and 1.5V. The current timings are at 9-9-9-24 because I recently reset her BIOS to defaults and thats what the motherboard chooses, but previously I had the timings set to 8-8-8-24 and it did not help with the blue screens
*You can ignore the BSOD dumps from 3/4/2011, as those were due to an unrelated problem (I was doing some overclock testing on 3/4, but the computer is not currently overclocked, BIOS is at recommended defaults). The rest of the dumps I believe are the consistent MEMORY_MANAGEMENT error that she gets.
Thank you sincerely in advance for any advice, analysis, ideas, or suggestions!
  • Seven Forums BSOD.rar
  • RAMMon - SPD Info.txt
See if your motherboard is qualified for this RAM:
Link Removed - Invalid URL
Set it 1333Mhz 8-8-8-24 1.5 Volts.
Update drivers:
JMicron RAID driver
jraid.sys Fri Jul 17 11:31:50 2009
Reclusa Keyboard
RecFltr.sys Wed Jan 17 20:23:09 2007
Realtek LAN
Rt64win7.sys Fri May 22 10:52:30 2009
Realtek
Logitech SetPoint
LMouFilt.Sys Wed Jun 17 12:49:43 2009
PowerISO
SCDEmu.SYS Sun Nov 08 22:27:29 2009
VIA Audio
viahduaa.sys Thu Jul 09 23:07:01 2009
Elaborate Bytes Virtual Clone
VClone.sys Sun Aug 09 17:25:45 2009
If crashes re-occur after you update everything and set RAM according to its rates, uninstall Daemon Tools:
sptd.sys Tue Aug 24 02:13:12 2010
DuplexSecure - FAQ
CRASH DUMPS
Loading Dump File [F:\DMP\032611-19156-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e1e000 PsLoadedModuleList = 0xfffff800`0305be50
Debug session time: Sat Mar 26 17:44:33.531 2011 (UTC - 4:00)
System Uptime: 0 days 0:35:30.076
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1A, {41284, 7318001, 25e3, fffff70001080000}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+4a83 )
Followup: MachineOwner
0: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041284, A PTE or the working set list is corrupt.
Arg2: 0000000007318001
Arg3: 00000000000025e3
Arg4: fffff70001080000
Debugging Details:
BUGCHECK_STR:  0x1a_41284
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  chrome.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002ee33b3 to fffff80002e8e740
STACK_TEXT:
fffff880`07d0e218 fffff800`02ee33b3 : 00000000`0000001a 00000000`00041284 00000000`07318001 00000000`000025e3 : nt!KeBugCheckEx
fffff880`07d0e220 fffff800`02ec1379 : fffffa80`0436c9c8 ffffffff`ffffffff fffffa80`043e6660 ffffffff`ffffffff : nt! ?? ::FNODOBFM::`string'+0x4a83
fffff880`07d0e260 fffff800`02ed4b2b : de300000`2150e867 fffff680`000398c0 ffffffff`ffffffff 000fffff`ffffffff : nt!MiTerminateWsle+0x29
fffff880`07d0e2a0 fffff800`02ecfdee : 00000000`00000002 fffff880`00000000 fffffa80`0436c630 fffffa80`0436c9c8 : nt!MiDecommitPages+0x20b
fffff880`07d0eb30 fffff800`02e8d993 : ffffffff`ffffffff 00000000`03fde320 00000000`03fde318 fffffa80`00000001 : nt!NtFreeVirtualMemory+0x2de
fffff880`07d0ec20 00000000`7710ff3a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`03fde2e8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7710ff3a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02ee33b3 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+4a83
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
FAILURE_BUCKET_ID:  X64_0x1a_41284_nt!_??_::FNODOBFM::_string_+4a83
Loading Dump File [F:\DMP\032611-20014-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02e1c000 PsLoadedModuleList = 0xfffff800`03059e50
Debug session time: Sat Mar 26 18:26:46.491 2011 (UTC - 4:00)
System Uptime: 0 days 0:23:44.036
BugCheck 1A, {41790, fffffa80009bd4e0, ffff, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+33906 )
3: kd> !analyze -v
Arguments:
Arg1: 0000000000041790, The subtype of the bugcheck.
Arg2: fffffa80009bd4e0
Arg3: 000000000000ffff
Arg4: 0000000000000000
Debugging Details:
BUGCHECK_STR:  0x1a_41790
PROCESS_NAME:  dllhost.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002efff9e to fffff80002e8c740
STACK_TEXT:
fffff880`08425828 fffff800`02efff9e : 00000000`0000001a 00000000`00041790 fffffa80`009bd4e0 00000000`0000ffff : nt!KeBugCheckEx
fffff880`08425830 fffff800`02ebfdf9 : 00000000`00000000 000007fe`ffad5fff fffffa80`00000000 fffffa80`00000000 : nt! ?? ::FNODOBFM::`string'+0x33906
fffff880`084259f0 fffff800`031a51d0 : fffffa80`063c4690 0007ffff`00000000 00000000`00000000 00000000`00000000 : nt!MiRemoveMappedView+0xd9
fffff880`08425b10 fffff800`031a55db : fffff880`00000000 000007fe`fed50000 fffffa80`00000001 fffffa80`04d64bf0 : nt!MiUnmapViewOfSection+0x1b0
fffff880`08425bd0 fffff800`02e8b993 : fffffa80`04554b60 fffff880`08425ca0 fffffa80`043d2620 000007fe`fdcc0000 : nt!NtUnmapViewOfSection+0x5f
fffff880`08425c20 00000000`7781fffa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0218f678 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7781fffa
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02efff9e cc              int     3
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+33906
MODULE_NAME: nt
FAILURE_BUCKET_ID:  X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+33906
DRIVERS
fffff880`04144000 fffff880`04182000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`050fd000 fffff880`05142000   a3ldtke4 a3ldtke4.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`01195000 fffff880`011ec000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cfa000 fffff880`02d84000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0515b000 fffff880`05171000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00c1e000 fffff880`00c29000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`04182000 fffff880`0418a000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`00ff6000 fffff880`00fff000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dd5000 fffff880`00dff000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`05681000 fffff880`056a4000   AtiHdmi  AtiHdmi.sys  Thu May 06 05:20:39 2010 (4BE289E7)
fffff880`0486a000 fffff880`04f46000   atikmdag atikmdag.sys Thu May 27 12:47:58 2010 (4BFEA23E)
fffff880`040fe000 fffff880`04144000   atikmpag atikmpag.sys Thu May 27 12:25:36 2010 (4BFE9D00)
fffff880`04196000 fffff880`041da000   aurfqbzj aurfqbzj.SYS Sat Jul 17 06:58:04 2010 (4C418CBC)
fffff880`02c4e000 fffff880`02c55000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03aa1000 fffff880`03ab2000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`073e2000 fffff880`07400000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00720000 fffff960`00747000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`06400000 fffff880`0641d000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`02c1b000 fffff880`02c45000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00efc000 fffff880`00fbc000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01200000 fffff880`01230000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d01000 fffff880`00d5f000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01555000 fffff880`015c8000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`0514b000 fffff880`0515b000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`07293000 fffff880`0729b000   cpuz132_x64 cpuz132_x64.sys Thu Mar 26 19:17:23 2009 (49CC0D03)
fffff880`057f0000 fffff880`057f9000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`0641d000 fffff880`0642b000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03a00000 fffff880`03a83000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03a83000 fffff880`03aa1000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03b7c000 fffff880`03b8b000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`015e3000 fffff880`015f9000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`056e1000 fffff880`05703000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06437000 fffff880`06440000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0642b000 fffff880`06437000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06440000 fffff880`06453000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06453000 fffff880`0645f000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04000000 fffff880`040f4000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04f46000 fffff880`04f8c000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`03b71000 fffff880`03b7c000   ElbyCDIO ElbyCDIO.sys Thu Dec 17 17:25:16 2009 (4B2AAFCC)
fffff880`00c75000 fffff880`00c89000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00c29000 fffff880`00c75000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`015d9000 fffff880`015e3000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0148f000 fffff880`014c9000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01600000 fffff880`0164a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`033f8000 fffff800`03441000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04f8c000 fffff880`04fb0000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0575d000 fffff880`05776000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`05776000 fffff880`0577e080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0574f000 fffff880`0575d000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0731a000 fffff880`073e2000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01486000 fffff880`0148f000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03bb1000 fffff880`03bc7000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00c00000 fffff880`00c1e000   jraid    jraid.sys    Fri Jul 17 11:31:50 2009 (4A609966)
fffff880`05046000 fffff880`05055000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`057bf000 fffff880`057cd000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba9000 fffff800`00bb3000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`05075000 fffff880`050b8000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`0153b000 fffff880`01555000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`017d0000 fffff880`017fb000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05703000 fffff880`05708200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0577f000 fffff880`05792000   LHidFilt LHidFilt.Sys Wed Jun 17 12:49:39 2009 (4A391EA3)
fffff880`051eb000 fffff880`05200000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0579f000 fffff880`057b3000   LMouFilt LMouFilt.Sys Wed Jun 17 12:49:43 2009 (4A391EA7)
fffff880`057cd000 fffff880`057f0000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`07ec4000 fffff880`07ece000   mbam     mbam.sys     Thu Feb 11 20:57:26 2010 (4B74B586)
fffff880`00ca9000 fffff880`00ced000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`05741000 fffff880`0574f000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`05055000 fffff880`05064000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05792000 fffff880`0579f000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00dbb000 fffff880`00dd5000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`07200000 fffff880`07218000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`07218000 fffff880`07245000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`07245000 fffff880`07293000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`041da000 fffff880`041fd000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02cb3000 fffff880`02cbe000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`011ec000 fffff880`011f6000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`014dd000 fffff880`0153b000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03b66000 fffff880`03b71000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01669000 fffff880`0167b000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0167e000 fffff880`01770000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`05195000 fffff880`051a1000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`072ef000 fffff880`07302000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`051a1000 fffff880`051d0000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0566c000 fffff880`05681000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02c0b000 fffff880`02c1a000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d84000 fffff880`02dc9000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01770000 fffff880`017d0000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02cbe000 fffff880`02ccf000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03b5a000 fffff880`03b66000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e1c000 fffff800`033f8000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01249000 fffff880`013ec000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02c45000 fffff880`02c4e000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0729c000 fffff880`072ef000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02dd2000 fffff880`02df8000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fbc000 fffff880`00fd1000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00ec0000 fffff880`00ef3000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`011f6000 fffff880`011fd000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fe6000 fffff880`00ff6000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`015c8000 fffff880`015d9000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07a9a000 fffff880`07b40000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`056a4000 fffff880`056e1000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ced000 fffff880`00d01000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`05171000 fffff880`05195000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`051d0000 fffff880`051eb000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`05000000 fffff880`05021000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`05021000 fffff880`0503b000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03b09000 fffff880`03b5a000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0503b000 fffff880`05046000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02c98000 fffff880`02ca1000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02ca1000 fffff880`02caa000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02caa000 fffff880`02cb3000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0144c000 fffff880`01486000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`057b3000 fffff880`057be180   RecFltr  RecFltr.sys  Wed Jan 17 20:23:09 2007 (45AECBFD)
fffff880`07302000 fffff880`0731a000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04fc1000 fffff880`04ffa000   Rt64win7 Rt64win7.sys Fri May 22 10:52:30 2009 (4A16BC2E)
fffff880`03aef000 fffff880`03b09000   SCDEmu   SCDEmu.SYS   Sun Nov 08 22:27:29 2009 (4AF78C21)
fffff880`01166000 fffff880`01195000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`07b40000 fffff880`07b4b000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0418a000 fffff880`04196000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`00c89000 fffff880`00ca6000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01662000 fffff880`01669000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`0165a000 fffff880`01662000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01000000 fffff880`0115d000   sptd     sptd.sys     Tue Aug 24 02:13:12 2010 (4C7362F8)
fffff880`07e2e000 fffff880`07ec4000   srv      srv.sys      Mon Jun 21 23:21:11 2010 (4C202C27)
fffff880`07a00000 fffff880`07a68000   srv2     srv2.sys     Mon Jun 21 23:20:47 2010 (4C202C0F)
fffff880`07bbc000 fffff880`07be9000   srvnet   srvnet.sys   Mon Jun 21 23:20:32 2010 (4C202C00)
fffff880`05073000 fffff880`05074480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01803000 fffff880`01a00000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`07be9000 fffff880`07bfb000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02ced000 fffff880`02cfa000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02ccf000 fffff880`02ced000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03adb000 fffff880`03aef000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00540000 fffff960`0054a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03b8b000 fffff880`03bb1000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`050b8000 fffff880`050ca000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`05726000 fffff880`05740c00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`05709000 fffff880`05726000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0645f000 fffff880`06460f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04fb0000 fffff880`04fc1000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`05612000 fffff880`0566c000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04800000 fffff880`04856000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04856000 fffff880`04863000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`05064000 fffff880`05073000   VClone   VClone.sys   Sun Aug 09 17:25:45 2009 (4A7F3ED9)
fffff880`00eb3000 fffff880`00ec0000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02c55000 fffff880`02c63000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`06469000 fffff880`065fd000   viahduaa viahduaa.sys Thu Jul 09 23:07:01 2009 (4A56B055)
fffff880`02c63000 fffff880`02c88000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0164a000 fffff880`0165a000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00fd1000 fffff880`00fe6000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d5f000 fffff880`00dbb000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01400000 fffff880`0144c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03ac0000 fffff880`03adb000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02c88000 fffff880`02c98000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e00000 fffff880`00ea4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ea4000 fffff880`00eb3000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02dc9000 fffff880`02dd2000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003f0000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`05142000 fffff880`0514b000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0115d000 fffff880`01166000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`050ca000 fffff880`050eb000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`07b4b000 fffff880`07bbc000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`014c9000 fffff880`014d7000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01230000 fffff880`0123c000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0123c000 fffff880`01245000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`013ec000 fffff880`013ff000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`02c00000 fffff880`02c0b000   SymIMv.sys
    Checksum:  00000000
    ImageSize:  0000B000
