hi i recently built me a new computer installed everything SaberTooth 990fx R2.0 mobo and 32gb of corsair memory windows 7 64bit everything was working fine till i decided to bios update then after successfully doing soo my computer would not load windows it would say the boot drive is inaccessible and press enter to continue so i did and it said repair windows or start normally either option i chose would just send it back to square one and it was in an endless loop after several failed attempts at getting my usb flash with windows to work on it i turned my computer on and got a black screen of death my computer would turn on but just a black screen so i managed to get it into to bios with direct key on the board and i went to website and downloaded the orignal drivers that were on the mobo before the update put on flash drive and flashed it back with success now when i try to put 32gb of memory into my computer windows crashes goes on an endless loading windows files loop startup repair but if i take out one stick of memory windows will load and ill have no problems so i am currently running my system with 24gb of memory cause if i add a 4th stick my computer will only work for bios and windows wont load any ideas? thanks
