Windows 7 Memory_Management BSOD and random hang ups
Hipposly
I have an Acer X1700 PC 4gb Ram Intel Pentium Dual CPU E222o @2.40ghz
I've been experiencing BSODs and hang ups. I just swapped out the video card thought that was the problem
But i guess not. I installed the Radeon HD 5450 I've attached a copy of the dmp file Thanks fpr looking
A Hardware fault is the cause, seems to be defective RAM
Test your RAM RAM - Test with Memtest86+ - Windows 7 Forums
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of...
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 82e4bc23, The address that the exception occurred at
Arg3: 807866dc, Trap Frame
Arg4: 00000000
Debugging Details:
FAULTING_IP:
nt!CmpDelayDerefKeyControlBlock+53
82e4bc23 01803dd68cd4    add     dword ptr [eax-2B7329C3h],eax
TRAP_FRAME:  807866dc -- (.trap 0xffffffff807866dc)
ErrCode = 00000002
eax=82d79080 ebx=82d79080 ecx=00000048 edx=00000000 esi=8be5eb48 edi=853c9d48
eip=82e4bc23 esp=80786750 ebp=80786758 iopl=0         ov up ei ng nz ac pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00210a96
nt!CmpDelayDerefKeyControlBlock+0x53:
82e4bc23 01803dd68cd4    add     dword ptr [eax-2B7329C3h],eax ds:0023:576466bd=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x8E
PROCESS_NAME:  System
CURRENT_IRQL:  0
MISALIGNED_IP:
LAST_CONTROL_TRANSFER:  from 82e6f8c7 to 82e4bc23
STACK_TEXT:
80786758 82e6f8c7 853f7448 8ce04750 00000000 nt!CmpDelayDerefKeyControlBlock+0x53
807867ac 82e33a98 8ce04768 8ce04768 8ce04750 nt!CmpDeleteKeyObject+0x3db
807867c4 82c7b080 00000000 853c9d48 8ce04750 nt!ObpRemoveObjectRoutine+0x59
807867d8 82c7aff0 8ce04768 82e57c5c 8be01cb0 nt!ObfDereferenceObjectWithTag+0x88
807867e0 82e57c5c 8be01cb0 853c9d48 0000006c nt!ObfDereferenceObject+0xd
80786824 82e59442 8be01cb0 8be030d8 853c9020 nt!ObpCloseHandleTableEntry+0x21d
80786854 82e595ba 853c9020 00000000 807868f8 nt!ObpCloseHandle+0x7f
80786870 82c5541a 8000006c 8078693c 82c52d6d nt!NtClose+0x4e
80786870 82c52d6d 8000006c 8078693c 82c52d6d nt!KiFastCallEntry+0x12a
807868ec 82db6765 8000006c 80786b28 00000000 nt!ZwClose+0x11
8078693c 82db63f2 80786b28 80000128 00000001 nt!PnpIsAnyDeviceInstanceEnabled+0xaf
807869b4 82db53c8 80000128 00000000 80786aec nt!PnpPrepareDriverLoading+0x61
80786b9c 82fc383b 00000001 00000000 80786bd4 nt!IopLoadDriver+0x478
80786be8 82fbf863 8080f918 8080a598 00000000 nt!IopInitializeSystemDrivers+0x163
80786c6c 82fc4e60 0080a598 853c90b8 853c9d48 nt!IoInitSystem+0x6de
80786d48 82d9d48e 80786d90 82e209df 8080a598 nt!Phase1InitializationDiscard+0xced
80786d50 82e209df 8080a598 acad3261 00000000 nt!Phase1Initialization+0xd
80786d90 82cd2219 82d9d481 8080a598 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!CmpDelayDerefKeyControlBlock+53
FOLLOWUP_NAME:  MachineOwner
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: hardware
FAILURE_BUCKET_ID:  IP_MISALIGNED
Followup: MachineOwner
Thank you for your help
One of the Memory ports went bad making the system fail
