Hi Katarina and Welcome to The Forum.
Your latest dump file lists
Memory_Corruption as the probable cause which usually indicates out of date Drivers, incorrectly configured Memory Timings, mismatched Memory
or Bad Memory.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Random stop codes can often indicate hardware issues.
The bible site of drivers is currently down so these are a few that I'm aware of.
As a Priority:
dtsoftbus01.sys Fri Jun 17 08:38:37 2011 The dtsoftbus01.sys driver has been known to cause problems on some Windows 7 systems. This belongs to Daemon Tools Light. I suggest uninstalling DT Light until your blue screens are resolved.
But do not replace with Daemon Tools!!
Norton is known to be a cause of BSOD's on many Windows 7 systems. I suggest that you uninstall Norton using the
Link Removed in Safe Mode. Download Blue Screen friendly
Link Removed due to 404 Error as its replacement. Make sure Windows firewall is enabled!
Make sure your system is fully updated including SP1.
Download and install the correct system readiness tool
prior to installing SP1.
Drivers that pre-date Windows 7. Update:
rimspe64.sys Thu Jul 02 00:54:49 2009
risdpe64.sys Wed Jul 01 10:31:57 2009
rixdpe64.sys Sat Jul 04 11:27:00 2009
Ricoh Memory Card Reader. Check with your
PC or Motherboard Mfr.
Drivers with Updates:
atikmdag.sys Wed Jun 02 02:37:54 2010
atikmpag.sys Wed Jun 02 02:42:47 2010
Rt64win7.sys Tue Jan 12 06:37:27 2010
Link Removed If you're unsure about manually installing drivers then choose the
Win7 and WinServer 2008 R2 Auto Installation Program (SID:1483XXX) option to download.
Bugcheck Analysis:
* Bugcheck Analysis *
BugCheck 4E, {99, ba41b, 2, 21c85e}
Probably caused by : memory_corruption ( nt!MiBadShareCount+4c )
Followup: MachineOwner
Drivers:
fffff880`08200000 fffff880`0823e000 1394ohci 1394ohci.sys Thu Oct 15 04:35:12 2009 (4AD69870)
fffff880`07b77000 fffff880`07b83000 Acceler Acceler.sys Fri Jun 26 21:56:34 2009 (4A453602)
fffff880`00f40000 fffff880`00f97000 ACPI ACPI.sys Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`04845000 fffff880`0485d000 adfs adfs.SYS Thu Jun 26 21:52:37 2008 (48640195)
fffff880`06ab7000 fffff880`06b40000 afd afd.sys Wed Dec 28 03:59:08 2011 (4EFA940C)
fffff880`07ba9000 fffff880`07bbf000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00df4000 fffff880`00dff000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`00cda000 fffff880`00ce3000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00daf000 fffff880`00dd9000 ataport ataport.SYS Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`07f51000 fffff880`07f74000 AtiHdmi AtiHdmi.sys Thu May 06 10:20:39 2010 (4BE289E7)
fffff880`07450000 fffff880`07b2c000 atikmdag atikmdag.sys Wed Jun 02 02:37:54 2010 (4C05B5F2)
fffff880`06f99000 fffff880`06fdf000 atikmpag atikmpag.sys Wed Jun 02 02:42:47 2010 (4C05B717)
fffff960`00860000 fffff960`008c1000 ATMFD ATMFD.DLL Sat Feb 19 04:13:38 2011 (4D5F4372)
fffff880`00e09000 fffff880`00e15000 BATTC BATTC.SYS Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`01bed000 fffff880`01bf4000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`06e54000 fffff880`06f73000 BHDrvx64 BHDrvx64.sys Sat Feb 11 03:28:02 2012 (4F35E042)
fffff880`06c00000 fffff880`06c11000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`02d4e000 fffff880`02d6c000 bowser bowser.sys Wed Feb 23 05:15:06 2011 (4D6497DA)
fffff880`01b85000 fffff880`01bb3000 ccSetx64 ccSetx64.sys Fri Nov 04 22:05:25 2011 (4EB461A5)
fffff960`00690000 fffff960`006b7000 cdd cdd.dll unavailable (00000000)
fffff880`01b5b000 fffff880`01b85000 cdrom cdrom.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000 CI CI.dll Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`01aad000 fffff880`01add000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00d51000 fffff880`00daf000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`07c96000 fffff880`07c9a500 CmBatt CmBatt.sys Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`0116b000 fffff880`011de000 cng cng.sys Thu Nov 17 04:26:35 2011 (4EC48CFB)
fffff880`00e00000 fffff880`00e09000 compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`07b99000 fffff880`07ba9000 CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`07fd9000 fffff880`07fe7000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`01add000 fffff880`01b072a0 CtClsFlt CtClsFlt.sys Mon Jun 15 06:06:41 2009 (4A35D6E1)
fffff880`06ddb000 fffff880`06df9000 dfsc dfsc.sys Wed Apr 27 03:57:39 2011 (4DB78623)
fffff880`06dcc000 fffff880`06ddb000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01435000 fffff880`0144b000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`07fb1000 fffff880`07fd3000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`01b15000 fffff880`01b5b000 dtsoftbus01 dtsoftbus01.sys Fri Jun 17 08:38:37 2011 (4DFB047D)
fffff880`07fe7000 fffff880`07ff3000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`06e1a000 fffff880`06e2d000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`07ff3000 fffff880`07ffe000 dump_msahci dump_msahci.sys Sat Nov 14 04:36:50 2009 (4AFE33E2)
fffff880`07e7f000 fffff880`07e8b000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`07ca1000 fffff880`07d95000 dxgkrnl dxgkrnl.sys Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`07d95000 fffff880`07ddb000 dxgmms1 dxgmms1.sys Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`06d2d000 fffff880`06da6000 eeCtrl64 eeCtrl64.sys Fri Jan 20 23:39:48 2012 (4F19FB44)
fffff880`06da6000 fffff880`06dcc000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri Jan 20 23:39:49 2012 (4F19FB45)
fffff880`01157000 fffff880`0116b000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0109a000 fffff880`010e6000 fltmgr fltmgr.sys Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`0142b000 fffff880`01435000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`0103a000 fffff880`01074000 fvevol fvevol.sys Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`0162b000 fffff880`01675000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff800`039f1000 fffff800`03a3a000 hal hal.dll Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`07ddb000 fffff880`07dff000 HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`07c00000 fffff880`07c11000 HECIx64 HECIx64.sys Thu Sep 17 20:54:16 2009 (4AB293E8)
fffff880`02c00000 fffff880`02cc8000 HTTP HTTP.sys Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`017ef000 fffff880`017f8000 hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`0828f000 fffff880`082ad000 i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`06cb0000 fffff880`06d2d000 IDSvia64 IDSvia64.sys Tue Nov 22 20:23:23 2011 (4ECC04BB)
fffff880`07b83000 fffff880`07b99000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`01bb3000 fffff880`01be4000 Ironx64 Ironx64.SYS Tue Nov 15 02:00:53 2011 (4EC1C7D5)
fffff880`07c78000 fffff880`07c87000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00b9d000 fffff800`00ba7000 kdcom kdcom.dll Sat Feb 05 12:21:45 2011 (4D4D40D9)
fffff880`07e8d000 fffff880`07ed0000 ks ks.sys Thu Mar 04 04:32:25 2010 (4B8F37D9)
fffff880`01400000 fffff880`0141a000 ksecdd ksecdd.sys Thu Nov 17 03:54:33 2011 (4EC48579)
fffff880`01600000 fffff880`0162b000 ksecpkg ksecpkg.sys Thu Nov 17 04:27:30 2011 (4EC48D32)
fffff880`07fd3000 fffff880`07fd8200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`01273000 fffff880`01288000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`01074000 fffff880`01097000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00cf9000 fffff880`00d3d000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`015ee000 fffff880`015fc000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`07c87000 fffff880`07c96000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`00cc0000 fffff880`00cda000 mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02d6c000 fffff880`02d84000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`02d84000 fffff880`02db1000 mrxsmb mrxsmb.sys Wed May 04 03:51:06 2011 (4DC0BF1A)
fffff880`02db1000 fffff880`02dff000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:44:55 2011 (4E17C0A7)
fffff880`04822000 fffff880`04845000 mrxsmb20 mrxsmb20.sys Wed May 04 03:51:05 2011 (4DC0BF19)
fffff880`00dd9000 fffff880`00de4000 msahci msahci.sys Sat Nov 14 04:36:50 2009 (4AFE33E2)
fffff880`01a5e000 fffff880`01a69000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00fa0000 fffff880`00faa000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01200000 fffff880`0125e000 msrpc msrpc.sys Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`06ca5000 fffff880`06cb0000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`017dd000 fffff880`017ef000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0168b000 fffff880`0177d000 ndis ndis.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`07be3000 fffff880`07bef000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`02d1c000 fffff880`02d2f000 ndisuio ndisuio.sys Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`07400000 fffff880`0742f000 ndiswan ndiswan.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`07f3c000 fffff880`07f51000 NDProxy NDProxy.SYS Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`06b85000 fffff880`06b94000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`06a72000 fffff880`06ab7000 netbt netbt.sys Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`0177d000 fffff880`017dd000 NETIO NETIO.SYS Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`082ba000 fffff880`08967000 NETw5s64 NETw5s64.sys Tue Sep 15 20:40:39 2009 (4AAFEDB7)
fffff880`01a69000 fffff880`01a7a000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`06c99000 fffff880`06ca5000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03416000 fffff800`039f1000 nt ntkrnlmp.exe Sat Nov 19 12:35:16 2011 (4EC7A284)
fffff880`0144c000 fffff880`015ee000 Ntfs Ntfs.sys Fri Mar 11 03:39:25 2011 (4D79996D)
fffff880`01be4000 fffff880`01bed000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`02cc9000 fffff880`02d1c000 nwifi nwifi.sys Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`06b49000 fffff880`06b6f000 pacer pacer.sys Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00fea000 fffff880`00fff000 partmgr partmgr.sys Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00faa000 fffff880`00fdd000 pci pci.sys Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00de4000 fffff880`00df4000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0141a000 fffff880`0142b000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0485d000 fffff880`04903000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`07bef000 fffff880`07bf8000 pneteth pneteth.sys Thu Sep 02 22:49:45 2010 (4C801BF9)
fffff880`07f74000 fffff880`07fb1000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00d3d000 fffff880`00d51000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`01399000 fffff880`013a4e00 PxHlpa64 PxHlpa64.sys Wed Jun 24 00:16:35 2009 (4A416253)
fffff880`07bbf000 fffff880`07be3000 rasl2tp rasl2tp.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`0742f000 fffff880`0744a000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`06fdf000 fffff880`07000000 raspptp raspptp.sys Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`06e00000 fffff880`06e1a000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`06c48000 fffff880`06c99000 rdbss rdbss.sys Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`01a43000 fffff880`01a4c000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01a4c000 fffff880`01a55000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01a55000 fffff880`01a5e000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01000000 fffff880`0103a000 rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`0898d000 fffff880`089a6000 rimspe64 rimspe64.sys Thu Jul 02 00:54:49 2009 (4A4BF749)
fffff880`08974000 fffff880`0898d000 risdpe64 risdpe64.sys Wed Jul 01 10:31:57 2009 (4A4B2D0D)
fffff880`089a6000 fffff880`089fc000 rixdpe64 rixdpe64.sys Sat Jul 04 11:27:00 2009 (4A4F2E74)
fffff880`02d2f000 fffff880`02d47000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0823e000 fffff880`0828f000 Rt64win7 Rt64win7.sys Tue Jan 12 06:37:27 2010 (4B4C18A7)
fffff880`04903000 fffff880`0490e000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`0167d000 fffff880`01685000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0125e000 fffff880`01273000 SRTSPX64 SRTSPX64.SYS Tue Nov 22 23:52:20 2011 (4ECC35B4)
fffff880`0ba30000 fffff880`0bac5000 srv srv.sys Fri Apr 29 04:13:05 2011 (4DBA2CC1)
fffff880`0494d000 fffff880`049b4000 srv2 srv2.sys Fri Apr 29 04:12:51 2011 (4DBA2CB3)
fffff880`0490e000 fffff880`0493b000 srvnet srvnet.sys Fri Apr 29 04:12:35 2011 (4DBA2CA3)
fffff880`01675000 fffff880`0167d000 stdflt stdflt.sys Thu Jul 16 16:36:50 2009 (4A5F4912)
fffff880`07e00000 fffff880`07e7f000 stwrt64 stwrt64.sys Thu Jan 21 10:15:11 2010 (4B58292F)
fffff880`082b8000 fffff880`082b9480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`010e6000 fffff880`01157000 SYMDS64 SYMDS64.SYS Mon May 16 23:15:03 2011 (4DD1A1E7)
fffff880`01288000 fffff880`01399000 SYMEFA64 SYMEFA64.SYS Wed Nov 23 00:49:28 2011 (4ECC4318)
fffff880`06bc3000 fffff880`06bfb000 SYMEVENT64x86 SYMEVENT64x86.SYS Mon Jan 23 18:57:54 2012 (4F1DADB2)
fffff880`06a00000 fffff880`06a6c000 SYMNETS SYMNETS.SYS Sat Nov 12 21:11:53 2011 (4EBEE119)
fffff880`07b2c000 fffff880`07b77000 SynTP SynTP.sys Mon Aug 24 18:37:05 2009 (4A92CFC1)
fffff880`01800000 fffff880`019fe000 tcpip tcpip.sys Thu Sep 29 04:52:31 2011 (4E83EB7F)
fffff880`0493b000 fffff880`0494d000 tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`01a98000 fffff880`01aa5000 TDI TDI.SYS Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`01a7a000 fffff880`01a98000 tdx tdx.sys Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`06baf000 fffff880`06bc3000 termdd termdd.sys Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`00580000 fffff960`0058a000 TSDDD TSDDD.dll Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`06f73000 fffff880`06f99000 tunnel tunnel.sys Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`02d47000 fffff880`02d4e000 TurboB TurboB.sys Mon Nov 02 20:47:34 2009 (4AEF4566)
fffff880`07ed0000 fffff880`07ee2000 umbus umbus.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`06e2d000 fffff880`06e4a000 usbccgp usbccgp.sys Tue Mar 29 04:32:29 2011 (4D9152CD)
fffff880`082ad000 fffff880`082aef00 USBD USBD.SYS Tue Mar 29 04:32:09 2011 (4D9152B9)
fffff880`07c11000 fffff880`07c22000 usbehci usbehci.sys Tue Mar 29 04:32:16 2011 (4D9152C0)
fffff880`07ee2000 fffff880`07f3c000 usbhub usbhub.sys Tue Mar 29 04:32:44 2011 (4D9152DC)
fffff880`07c22000 fffff880`07c78000 USBPORT USBPORT.SYS Tue Mar 29 04:32:20 2011 (4D9152C4)
fffff880`06c11000 fffff880`06c3e200 usbvideo usbvideo.sys Thu Mar 04 04:40:57 2010 (4B8F39D9)
fffff880`00fdd000 fffff880`00fea000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01a00000 fffff880`01a0e000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01a0e000 fffff880`01a33000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00e15000 fffff880`00e2a000 volmgr volmgr.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00e2a000 fffff880`00e86000 volmgrx volmgrx.sys Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`013a5000 fffff880`013f1000 volsnap volsnap.sys Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`08967000 fffff880`08974000 vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`06b6f000 fffff880`06b85000 vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`0bac5000 fffff880`0bacf000 vwifimp vwifimp.sys Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`06b94000 fffff880`06baf000 wanarp wanarp.sys Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`01a33000 fffff880`01a43000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e8d000 fffff880`00f31000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f31000 fffff880`00f40000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`06b40000 fffff880`06b49000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000c0000 fffff960`003d4000 win32k win32k.sys Fri Feb 03 04:15:32 2012 (4F2B5F64)
fffff880`082af000 fffff880`082b8000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f97000 fffff880`00fa0000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`011de000 fffff880`011ff000 WudfPf WudfPf.sys Fri Jan 15 07:32:54 2010 (4B501A26)
Unloaded modules:
fffff880`01add000 fffff880`01aeb000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`01aeb000 fffff880`01af7000 dump_pciidex
Checksum: 00000000
ImageSize: 0000C000
fffff880`01af7000 fffff880`01b02000 dump_msahci.
Checksum: 00000000
ImageSize: 0000B000
fffff880`01b02000 fffff880`01b15000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
