Missing System Protection Tab
Hi there! I'm new here. :p
I hope that someone out there can help me out. I just installed Windows Vista Home Premium Lite 32-bit.
When I wanted to create a restore point, I couldn't. Instead of the System Protection Tab, the System Properties Tab comes out whenever I try to create a restore point.
Can anyone out there help me?
Thanks :p
Celestra
Former Moderator
Hi, Has your system protection been enabled? To open manually, left click pane system protection. Give administrator password. Click system protection, then click create. In the system protection dialog box type description and then click create. Make sure to close all files etc. before hand.
