motherbord changing to the same one
i have a little bit problem,
my motherboard went wrong, and thats why i had to buy a new one ( but exactly the same one - the same producer, the same type. and the same version, so nearly nothing have changed)
After this changing the win7 is not working, during the boot it says sg about the motherboard ...
(with other system it is working properly)
So i dont want to reinstall the whole win7,
what should i do?
thnx
regards
Embo
reghakr
Obviously a hardware problem, re-installing will do nothing.
You must have missed a connection somewhere on the board.
Hi, thnx, but it is strange a little for me, becuase the XP is working normaly after this changing (XP updated sg after the first boot, and its working now)
and i did not find anythink difference between the wrong and the new motherboard in connection with the wires, or jumpers...
