CJ12
I recently purchased Windows 7 and for a few months it was great. Then I did a repair install because I kept getting the 'busy' blue circle around the mouse pointer which was very distracting when trying to do my accountancy tests from the CD ROM.
After the repair install W7 seemed to be working okay for a while.
The next week or so I found programs (i.e. Excel) would suddenly shut down after a single click on the 'Office' symbol (top left). Also controlling files became problematic because a single click would mysteriously open a file, instead of e.g. selecting it. This and other erratic behaviour, the latest installment of which is the mouse wanders randomly around the screen, led me to believe I was the innocent victim of a nasty "malware" attack.
I was surprised because I use Kaspersky antivirus and Malwarebytes and use them regularly; I also have Driver Manager installed.
I back up regularly to an external USB hard drive, both manually copying files I use/modify often (mainly Excel), and doing a weekly back up using Windows 7 proprietory back up program.
Apart from re-installing it please can anyone recommend/suggest another option that might fix my issues with Windows 7? I could try System Restore but since I am not sure exactly when the problem emerged this is problematic.
Thanks in advance! (Written on my older XP System.)
