Mow over my BSOD while I research what I found
Attached;
1 CPUID Screen Shots
2 SF Diagnostics Tool Files .ZIP
3 RAMMon - SPD Info .ZIP and .TXT
My History
Pre Yesterday many BSOD could not narrow it down. PC guy told me it was my web cam they up dated my drivers. No Luck.. BSOD Was trying to convert DVD files using DVDfab to a format for an Android Tablet BSOD BSOD BSOD. Ok Update all drivers...
Ran program called DriverUpDate found 9 drivers out of date. Updated all these ie. Video Card, Audio Card, Mouse, AMD AHCI Compatible RAID Controller, Both Wire and wireless Network, Hauppauge HVR-2250 TV Tuner, ?? ,?? and ?? .
Today Doing some work on Eclipce (Android program Developing) BSOD But this time I seen hcw89.sys. Linked to the Hauppauge card. Ok I found you here. Removed Card. All well so far. I turned of auto restart for next time. and will run the memory test with out the Tuner installed. Ran Program called BlueScreenView Seen Pre today ntoskrnl.exe is at fault now its that hcw89.sys. and I have had more than 5 BSOD but that is all that is listed.
One Problem I am having now is boot up. its not unless I hold Esc at the start and select the boot device. Did I mess up some how that file that tell the system what to boot with. What is that called? Getting Late Going to sleep. I'm sure it will not fix itself over night.
Elmer
Hi capple and Welcome to The Forum.
STOP 0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL.
Usual causes:
Device driver.
Your latest dump file lists hcw89.sys as the probable cause. As you know this is a Huappage driver.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
F-Secure has been known to be the cause of BSOD's on some Windows 7 systems.
Uninstall F-Secure through Programs and Features then boot to Safe Mode and use the correct F-Secure Cleaup tool until your issue is resolved. Download Microsoft Security Essentials as its replacement. Make sure Windows firewall is enabled!
pcouffin.sys Tue Dec 05 14:39:30 2006 PCouffin is part of VSO software, related to CD/DVD burning software and has known issues with Windows 7. Update or Uninstall your current CD/DVD burning software.
There's a couple of Norton drivers still installed and loading. Use the Norton Removal Tool in Safe Mode.
Bugcheck Analysis:
BugCheck D1, {580013, 2, 0, fffff8800429d2b5}
Unable to load image \SystemRoot\system32\DRIVERS\hcw89.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for hcw89.sys
*** ERROR: Module load completed but symbols could not be loaded for hcw89.sys
Probably caused by : hcw89.sys ( hcw89+6d2b5 )
Followup: MachineOwner
3: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000580013, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8800429d2b5, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002ecc100
 0000000000580013
CURRENT_IRQL:  2
FAULTING_IP:
hcw89+6d2b5
fffff880`0429d2b5 ff5010          call    qword ptr [rax+10h]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
TRAP_FRAME:  fffff88002ffbae0 -- (.trap 0xfffff88002ffbae0)
rax=0000000000580003 rbx=0000000000000000 rcx=fffffa8008d2bb30
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800429d2b5 rsp=fffff88002ffbc70 rbp=fffffa8007bca6f0
 r8=0000000000000000  r9=0000000000000000 r10=fffff80002c1d000
r11=0000000000000002 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na po nc
hcw89+0x6d2b5:
fffff880`0429d2b5 ff5010          call    qword ptr [rax+10h] ds:7830:00000000`00580013=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002c991e9 to fffff80002c99c40
STACK_TEXT:
fffff880`02ffb998 fffff800`02c991e9 : 00000000`0000000a 00000000`00580013 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`02ffb9a0 fffff800`02c97e60 : 00000000`00000000 00000000`00000001 fffff800`02c95663 fffff880`043116b0 : nt!KiBugCheckDispatch+0x69
fffff880`02ffbae0 fffff880`0429d2b5 : fffff880`043116b0 fffffa80`07bca960 fffff880`02ffbc98 00000000`00000018 : nt!KiPageFault+0x260
fffff880`02ffbc70 fffff880`043116b0 : fffffa80`07bca960 fffff880`02ffbc98 00000000`00000018 00000000`00000000 : hcw89+0x6d2b5
fffff880`02ffbc78 fffffa80`07bca960 : fffff880`02ffbc98 00000000`00000018 00000000`00000000 fffff880`042392c4 : hcw89+0xe16b0
fffff880`02ffbc80 fffff880`02ffbc98 : 00000000`00000018 00000000`00000000 fffff880`042392c4 fffff880`02fd3180 : 0xfffffa80`07bca960
fffff880`02ffbc88 00000000`00000018 : 00000000`00000000 fffff880`042392c4 fffff880`02fd3180 fffffa80`074e0680 : 0xfffff880`02ffbc98
fffff880`02ffbc90 00000000`00000000 : fffff880`042392c4 fffff880`02fd3180 fffffa80`074e0680 fffff880`02fddfc0 : 0x18
STACK_COMMAND:  kb
FOLLOWUP_IP:
hcw89+6d2b5
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  hcw89+6d2b5
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hcw89
IMAGE_NAME:  hcw89.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4e134b6d
FAILURE_BUCKET_ID:  X64_0xD1_hcw89+6d2b5
Drivers:
fffff880`0457f000 fffff880`045bd000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00eef000 fffff880`00f46000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`02cd3000 fffff880`02d5c000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`045de000 fffff880`045f4000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`019ae000 fffff880`019fd000   ahcix64s ahcix64s.sys Wed Sep 23 13:52:47 2009 (4ABA1A1F)
fffff880`04021000 fffff880`04035000   amdiox64 amdiox64.sys Thu Feb 18 15:17:53 2010 (4B7D5A21)
fffff880`03b68000 fffff880`03b7d000   amdppm   amdppm.sys   Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`01017000 fffff880`0105e000   amdsbs   amdsbs.sys   Fri Mar 20 18:36:03 2009 (49C3E213)
fffff880`010c1000 fffff880`010cc000   amdxata  amdxata.sys  Wed Oct 07 21:13:10 2009 (4ACCF656)
fffff880`05424000 fffff880`05455000   AODDriver2 AODDriver2.sys Wed Jun 15 09:38:35 2011 (4DF86F8B)
fffff880`0cf66000 fffff880`0cf71000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`05687000 fffff880`060ed000   atikmdag atikmdag.sys Thu Nov 10 02:52:46 2011 (4EBB3C7E)
fffff880`03b7d000 fffff880`03bd2000   atikmpag atikmpag.sys Thu Nov 10 02:12:44 2011 (4EBB331C)
fffff880`019a6000 fffff880`019ae000   AtiPcie64 AtiPcie64.sys Wed Mar 10 14:33:45 2010 (4B97ADC9)
fffff960`00990000 fffff960`009f1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`043fb000 fffff880`043fee80   BdaSup   BdaSup.SYS   Tue Jul 14 01:06:40 2009 (4A5BCC10)
fffff880`015ed000 fffff880`015f4000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03b31000 fffff880`03b42000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`05544000 fffff880`05562000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00730000 fffff960`00757000   cdd      cdd.dll      unavailable (00000000)
fffff880`00e00000 fffff880`00e2a000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00cc4000 fffff880`00d84000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`0400f000 fffff880`04021000   circlass circlass.sys Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`01976000 fffff880`019a6000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00c66000 fffff880`00cc4000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0118a000 fffff880`011fc000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`045c6000 fffff880`045d6000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`05455000 fffff880`0545e000   cpuz135_x64 cpuz135_x64.sys Wed Sep 21 09:23:41 2011 (4E799F0D)
fffff880`0864e000 fffff880`0865c000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03b13000 fffff880`03b31000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`03b04000 fffff880`03b13000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01960000 fffff880`01976000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`089dc000 fffff880`089fe000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`08666000 fffff880`086b5000   dump_ahcix64s dump_ahcix64s.sys Wed Sep 23 13:52:47 2009 (4ABA1A1F)
fffff880`0865c000 fffff880`08666000   dump_diskdump dump_diskdump.sys Fri Apr 22 21:04:32 2011 (4DB1DF50)
fffff880`086b5000 fffff880`086c8000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`07b92000 fffff880`07b9e000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`060ed000 fffff880`061e1000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`05600000 fffff880`05646000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0ce00000 fffff880`0ce36000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`01118000 fffff880`0112c000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`010cc000 fffff880`01118000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`03ad8000 fffff880`03aecda0   fsdfw    fsdfw.sys    Wed Oct 28 14:57:21 2009 (4AE85BD1)
fffff880`03aed000 fffff880`03af63a0   fses     fses.sys     Tue Mar 09 11:37:48 2010 (4B96330C)
fffff880`0bb28000 fffff880`0bb5c000   fsgk     fsgk.sys     Tue Jul 05 16:48:27 2011 (4E13324B)
fffff880`03af7000 fffff880`03b037e0   fshs     fshs.sys     Fri Jul 03 12:48:07 2009 (4A4DEFF7)
fffff880`03ad0000 fffff880`03ad8000   fsvista  fsvista.sys  Tue Mar 18 06:37:07 2008 (47DF6313)
fffff880`01926000 fffff880`01960000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01829000 fffff880`01873000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`03206000 fffff800`0324f000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`04230000 fffff880`043b7f00   hcw89    hcw89.sys    Tue Jul 05 18:35:41 2011 (4E134B6D)
fffff880`0455b000 fffff880`0457f000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`08611000 fffff880`0862a000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`08600000 fffff880`08611000   hidir    hidir.sys    Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`0862a000 fffff880`08632080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`086c8000 fffff880`086d6000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0547b000 fffff880`05544000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`0191d000 fffff880`01926000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`041f1000 fffff880`04200000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`08633000 fffff880`08641000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00b9b000 fffff800`00ba5000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`043b8000 fffff880`043fb000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013e5000 fffff880`01400000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`015af000 fffff880`015da000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`04200000 fffff880`04205200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`07a21000 fffff880`07a36000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`07bc7000 fffff880`07bea000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c45000 fffff880`00c52000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`07bb9000 fffff880`07bc7000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04000000 fffff880`0400f000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`08641000 fffff880`0864e000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00fc3000 fffff880`00fdd000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`05562000 fffff880`0557a000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0bb8d000 fffff880`0bbb5000   mrxdav   mrxdav.sys   Sat Nov 20 09:26:42 2010 (4CE79452)
fffff880`0557a000 fffff880`055a7000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`055a7000 fffff880`055f5000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`05400000 fffff880`05424000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`01000000 fffff880`0100b000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f4f000 fffff880`00f59000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0cfdf000 fffff880`0cfe0c00   MSPCLOCK MSPCLOCK.sys Tue Jul 14 01:00:17 2009 (4A5BCA91)
fffff880`0cf71000 fffff880`0cf72a80   MSPQM    MSPQM.sys    Tue Jul 14 01:00:17 2009 (4A5BCA91)
fffff880`0112c000 fffff880`0118a000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`03ac5000 fffff880`03ad0000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`0190b000 fffff880`0191d000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0145c000 fffff880`0154f000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`04424000 fffff880`04430000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`07a89000 fffff880`07a9c000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`04193000 fffff880`041c2000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`07b0a000 fffff880`07b1f000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`02c00000 fffff880`02c0f000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02d5c000 fffff880`02da1000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`0154f000 fffff880`015af000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`04036000 fffff880`04186000   netr28x  netr28x.sys  Mon Mar 07 01:53:24 2011 (4D743A94)
fffff880`00e2a000 fffff880`00e3b000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03ab9000 fffff880`03ac5000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c1d000 fffff800`03206000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01242000 fffff880`013e5000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01618000 fffff880`01621000   Null     Null.SYS     unavailable (00000000)
fffff880`07a36000 fffff880`07a89000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`02daa000 fffff880`02dd0000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00f99000 fffff880`00fae000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f59000 fffff880`00f8c000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`041dc000 fffff880`041f0380   pcouffin pcouffin.sys Tue Dec 05 14:39:30 2006 (457584A2)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0b0ad000 fffff880`0b153000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0899f000 fffff880`089dc000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c52000 fffff880`00c66000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`04400000 fffff880`04424000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04430000 fffff880`0444b000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04206000 fffff880`04227000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`041c2000 fffff880`041dc000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03a68000 fffff880`03ab9000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`0444b000 fffff880`04456000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`015f4000 fffff880`015fd000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0baa7000 fffff880`0bad5000   rdpdr    rdpdr.sys    Sat Nov 20 11:06:41 2010 (4CE7ABC1)
fffff880`0144f000 fffff880`01458000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01239000 fffff880`01242000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`0baef000 fffff880`0bb28000   RDPWD    RDPWD.SYS    Sat Nov 20 11:04:37 2010 (4CE7AB45)
fffff880`018d1000 fffff880`0190b000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`061e1000 fffff880`061f9000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04456000 fffff880`044db000   Rt64win7 Rt64win7.sys Fri Jun 10 07:33:15 2011 (4DF1BAAB)
fffff880`086de000 fffff880`0899e280   RTKVHD64 RTKVHD64.sys Tue Jun 07 13:45:44 2011 (4DEE1D78)
fffff880`0b153000 fffff880`0b15e000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`0ce62000 fffff880`0ce6a000   serscan  serscan.sys  Tue Jul 14 01:35:32 2009 (4A5BD2D4)
fffff880`018c7000 fffff880`018d1000   speedfan speedfan.sys Fri Mar 18 16:08:46 2011 (4D83838E)
fffff880`018bf000 fffff880`018c7000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0ba0f000 fffff880`0baa7000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`0b000000 fffff880`0b069000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0b15e000 fffff880`0b18f000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`0105e000 fffff880`010c1000   storport storport.sys Fri Mar 11 04:30:23 2011 (4D79A55F)
fffff880`045f4000 fffff880`045f5480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01625000 fffff880`01829000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`0b18f000 fffff880`0b1a1000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`00c25000 fffff880`00c32000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`0bad5000 fffff880`0bae0000   tdtcp    tdtcp.sys    Tue Jul 14 01:16:32 2009 (4A5BCE60)
fffff880`00fdd000 fffff880`00fff000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`02c81000 fffff880`02c95000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00500000 fffff960`0050a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`0bae0000 fffff880`0baef000   tssecsrv tssecsrv.sys Sat Nov 20 11:04:09 2010 (4CE7AB29)
fffff880`03b42000 fffff880`03b68000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`05646000 fffff880`05658000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`07b1f000 fffff880`07b3c000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`045f6000 fffff880`045f7f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`0454a000 fffff880`0455b000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`0453c000 fffff880`0454a000   usbfilter usbfilter.sys Mon Nov 29 09:50:21 2010 (4CF3775D)
fffff880`07ab0000 fffff880`07b0a000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`044db000 fffff880`044e6000   usbohci  usbohci.sys  Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`044e6000 fffff880`0453c000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`05675000 fffff880`05684000   usbrpm   usbrpm.sys   Sat Nov 20 11:37:19 2010 (4CE7B2EF)
fffff880`07b9e000 fffff880`07bb9000   USBSTOR  USBSTOR.SYS  Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`00f8c000 fffff880`00f99000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`0121b000 fffff880`01229000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`00c00000 fffff880`00c25000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00fae000 fffff880`00fc3000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00d84000 fffff880`00de0000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01873000 fffff880`018bf000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`03a00000 fffff880`03a3c000   vpchbus  vpchbus.sys  Sat Nov 20 11:35:38 2010 (4CE7B28A)
fffff880`02de6000 fffff880`02dfa000   vpcnfltr vpcnfltr.sys Sat Nov 20 11:35:20 2010 (4CE7B278)
fffff880`05658000 fffff880`05675000   vpcusb   vpcusb.sys   Sat Nov 20 11:35:31 2010 (4CE7B283)
fffff880`02c2a000 fffff880`02c80600   vpcvmm   vpcvmm.sys   Sat Nov 20 11:35:48 2010 (4CE7B294)
fffff880`04186000 fffff880`04193000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`02dd0000 fffff880`02de6000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`02c0f000 fffff880`02c2a000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`01229000 fffff880`01239000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e3c000 fffff880`00ee0000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ee0000 fffff880`00eef000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02da1000 fffff880`02daa000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a4000   win32k   win32k.sys   unavailable (00000000)
fffff880`045bd000 fffff880`045c6000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f46000 fffff880`00f4f000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`07a00000 fffff880`07a21000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`0bb5c000 fffff880`0bb8d000   WUDFRd   WUDFRd.sys   Sat Nov 20 10:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`0cfa8000 fffff880`0cfd6000   usbvideo.sys
    Checksum:  00000000
    ImageSize:  0002E000
fffff880`0cf9b000 fffff880`0cfa8000   nx6000.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`0cf73000 fffff880`0cf8e000   usbaudio.sys
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`0cf8e000 fffff880`0cf91000   MSKSSRV.sys
    Checksum:  00000000
    ImageSize:  00003000
fffff880`0cf93000 fffff880`0cf9b000   drmkaud.sys
    Checksum:  00000000
    ImageSize:  00008000
fffff880`0cf91000 fffff880`0cf93000   MSTEE.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0cee3000 fffff880`0ceed000   hiber_storpo
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`0ceed000 fffff880`0cf3c000   hiber_ahcix6
    Checksum:  00000000
    ImageSize:  0004F000
fffff880`0cf3c000 fffff880`0cf4f000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0ce6a000 fffff880`0cee3000   eeCtrl64.sys
    Checksum:  00000000
    ImageSize:  00079000
fffff880`045d6000 fffff880`045de000   serscan.sys
    Checksum:  00000000
    ImageSize:  00008000
fffff880`0cfe1000 fffff880`0cfeb000   hiber_storpo
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`0ce00000 fffff880`0ce4f000   hiber_ahcix6
    Checksum:  00000000
    ImageSize:  0004F000
fffff880`0ce4f000 fffff880`0ce62000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0cf73000 fffff880`0cf7d000   hiber_storpo
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`0cf7d000 fffff880`0cfcc000   hiber_ahcix6
    Checksum:  00000000
    ImageSize:  0004F000
fffff880`0cfcc000 fffff880`0cfdf000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`07b49000 fffff880`07b77000   usbvideo.sys
    Checksum:  00000000
    ImageSize:  0002E000
fffff880`07b3c000 fffff880`07b49000   nx6000.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`07b77000 fffff880`07b92000   usbaudio.sys
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`0cef5000 fffff880`0cf66000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01600000 fffff880`0160e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0160e000 fffff880`01618000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`01400000 fffff880`0144f000   dump_ahcix64
    Checksum:  00000000
    ImageSize:  0004F000
fffff880`015da000 fffff880`015ed000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Thank you for making sense of all this. I will take into consideration all you have provided. I hope to report back good news or no news at all and DVDfab did instal the PCouffin You talked about and would make sense why I goto Some BSOD while using it the other day.
Uninstalled F-Secure, Ran Unistall tools, Install MSE. Two BSOD already. One is new tcpip.sys and one is ntoskrnl.exe. SF Diagnostics Tool not working will redownload and try some more but hopfuly this zip is enough. Only change should be the Security software. hope these mini dumps work.
Elmer
Just a quickie. Did you right click the SF Diag tool & select Run as Administrator?
When you say DVDFab, Do you mean the free version as here? I ask because your drivers look fine apart from the pcouffin driver that is still loading in your last dmp file.
I've run that little program since I've had Windows 7 and pcouffin is not on my system.
If you GoTo C:\Windows\System32\drivers and rename the pcouffin.sys driver to pcouffin.bak. This will break the driver and prevent it from loading at the next boot. It will also break any software related to it.
Well that was it but That PC seems to be getting more unstable. I had the file from SF Diag but as I was posting to here ...BSOD "Page_Fault_In _None_Page_Area" ?Hard Ware?. Then I restart. Quickly ..BSOD "Interup_Exception_Not_Handled" More Details "ahcix64.sys. I'm running system restore now to roll back to prior me updating all out of data driver pe-"DriverUpdata". It did have me update the raid drivers and what I thing have something to do with the hardware associated with the usb and sata stuff. I have ".BCK" the pcouffin driver before the first BSOD. Ill Come back and post the SF Diag files from Pre_BSOD's of today, and if I can I will post the files from after the restore as well.
Have to admit Getting real close to breaking down and letting the corporations win and buy a new tower. I know they build this stuff to run normally 2-3 years. Mine is only 1.2 years old I'm on the low side of the average.
