GamerKingFaiz
Hey guys, I've been trying to record a game of Starcraft 2 in 720p for the longest time, but I've been running into quite a few problems.
The first try I did, I recorded using Fraps at 1024x768 and at half quality on Fraps, and I came out with pretty "meh" quality:
Then I tried to record at 1280x720 in Fraps at full size, and I got better quality:
But the problem is that Fraps video files are really big, so I decided if I am going to be uploading this, I need to compress it. So I used Windows Movie Maker, and saved the movie in a 720p format, and it definitely reduced the file size into something more easy to upload. But the problem is that I now get black bars on all sides:
How can I compress a video but keep it widescreen without any black bars?
You'll be much better off using VirtualDubMod to compress to any AVI standard (any codec) or TMPGEnc 2.524.63.181 for DVD standard.
XviD codec should suit you well here for size/quality.
If you need help with either, let me know. They aren't too difficult to use.
Alright, I got everything to finally work out. I used VirtualDub with a Xvid codec, and it compresses great with minimal to no loss in quality!
Like check out this test clip for how my future broadcasts will look:
