- Thread Author
- #1
Is my CPU going bad? Startup error: "Warning! CPU has been changed. Please re-enter CPU settings."
It is HomeBuilt, 6years old. ABIT AN8 mobo; Phoenix-Award Bios v6.00PG; Athlon 64 3500+; 4 Gig. Corsair XMS, 400 speed; CoolerMaster 650W PSU; Windows 7 home prem. on 200 Gig Sata HD.
I like to shut down every night. Lately, it hangs with this error right after the flash screen of ABIT logo. It gives me the option F1 to continue, Del. to enter setup. If I punch F1, it promptly boots and runs just like always.
The same time this showed up, my clock on desktop runs slow. Real Slow.
So far I have scanned with MSE, then scanned with MBAM, I pulled the CMOS battery, then moved the CMOS jumper, waited several minutes, then re-set the jumper before I replaced the battery. Oh, yeh, "bout forgot I had a couple of extra hard drive hooked up, one Sata and another Pata, I unplugged both of them, also unplugged my USB flash drive also unplugged USB hub, and unplugged an old USB Zip Drive. I removed all that stuff before I re-set the Bios. Then, of course I reset both the calandar and the correct time.
I googled the slow clock and somebody said to go into device manager> IDE ATA/PATA controllers and check the box "enable DMA" on each Channel. I did that.
I shut down and re-started TWICE last evening with no error. Shut down overnight and today the error is back.
Any help appreciated
