layitlo
- Joined
- Apr 28, 2010
Ok I've done an upgrade to my pc. I swapped out the motherboard and the harddrive. Before I did the swap I installed everything to the drive while it was in another case. Then I put it in my case that has two other harddrives. Now all of them were working when I did the change over. One of them still works fine but the other one that has all of my important files like family pics and stuff will not open. It tells me it's cupport and unreadable. I put it in another computer to be it wasn't my computer causing it. I still have the old board and I'm going to put it together to give to my daughter so I'll try it on there also. But if it doesn't work is there anything I can do to recover it so I can atleast save the pics? They are something I can't replace. It has to be something really cheap or free I can get. I'm on ssi and broke right now so I can't afford anything. I have activekilldisk which has the recovery feature but I haven't had a chance to look at it. Thanks in advance.
