need help forcing a program
Hi ! I am new to Windows 7 and I have a question that I need an answer to if at all possible.
I was told there is a way to force a program to use all of my processors and Ram memory. I need to figure out if this possible and what I have to do to accomplish this.
I am wanting to force a video game to use all four processors and all/ more Ram memory than the game was designed to use. According the Game manufacturs/ producer I was informed to use Msconfig to set up this procedure and for it to work properly. Is this correct or is there a different way I can force this game to work better?
Thank you in advance.
The game should be given access to all the available resources. 'msconfig', is commonly used to force the computer to use all resources on startup, but if the instructions provided with the game give you specific directions to use it, there's no immediate harm in doing so.
