Windows 7 need help reading .dmp files....
ridleyj329
I'm currently running an hp dv4-1428dx. all stock except for the hard drive i upgraded and my os to win7 pro x64. would like someone who can explain to me how to read these rather than just explain what it says, please. thanks guys!
  • 032011-15553-01.dmp
  • 031911-16426-01.dmp
  • 031711-18657-01.dmp
Update drivers:
Realtek LAN
Rt64win7.sys Thu Feb 26 04:04:13 2009
Realtek
Broadcom 802.11 Network Adapter wireless
bcmwl664.sys Tue Jul 07 20:45:04 2009
ATI
atikmdag.sys Mon Aug 17 23:05:47 2009
CRASH DUMPS
Loading Dump File [F:\DMP\031711-18657-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`02c08000 PsLoadedModuleList = 0xfffff800`02e4de90
Debug session time: Thu Mar 17 22:01:48.383 2011 (UTC - 4:00)
System Uptime: 0 days 21:01:53.381
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 50, {fffffffffffffff6, 0, fffff80002f553de, 0}
Probably caused by : ntkrnlmp.exe ( nt!CmpKcbCacheLookup+1de )
Followup: MachineOwner
0: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffffffffffffff6, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80002f553de, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 0000000000000000, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002eb90e8
 fffffffffffffff6
FAULTING_IP:
fffff800`02f553de 418b45f4        mov     eax,dword ptr [r13-0Ch]
MM_INTERNAL_CODE:  0
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x50
PROCESS_NAME:  Cleaner_Valida
CURRENT_IRQL:  0
TRAP_FRAME:  fffff88005faef70 -- (.trap 0xfffff88005faef70)
rax=0000000000000000 rbx=0000000000000000 rcx=00000000000003bd
rdx=00000000006b3424 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002f553de rsp=fffff88005faf100 rbp=fffff8a000cda010
 r8=0000000000000008  r9=0000000000000000 r10=0000000000000002
r11=fffff88005faf280 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na pe nc
nt!CmpKcbCacheLookup+0x1de:
fffff800`02f553de 418b45f4        mov     eax,dword ptr [r13-0Ch] ds:ffffffff`fffffff4=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002c342ac to fffff80002c88640
STACK_TEXT:
fffff880`05faee08 fffff800`02c342ac : 00000000`00000050 ffffffff`fffffff6 00000000`00000000 fffff880`05faef70 : nt!KeBugCheckEx
fffff880`05faee10 fffff800`02c8676e : 00000000`00000000 ffffffff`fffffff6 fffff880`05faf300 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x4621f
fffff880`05faef70 fffff800`02f553de : fffffa80`0622b060 00000000`00000000 fffffa80`06633950 00000000`00000000 : nt!KiPageFault+0x16e
fffff880`05faf100 fffff800`02f560e5 : fffff880`05faf280 fffff880`00000001 fffff880`05faf698 fffff880`05faf690 : nt!CmpKcbCacheLookup+0x1de
fffff880`05faf1f0 fffff800`02f52794 : fffff8a0`099006a0 fffff880`05faf690 fffff880`05faf6e0 fffff880`05faf6c0 : nt!CmpBuildHashStackAndLookupCache+0x335
fffff880`05faf5d0 fffff800`02f82d38 : fffffa80`0431d3f8 fffffa80`00000000 fffffa80`0431d240 00000000`00000001 : nt!CmpParseKey+0x294
fffff880`05faf8d0 fffff800`02f83f56 : 00000000`000124c0 fffffa80`0431d240 00000000`00000000 fffffa80`03d08510 : nt!ObpLookupObjectName+0x588
fffff880`05faf9c0 fffff800`02f5782c : 00000000`0ab20400 00000000`00000000 fffff8a0`09900601 fffff880`05fafaa8 : nt!ObOpenObjectByName+0x306
fffff880`05fafa90 fffff800`02f59c9f : 00000000`0228d2d0 00000000`000f003f 00000000`0228d358 00000000`00000000 : nt!CmOpenKey+0x28a
fffff880`05fafbe0 fffff800`02c878d3 : fffffa80`06633950 fffff880`05fafca0 00000000`00000000 00000000`00000000 : nt!NtOpenKeyEx+0xf
fffff880`05fafc20 00000000`7734226a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0228d268 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7734226a
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!CmpKcbCacheLookup+1de
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7951a
FAILURE_BUCKET_ID:  X64_0x50_nt!CmpKcbCacheLookup+1de
DRIVERS
fffff880`04a69000 fffff880`04a76000   Accelerometer Accelerometer.sys Fri Jul 16 11:02:38 2010 (4C40748E)
fffff880`00ecb000 fffff880`00f22000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`0143b000 fffff880`014c4000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`045d5000 fffff880`045eb000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`05a79000 fffff880`05b9b000   agrsm64  agrsm64.sys  Mon Nov 10 10:01:35 2008 (49184CCF)
fffff880`02e26000 fffff880`02e3b000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`010e6000 fffff880`010f1000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`06471000 fffff880`0647c000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`010a8000 fffff880`010b1000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`010b1000 fffff880`010db000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`03e27000 fffff880`0443e000   atikmdag atikmdag.sys Mon Aug 17 23:05:47 2009 (4A8A1A8B)
fffff880`00f93000 fffff880`00f9f000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`04a7a000 fffff880`04d22000   bcmwl664 bcmwl664.sys Tue Jul 07 20:45:04 2009 (4A53EC10)
fffff880`01600000 fffff880`01607000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02fe4000 fffff880`02ff5000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`048cb000 fffff880`048e9000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00640000 fffff960`00667000   cdd      cdd.dll      unavailable (00000000)
fffff880`01826000 fffff880`01850000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`017ce000 fffff880`017e4000   CFRMD    CFRMD.sys    Thu Nov 25 07:40:39 2010 (4CEE5947)
fffff880`017e4000 fffff880`017f2000   CFRPD    CFRPD.sys    Thu Dec 09 03:02:58 2010 (4D008D32)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`01bb6000 fffff880`01be6000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00d1b000 fffff880`00d79000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04a64000 fffff880`04a68500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`0181e000 fffff880`01826000   cmderd   cmderd.sys   Wed Jan 05 12:09:44 2011 (4D24A5D8)
fffff880`0178c000 fffff880`017ce000   cmdguard cmdguard.sys Wed Jan 05 12:10:43 2011 (4D24A613)
fffff880`0142f000 fffff880`0143b000   cmdhlp   cmdhlp.sys   Wed Jan 05 12:09:59 2011 (4D24A5E7)
fffff880`014d8000 fffff880`0154a000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`00f8a000 fffff880`00f93000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`045c5000 fffff880`045d5000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`0499f000 fffff880`049a8000   cpuz135_x64 cpuz135_x64.sys Wed Jan 19 11:42:06 2011 (4D37145E)
fffff880`05a2e000 fffff880`05a3c000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02f43000 fffff880`02fc6000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`02fc6000 fffff880`02fe4000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`02f34000 fffff880`02f43000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01ba0000 fffff880`01bb6000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`047d5000 fffff880`047f7000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05a3c000 fffff880`05a48000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05a53000 fffff880`05a66000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`05a48000 fffff880`05a53000   dump_msahci dump_msahci.sys Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`05bc7000 fffff880`05bd3000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0443e000 fffff880`04532000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`04532000 fffff880`04578000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`0113d000 fffff880`01151000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010f1000 fffff880`0113d000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`0155b000 fffff880`01565000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01b66000 fffff880`01ba0000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01a59000 fffff880`01aa3000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff800`031f2000 fffff800`0323b000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`04578000 fffff880`0459c000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`04600000 fffff880`0465c000   HdAudio  HdAudio.sys  Sat Nov 20 05:44:23 2010 (4CE7A687)
fffff880`01b5c000 fffff880`01b66000   hpdskflt hpdskflt.sys Fri Jul 16 11:02:38 2010 (4C40748E)
fffff880`04802000 fffff880`048cb000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01b53000 fffff880`01b5c000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`04dd3000 fffff880`04df1000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01018000   inspect  inspect.sys  Wed Jan 05 12:09:49 2011 (4D24A5DD)
fffff880`04df1000 fffff880`04e00000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bbb000 fffff800`00bc5000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`046a9000 fffff880`046ec000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`013ce000 fffff880`013e9000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`01761000 fffff880`0178c000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`047f7000 fffff880`047fc200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0590a000 fffff880`0591f000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05bd3000 fffff880`05bf6000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cfa000 fffff880`00d07000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`05b9b000 fffff880`05baa000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`064a6000 fffff880`064b4000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04a55000 fffff880`04a64000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`00fcb000 fffff880`00fe5000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`048e9000 fffff880`04901000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`04901000 fffff880`0492e000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`0492e000 fffff880`0497b000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`0497b000 fffff880`0499f000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`010db000 fffff880`010e6000   msahci   msahci.sys   Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`015c3000 fffff880`015ce000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f2b000 fffff880`00f35000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01151000 fffff880`011af000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`02f29000 fffff880`02f34000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01b41000 fffff880`01b53000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0160e000 fffff880`01701000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`045eb000 fffff880`045f7000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`05972000 fffff880`05985000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`00cc0000 fffff880`00cef000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`047c0000 fffff880`047d5000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`01018000 fffff880`01027000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`011af000 fffff880`011f4000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01701000 fffff880`01761000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`015ce000 fffff880`015df000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02f1d000 fffff880`02f29000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c08000 fffff800`031f2000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0122b000 fffff880`013ce000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`017f2000 fffff880`017fb000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0591f000 fffff880`05972000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`01200000 fffff880`01226000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`00f75000 fffff880`00f8a000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00f35000 fffff880`00f68000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00fb4000 fffff880`00fbb000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fbb000 fffff880`00fcb000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0154a000 fffff880`0155b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0627a000 fffff880`06320000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0465c000 fffff880`04699000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d07000 fffff880`00d1b000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03e00000 fffff880`03e24000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`02e3b000 fffff880`02e56000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`00dd5000 fffff880`00df6000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`00fe5000 fffff880`00fff000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02ecc000 fffff880`02f1d000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`02e56000 fffff880`02e61000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`015a8000 fffff880`015b1000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015b1000 fffff880`015ba000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015ba000 fffff880`015c3000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01b07000 fffff880`01b41000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`05985000 fffff880`0599d000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04d2f000 fffff880`04d61000   Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009 (49A65B0D)
fffff880`0459c000 fffff880`045bc000   sdbus    sdbus.sys    Sat Nov 20 04:37:42 2010 (4CE796E6)
fffff880`06320000 fffff880`0632b000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01aff000 fffff880`01b07000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`064f9000 fffff880`06592000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`0636e000 fffff880`063d9000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`0632b000 fffff880`0635c000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`0586a000 fffff880`058e9000   stwrt64  stwrt64.sys  Wed Mar 24 00:01:24 2010 (4BA98E94)
fffff880`04a76000 fffff880`04a77480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`04a00000 fffff880`04a53000   SynTP    SynTP.sys    Thu May 27 17:41:36 2010 (4BFEE710)
fffff880`01855000 fffff880`01a59000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`0635c000 fffff880`0636e000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`01422000 fffff880`0142f000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`01400000 fffff880`01422000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`02eb8000 fffff880`02ecc000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00540000 fffff960`0054a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02e00000 fffff880`02e26000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`046ec000 fffff880`046fe000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`05baa000 fffff880`05bc7000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`04a53000 fffff880`04a54f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04dc2000 fffff880`04dd3000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04766000 fffff880`047c0000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`04d61000 fffff880`04d6c000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04d6c000 fffff880`04dc2000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0471b000 fffff880`0472a000   usbrpm   usbrpm.sys   Sat Nov 20 06:37:19 2010 (4CE7B2EF)
fffff880`05a00000 fffff880`05a2d280   usbvideo usbvideo.sys Sat Nov 20 05:44:34 2010 (4CE7A692)
fffff880`00f68000 fffff880`00f75000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01565000 fffff880`01573000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01573000 fffff880`01598000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01058000 fffff880`01094000   vmbus    vmbus.sys    Sat Nov 20 04:57:29 2010 (4CE79B89)
fffff880`01aa3000 fffff880`01ab3000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`00f9f000 fffff880`00fb4000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00d79000 fffff880`00dd5000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01ab3000 fffff880`01aff000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`0472a000 fffff880`04766000   vpchbus  vpchbus.sys  Sat Nov 20 06:35:38 2010 (4CE7B28A)
fffff880`013e9000 fffff880`013fd000   vpcnfltr vpcnfltr.sys Sat Nov 20 06:35:20 2010 (4CE7B278)
fffff880`046fe000 fffff880`0471b000   vpcusb   vpcusb.sys   Sat Nov 20 06:35:31 2010 (4CE7B283)
fffff880`02e61000 fffff880`02eb7600   vpcvmm   vpcvmm.sys   Sat Nov 20 06:35:48 2010 (4CE7B294)
fffff880`04d22000 fffff880`04d2f000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`015df000 fffff880`015f5000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`01027000 fffff880`01042000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`01598000 fffff880`015a8000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e18000 fffff880`00ebc000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ebc000 fffff880`00ecb000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`014c4000 fffff880`014cd000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00020000 fffff960`00331000   win32k   win32k.sys   Wed Jan 05 01:55:38 2011 (4D2415EA)
fffff880`01094000 fffff880`010a8000   winhv    winhv.sys    Sat Nov 20 04:20:02 2010 (4CE792C2)
fffff880`045bc000 fffff880`045c5000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f22000 fffff880`00f2b000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`058e9000 fffff880`0590a000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`06498000 fffff880`064a6000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0648a000 fffff880`06498000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0647c000 fffff880`0648a000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`05a66000 fffff880`05a74000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06400000 fffff880`06471000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01be6000 fffff880`01bf4000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01bf4000 fffff880`01c00000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01800000 fffff880`0180b000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`0180b000 fffff880`0181e000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
how can you tell what the fixes are? can you please explain what you were lookin at that told you this.
Old drivers are known to invoke blue screens. In your case, WinDbg identifies system kernel driver as the causer of the crash. However, a system file is very much unlikely (never) to be the real culprit. Therefore, update old drivers and enjoy. : )
Top Bottom
