Windows 7 Need Help with 7 x64 Constant BSOD
kweeceng
Hello guys, I know this forum from a little googling to solve the problem myself, but after so many tries, I failed and decided to need some help.
Lately (about a week) I got this constant BSOD which is really annoying because of the randomness (about once a day). I've tried so many things, Processor stability test, memtest, furmark, sfc scan, everything going smoothly, but then after a day, bam. Another BSOD.
I've uploaded the dmp file. Sorry for the bad english.
Any help would be appreciated :D
Solved. Thank you.
  • 092810-41059-01.rar
092810-41059-01.dmp
KMODE_EXCEPTION_NOT_HANDLED (1e)
Caused by : amdppm.sys (Microsoft Windows 7 Processor Device Driver)
PROCESS_NAME: dwm.exe
Stack: nt!, amdppm!
FAILURE_BUCKET_ID: X64_0x1E_amdppm!PerfSelectionPTStates+34
Update these drivers:
ElanFltr.sys Wed May 23 12:22:06 2007
Ortek USB Keypad
Waytech Development, Inc.
Rt64win7.sys Thu Feb 26 11:04:13 2009
Realtek 8136/8168/8169
Realtek
RTKVHD64.sys Mon Aug 31 13:19:33 2009
Realtek High Definition Audio
Realtek
atikmdag.sys Fri Aug 14 05:42:35 2009
ATI Video driver
ati.amd.com/support/driver.HTML
netr7364.sys Fri Mar 13 05:13:08 2009
Ralink 802.11 USB Wireless Adapter
Ralink corp. | Home
tap0901t.sys Wed Sep 16 09:02:43 2009
TAP-Win32 Virtual Network
Link Removed due to 404 Error
lirsgt.sys Sun May 17 16:06:57 2009
atksgt.sys Sun May 17 16:36:34 2009
Copy Protection platform dveloped by Tages SA
TAGES, the AAA Copy Protection System
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\Minidump\092810-41059-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02e49000 PsLoadedModuleList = 0xfffff800`03086e50
System Uptime: 0 days 0:09:31.003
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1E, {0, 0, 0, 0}
Probably caused by : amdppm.sys ( amdppm!PerfSelectionPTStates+34 )
Followup: MachineOwner
3: kd> !analyze -v
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
Debugging Details:
EXCEPTION_CODE: (Win32) 0 (0) -                           .
FAULTING_IP:
+0
00000000`00000000 ??              ???
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000000
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x1E
CURRENT_IRQL:  2
EXCEPTION_RECORD:  fffff880009b0be8 -- (.exr 0xfffff880009b0be8)
ExceptionAddress: fffff88003e28ba0 (amdppm!PerfSelectionPTStates+0x0000000000000034)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME:  fffff880009b0c90 -- (.trap 0xfffff880009b0c90)
rax=0000000000000064 rbx=0000000000000000 rcx=fffffa8004f1fb60
rdx=000000000000001e rsi=0000000000000000 rdi=0000000000000000
rip=fffff88003e28ba0 rsp=fffff880009b0e28 rbp=fffffa8004f79768
 r8=0000000000000001  r9=000000000000001e r10=000000000000001e
r11=0f0101050f010104 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na pe nc
amdppm!PerfSelectionPTStates+0x34:
fffff880`03e28ba0 458b5328        mov     r10d,dword ptr [r11+28h] ds:6050:0f010105`0f01012c=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002eb2c2e to fffff80002ebaed0
STACK_TEXT:
fffff880`009afcc8 fffff800`02eb2c2e : fffff880`009afd68 fffff880`009afde8 fffff880`009b0440 fffff800`02ee7e28 : nt!KeBugCheck
fffff880`009afcd0 fffff800`02ee0bed : fffff800`030c7c24 fffff800`03000a3c fffff800`02e49000 fffff880`009b0be8 : nt!KiKernelCalloutExceptionHandler+0xe
fffff880`009afd00 fffff800`02ee8250 : fffff800`03008a88 fffff880`009afd78 fffff880`009b0be8 fffff800`02e49000 : nt!RtlpExecuteHandlerForException+0xd
fffff880`009afd30 fffff800`02ef51b5 : fffff880`009b0be8 fffff880`009b0440 fffff880`00000000 00000000`00000001 : nt!RtlDispatchException+0x410
fffff880`009b0410 fffff800`02eba542 : fffff880`009b0be8 00000000`00000064 fffff880`009b0c90 00000000`00000064 : nt!KiDispatchException+0x135
fffff880`009b0ab0 fffff800`02eb8e4a : fffffa80`04e16050 fffffa80`03b2e7f0 00000000`70627375 fffff880`03e4e6f3 : nt!KiExceptionDispatch+0xc2
fffff880`009b0c90 fffff880`03e28ba0 : fffff800`02f74450 00000000`00000064 00000000`00000014 00000000`00000028 : nt!KiGeneralProtectionFault+0x10a
fffff880`009b0e28 fffff800`02f74450 : 00000000`00000064 00000000`00000014 00000000`00000028 00000000`00000002 : amdppm!PerfSelectionPTStates+0x34
fffff880`009b0e30 fffff800`02f74bed : 00000000`00000000 00000000`00000001 00000000`00000000 00000000`00000002 : nt!PpmPerfSelectProcessorState+0x1c0
fffff880`009b0e90 fffff800`02f7225c : fffff880`02fd3180 00000000`00000000 fffff800`0305b310 00000000`00000000 : nt!PpmPerfSelectProcessorStates+0xbd
fffff880`009b0ed0 fffff800`02ec65dc : fffff880`02fd3180 fffffa80`047f9050 00000000`00000000 00000000`00000000 : nt!PpmCheckRun+0x8c
fffff880`009b0f00 fffff800`02ec1065 : 000004d8`00000000 fffffa80`03fb6780 00000000`00000000 fffff800`02f721d0 : nt!KiRetireDpcList+0x1bc
fffff880`009b0fb0 fffff800`02ec0e7c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxRetireDpcList+0x5
fffff880`079c0bf0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchInterruptContinue
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  7
SYMBOL_NAME:  amdppm!PerfSelectionPTStates+34
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: amdppm
IMAGE_NAME:  amdppm.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc0fd
fffff880`03e26000 fffff880`03e3b000   amdppm     (pdb symbols)          c:\websymbols\amdppm.pdb\AB154B73C6884E70807CA6407175368D1\amdppm.pdb
    Loaded symbol image file: amdppm.sys
    Mapped memory image file: c:\websymbols\amdppm.sys\4A5BC0FD15000\amdppm.sys
    Image path: \SystemRoot\system32\DRIVERS\amdppm.sys
    Image name: amdppm.sys
    Timestamp:        Tue Jul 14 02:19:25 2009 (4A5BC0FD)
    CheckSum:         0001EA42
    ImageSize:        00015000
    File version:     6.1.7600.16385
    Product version:  6.1.7600.16385
    File flags:       0 (Mask 3F)
    File OS:          40004 NT Win32
    File type:        3.7 Driver
    File date:        00000000.00000000
    Translations:     0409.04b0
    CompanyName:      Microsoft Corporation
    ProductName:      Microsoft® Windows® Operating System
    InternalName:     amdppm.sys
    OriginalFilename: amdppm.sys
    ProductVersion:   6.1.7600.16385
    FileVersion:      6.1.7600.16385 (win7_rtm.090713-1255)
    FileDescription:  Processor Device Driver
    LegalCopyright:   © Microsoft Corporation. All rights reserved.
fffff800`00bcc000 fffff800`00bd6000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`02e00000 fffff800`02e49000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff800`02e49000 fffff800`03426000   nt       ntkrnlmp.exe Tue Jul 14 02:40:48 2009 (4A5BC600)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00cc0000 fffff880`00cc9000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`00cc9000 fffff880`00cd4000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00cd4000 fffff880`00ce5000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00cef000 fffff880`00cfc000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00cfc000 fffff880`00d10000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00d10000 fffff880`00d6e000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00d6e000 fffff880`00dba000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`00dba000 fffff880`00dc8000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`00dc8000 fffff880`00ded000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`00ded000 fffff880`00dfd000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00e5c000 fffff880`00e6c000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00e6c000 fffff880`00e86000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e86000 fffff880`00e8f000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00e8f000 fffff880`00eb9000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00eb9000 fffff880`00ec4000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`00ec4000 fffff880`00ecd000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`00ed0000 fffff880`00f74000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00f74000 fffff880`00f83000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00f83000 fffff880`00fb6000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00fb6000 fffff880`00fca000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`00fca000 fffff880`00ff4000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00ff4000 fffff880`00ffd000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`01000000 fffff880`0102f000   SCSIPORT SCSIPORT.SYS Tue Jul 14 03:01:04 2009 (4A5BCAC0)
fffff880`0102f000 fffff880`01086000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`01086000 fffff880`01090000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`01090000 fffff880`0109d000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`0109d000 fffff880`010b2000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`010b2000 fffff880`011d8000   sptd     sptd.sys     Sun Oct 11 23:55:14 2009 (4AD24632)
fffff880`011d8000 fffff880`011e1000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`011e1000 fffff880`011f6000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`011f6000 fffff880`011fd000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`01213000 fffff880`0121c000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`0121c000 fffff880`01223000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`01229000 fffff880`013cc000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013cc000 fffff880`013fc000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01400000 fffff880`0144c000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`0144c000 fffff880`01486000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`01486000 fffff880`014c0000   fvevol   fvevol.sys   Tue Jul 14 02:22:15 2009 (4A5BC1A7)
fffff880`014d5000 fffff880`01533000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`01533000 fffff880`0154d000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`0154d000 fffff880`015c0000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`015c0000 fffff880`015d1000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`015d1000 fffff880`015db000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`015db000 fffff880`015f1000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01600000 fffff880`0164a000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`0164a000 fffff880`0165a000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`0165a000 fffff880`01662000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`01667000 fffff880`01759000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`01759000 fffff880`017b9000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`017b9000 fffff880`017e4000   ksecpkg  ksecpkg.sys  Tue Jul 14 02:50:34 2009 (4A5BC84A)
fffff880`017e4000 fffff880`017f6000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`017f6000 fffff880`017ff000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`01802000 fffff880`019ff000   tcpip    tcpip.sys    Tue Jul 14 02:25:34 2009 (4A5BC26E)
fffff880`02400000 fffff880`0244f000   atksgt   atksgt.sys   Sun May 17 16:36:34 2009 (4A1012E2)
fffff880`02450000 fffff880`02506000   netr7364 netr7364.sys Fri Mar 13 05:13:08 2009 (49B9CF44)
fffff880`02506000 fffff880`02513000   vwifibus vwifibus.sys Tue Jul 14 03:07:21 2009 (4A5BCC39)
fffff880`02513000 fffff880`02520000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`02520000 fffff880`0252e000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`0252e000 fffff880`02551000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`02551000 fffff880`0258b000   aswMonFlt aswMonFlt.sys Tue Sep 07 17:47:32 2010 (4C865084)
fffff880`0258b000 fffff880`02594000   aswFsBlk aswFsBlk.SYS Tue Sep 07 17:47:09 2010 (4C86506D)
fffff880`02594000 fffff880`025b5000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`025b5000 fffff880`025ca000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`025ca000 fffff880`025dd000   ndisuio  ndisuio.sys  Tue Jul 14 03:09:25 2009 (4A5BCCB5)
fffff880`025dd000 fffff880`025f5000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`02c00000 fffff880`02c0f000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02c0f000 fffff880`02c2c000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02c2c000 fffff880`02c47000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`02c47000 fffff880`02c5b000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`02c5b000 fffff880`02c78000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02ca0000 fffff880`02cbe000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`02cbe000 fffff880`02ccb000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`02ccb000 fffff880`02cdb000   aswTdi   aswTdi.SYS   Tue Sep 07 17:52:27 2010 (4C8651AB)
fffff880`02cdb000 fffff880`02d65000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`02d65000 fffff880`02d6f000   aswRdr   aswRdr.SYS   Tue Sep 07 17:47:47 2010 (4C865093)
fffff880`02d6f000 fffff880`02db4000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02db4000 fffff880`02dbd000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02dbd000 fffff880`02de3000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`02de3000 fffff880`02df9000   vwififlt vwififlt.sys Tue Jul 14 03:07:22 2009 (4A5BCC3A)
fffff880`03e00000 fffff880`03e26000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`03e26000 fffff880`03e3b000   amdppm   amdppm.sys   Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`03e3b000 fffff880`03e91000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`03e91000 fffff880`03e9d000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`03ea0000 fffff880`03ef1000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`03ef1000 fffff880`03efd000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`03efd000 fffff880`03f08000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`03f08000 fffff880`03f17000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`03f17000 fffff880`03f9a000   csc      csc.sys      Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03f9a000 fffff880`03fb8000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`03fb8000 fffff880`03fc9000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03fc9000 fffff880`03fec000   aswSP    aswSP.SYS    Tue Sep 07 17:52:07 2010 (4C865197)
fffff880`0401e000 fffff880`04063000   ag7y3gjn ag7y3gjn.SYS Wed Jul 15 00:12:55 2009 (4A5CF4D7)
fffff880`04063000 fffff880`0406c000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`0406c000 fffff880`0407c000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`0407c000 fffff880`04092000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`04092000 fffff880`040b6000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`040b6000 fffff880`040c2000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`040c2000 fffff880`040f1000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`040f1000 fffff880`0410c000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`0410c000 fffff880`0412d000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`0412d000 fffff880`04147000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`04147000 fffff880`04154000   tap0901t tap0901t.sys Wed Sep 16 09:02:43 2009 (4AB07F83)
fffff880`04154000 fffff880`0415f000   rdpbus   rdpbus.sys   Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`0415f000 fffff880`0416e000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`0416e000 fffff880`0417d000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`0417d000 fffff880`0417e480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`0417f000 fffff880`041c2000   ks       ks.sys       Tue Jul 14 03:00:31 2009 (4A5BCA9F)
fffff880`041c2000 fffff880`041d4000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`04800000 fffff880`04832000   Rt64win7 Rt64win7.sys Thu Feb 26 11:04:13 2009 (49A65B0D)
fffff880`04838000 fffff880`04e78000   atikmdag atikmdag.sys Fri Aug 14 05:42:35 2009 (4A84CF1B)
fffff880`04e78000 fffff880`04f6c000   dxgkrnl  dxgkrnl.sys  Tue Jul 14 02:38:56 2009 (4A5BC590)
fffff880`04f6c000 fffff880`04fb2000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`04fb2000 fffff880`04fd6000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`04fd6000 fffff880`04fe1000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`04fe1000 fffff880`04ff2000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`04ff2000 fffff880`04fff000   fdc      fdc.sys      Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`05200000 fffff880`05253000   nwifi    nwifi.sys    Tue Jul 14 03:07:23 2009 (4A5BCC3B)
fffff880`05253000 fffff880`052ad000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`052ad000 fffff880`052b8000   flpydisk flpydisk.sys Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`052b8000 fffff880`052cd000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`052cd000 fffff880`052ed000   AtihdW76 AtihdW76.sys Thu Jul 15 15:46:49 2010 (4C3F0339)
fffff880`052ed000 fffff880`0532a000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`0532a000 fffff880`0534c000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`0534c000 fffff880`05351200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`05352000 fffff880`0535b000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`0535b000 fffff880`0536e000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`0536e000 fffff880`0538b000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`0538b000 fffff880`0538cf00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`0538d000 fffff880`05399000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`05399000 fffff880`053a3f80   ElanFltr ElanFltr.sys Wed May 23 12:22:06 2007 (465407BE)
fffff880`053a4000 fffff880`053b2000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`053b2000 fffff880`053cb000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`053cb000 fffff880`053d3080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`053d4000 fffff880`053e2000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`05c00000 fffff880`05de4c80   RTKVHD64 RTKVHD64.sys Mon Aug 31 13:19:33 2009 (4A9BA3B5)
fffff880`05de5000 fffff880`05df3000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`05df3000 fffff880`05dff000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`06000000 fffff880`0604d000   mrxsmb10 mrxsmb10.sys Tue Jul 14 02:24:08 2009 (4A5BC218)
fffff880`0604d000 fffff880`06070000   mrxsmb20 mrxsmb20.sys Tue Jul 14 02:24:05 2009 (4A5BC215)
fffff880`06070000 fffff880`06088000   adfs     adfs.SYS     Thu Jun 26 23:52:37 2008 (48640195)
fffff880`06088000 fffff880`06095000   lirsgt   lirsgt.sys   Sun May 17 16:06:57 2009 (4A100BF1)
fffff880`06096000 fffff880`0615e000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`0615e000 fffff880`0617c000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`0617c000 fffff880`06194000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`06194000 fffff880`061c0000   mrxsmb   mrxsmb.sys   Tue Jul 14 02:23:59 2009 (4A5BC20F)
fffff880`061c0000 fffff880`061cf000   npf      npf.sys      Tue Oct 20 21:00:19 2009 (4ADDFAB3)
fffff880`06600000 fffff880`06669000   srv2     srv2.sys     Tue Jul 14 02:25:02 2009 (4A5BC24E)
fffff880`066cc000 fffff880`06772000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`06772000 fffff880`0677d000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`0677d000 fffff880`067aa000   srvnet   srvnet.sys   Tue Jul 14 02:24:58 2009 (4A5BC24A)
fffff880`067aa000 fffff880`067bc000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`06a3f000 fffff880`06ad7000   srv      srv.sys      Tue Jul 14 02:25:11 2009 (4A5BC257)
fffff960`00090000 fffff960`0039f000   win32k   win32k.sys   Tue Jul 14 02:40:16 2009 (4A5BC5E0)
fffff960`005e0000 fffff960`005ea000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00670000 fffff960`00697000   cdd      cdd.dll      Tue Jul 14 04:25:40 2009 (4A5BDE94)
fffff960`00800000 fffff960`00861000   ATMFD    ATMFD.DLL    Tue Jul 14 02:38:13 2009 (4A5BC565)
Unloaded modules:
fffff880`06ad7000 fffff880`06b48000   spsys.sys
    Checksum:  00000000
fffff880`015f1000 fffff880`015ff000   crashdmp.sys
    Checksum:  00000000
fffff880`014c0000 fffff880`014cc000   dump_ataport
    Checksum:  00000000
fffff880`014cc000 fffff880`014d5000   dump_atapi.s
    Checksum:  00000000
fffff880`01200000 fffff880`01213000   dump_dumpfve
    Checksum:  00000000
thank you very much cybercore, I've get rid of the elanfltr.sys, still using 9.11 catalyst because the newest (10.9) keeps crashing. Thank you for reminding me to update my soundcard and wireless driver, and how the hell that tages thing is still there.. strange.. I remember I've uninstalled it long ago.
Anyway thank you for your help, I will update those drivers and keep reporting to this thread :)
Your keyboard drivers are too old - 2007, Realtek - early 2009, ATI Catalyst should be newer too.
Since your crash took place while dwm.exe was running, and that Catalyst 9.11 is a bit old for Windows 7, I recommend:
1. Control Panel -> Uninstall Catalyst completely, reboot
2. Get rid of ATI tracks with Driver Sweeper Guru3D - Driver Sweeper, reboot
3. Install Catalyst 2010 version, 10.3 or 10.9, try 10.9 again, should work now
how the hell that tages thing is still there - this is exactly what your .dmp shows, it's still there C:\Windows\system32\drivers. It's a part of a software that I'm not familiar with, if you have uninstalled that soft, you may want to rename those drivers to .old. But it's always the right method to uninstall thro Control Panel.
Update what you can, the more of those drivers you can update the better. If after the updates you get more crash dumps, attach them. If drivers won't fix it, then test the hardware :
Video card FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
Memory Memtest86+ - Advanced Memory Diagnostic Tool
HDD HDDScan
okay.. i got it again..
after google chrome crashed, the BSOD says page_fault_in_nonpaged_area
and this is the dmp file
  • 092910-40794-01.rar
092910-40794-01.dmp
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. Typically the address is just plain bad or it is pointing at freed memory.
PROCESS_NAME: System
Stack: nt!
FAILURE_BUCKET_ID: X64_0x50_nt!MiMapPageInHyperSpaceWorker+1b
Probably caused by : memory_corruption ( nt!MiMapPageInHyperSpaceWorker+1b )
Run memtest OVERNIGHT
Try to update these drivers too:
Realtek
atikmdag.sys Wed Nov 04 18:11:41 2009
ATI Video Driver
Ralink corp. | Home
Also, replace your Avast with Microsoft Security Essentials.
Loading Dump File [F:\a\Minidump\092910-40794-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02e01000 PsLoadedModuleList = 0xfffff800`0303ee50
System Uptime: 0 days 0:36:27.738
BugCheck 50, {fffffa7fffffffea, 0, fffff80002ea86fb, 7}
3: kd> !analyze -v
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
Arguments:
Arg1: fffffa7fffffffea, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80002ea86fb, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000007, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800030a90e0
 fffffa7fffffffea
FAULTING_IP:
fffff800`02ea86fb 458a481a        mov     r9b,byte ptr [r8+1Ah]
MM_INTERNAL_CODE:  7
BUGCHECK_STR:  0x50
CURRENT_IRQL:  0
TRAP_FRAME:  fffff880098d1820 -- (.trap 0xfffff880098d1820)
rax=0000058000000000 rbx=0000000000000000 rcx=ffffffffffffffff
rdx=fffff880098d1a40 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002ea86fb rsp=fffff880098d19b8 rbp=0000058000000000
 r8=fffffa7fffffffd0  r9=0000000000000001 r10=0000000000000002
r11=fffff880098d1990 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na pe nc
nt!MiMapPageInHyperSpaceWorker+0x1b:
fffff800`02ea86fb 458a481a        mov     r9b,byte ptr [r8+1Ah] ds:fffffa7f`ffffffea=??
LAST_CONTROL_TRANSFER:  from fffff80002ef0b19 to fffff80002e72f00
STACK_TEXT:
fffff880`098d16b8 fffff800`02ef0b19 : 00000000`00000050 fffffa7f`ffffffea 00000000`00000000 fffff880`098d1820 : nt!KeBugCheckEx
fffff880`098d16c0 fffff800`02e70fee : 00000000`00000000 ffffffff`ffffffff 00000000`00000000 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x40edb
fffff880`098d1820 fffff800`02ea86fb : fffff800`02ed59a9 ffffffff`ffffffff 00000000`00002329 fffffa80`03d35060 : nt!KiPageFault+0x16e
fffff880`098d19b8 fffff800`02ed59a9 : ffffffff`ffffffff 00000000`00002329 fffffa80`03d35060 fffffa80`06bfcd90 : nt!MiMapPageInHyperSpaceWorker+0x1b
fffff880`098d19c0 fffff800`0312f542 : fffff780`00000000 00000000`00000000 00000000`00000001 fffffa80`0396ec10 : nt! ?? ::FNODOBFM::`string'+0x17216
fffff880`098d1a40 fffff800`0312f207 : fffffa80`03d35060 00000000`00000008 fffffa80`00000000 fffffa80`00000003 : nt!MmDeleteProcessAddressSpace+0x42
fffff880`098d1a80 fffff800`02e780b4 : 00000000`00000000 fffffa80`03d35060 fffffa80`03d35030 fffff800`031ff915 : nt!PspProcessDelete+0x177
fffff880`098d1ae0 fffff800`02f77439 : fffffa80`03d35060 fffffa80`0402d000 fffffa80`0402da00 fffffa80`0402d9f8 : nt!ObfDereferenceObject+0xd4
fffff880`098d1b40 fffff800`032c31fe : fffffa80`00000469 fffffa80`03f93000 fffffa80`03d35060 fffffa80`0402da00 : nt!MmFreeAccessPfnBuffer+0x29
fffff880`098d1b70 fffff800`032e4820 : fffffa80`06b8a701 00000000`00000080 fffffa80`039739e0 fffff800`02fff568 : nt!PfpFlushBuffers+0x23e
fffff880`098d1c10 fffff800`03116166 : ffffffff`ff676980 fffffa80`06b8a760 fffff880`098d1db0 fffffa80`06b8a760 : nt!PfTLoggingWorker+0xe0
fffff880`098d1d40 fffff800`02e51486 : fffff880`009e9180 fffffa80`06b8a760 fffff880`009f3fc0 fffff880`0122d534 : nt!PspSystemThreadStartup+0x5a
fffff880`098d1d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MiMapPageInHyperSpaceWorker+1b
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc600
IMAGE_NAME:  memory_corruption
fffff800`00ba6000 fffff800`00bb0000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`02e01000 fffff800`033de000   nt       ntkrnlmp.exe Tue Jul 14 02:40:48 2009 (4A5BC600)
fffff800`033de000 fffff800`03427000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff880`00c35000 fffff880`00c42000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00c42000 fffff880`00c56000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00c56000 fffff880`00cb4000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00cb4000 fffff880`00d74000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00d74000 fffff880`00d8e000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00d8e000 fffff880`00d97000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00d97000 fffff880`00dc1000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00dc1000 fffff880`00dcc000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`00dcc000 fffff880`00de4000   adfs     adfs.SYS     Thu Jun 26 23:52:37 2008 (48640195)
fffff880`00e04000 fffff880`00ea8000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00ea8000 fffff880`00eb7000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00eb7000 fffff880`00f0e000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`00f0e000 fffff880`00f17000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f17000 fffff880`00f21000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`00f21000 fffff880`00f2e000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`00f2e000 fffff880`00f61000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f61000 fffff880`00f76000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00f76000 fffff880`00f8b000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00f8b000 fffff880`00fe7000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00fe7000 fffff880`00fee000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`00fee000 fffff880`00ffe000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`01086000 fffff880`01095000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`01095000 fffff880`010a4000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`010a6000 fffff880`010f2000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`010f2000 fffff880`01106000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`01106000 fffff880`01164000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`01164000 fffff880`011d7000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`011d7000 fffff880`011f8000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`01200000 fffff880`0121a000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`0121f000 fffff880`013c2000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013c2000 fffff880`013dc000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`013dc000 fffff880`013ed000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`013ed000 fffff880`013f7000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`013f7000 fffff880`01400000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`01400000 fffff880`01410000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`01410000 fffff880`01418000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`01418000 fffff880`0142a000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`01432000 fffff880`01524000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`01524000 fffff880`01584000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`01584000 fffff880`015af000   ksecpkg  ksecpkg.sys  Tue Jul 14 02:50:34 2009 (4A5BC84A)
fffff880`015af000 fffff880`015f9000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Tue Jul 14 02:25:34 2009 (4A5BC26E)
fffff880`01800000 fffff880`0181b000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`0181e000 fffff880`01858000   fvevol   fvevol.sys   Tue Jul 14 02:22:15 2009 (4A5BC1A7)
fffff880`01858000 fffff880`0186e000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`0186e000 fffff880`0189e000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`0189e000 fffff880`018c1000   mrxsmb20 mrxsmb20.sys Tue Jul 14 02:24:05 2009 (4A5BC215)
fffff880`018d4000 fffff880`018fe000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`018fe000 fffff880`01907000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`01907000 fffff880`0190e000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`0190e000 fffff880`0191c000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`0191c000 fffff880`01941000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`01941000 fffff880`01951000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`01951000 fffff880`0195a000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`0195a000 fffff880`01963000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`01963000 fffff880`0196c000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`0196c000 fffff880`01977000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`01977000 fffff880`01988000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01988000 fffff880`019a6000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`019a6000 fffff880`019b3000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`019b3000 fffff880`019c3000   aswTdi   aswTdi.SYS   Tue Sep 07 17:52:27 2010 (4C8651AB)
fffff880`019c3000 fffff880`019f2000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`02c00000 fffff880`02c24000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`02c24000 fffff880`02c30000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`02c30000 fffff880`02c3d000   tap0901t tap0901t.sys Wed Sep 16 09:02:43 2009 (4AB07F83)
fffff880`02c46000 fffff880`02cd0000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`02cd0000 fffff880`02cda000   aswRdr   aswRdr.SYS   Tue Sep 07 17:47:47 2010 (4C865093)
fffff880`02cda000 fffff880`02d1f000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02d1f000 fffff880`02d28000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02d28000 fffff880`02d4e000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`02d4e000 fffff880`02d64000   vwififlt vwififlt.sys Tue Jul 14 03:07:22 2009 (4A5BCC3A)
fffff880`02d64000 fffff880`02d73000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02d73000 fffff880`02d90000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02d90000 fffff880`02dab000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`02dab000 fffff880`02dbf000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`02dbf000 fffff880`02dd9000   SCDEmu   SCDEmu.SYS   Mon Nov 09 05:27:29 2009 (4AF78C21)
fffff880`02dd9000 fffff880`02df6000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`03a01000 fffff880`03a54000   nwifi    nwifi.sys    Tue Jul 14 03:07:23 2009 (4A5BCC3B)
fffff880`03a54000 fffff880`03a67000   ndisuio  ndisuio.sys  Tue Jul 14 03:09:25 2009 (4A5BCCB5)
fffff880`03a67000 fffff880`03a7f000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`03a7f000 fffff880`03b47000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`03b47000 fffff880`03b65000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`03b65000 fffff880`03b7d000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`03b7d000 fffff880`03ba9000   mrxsmb   mrxsmb.sys   Tue Jul 14 02:23:59 2009 (4A5BC20F)
fffff880`03ba9000 fffff880`03bf6000   mrxsmb10 mrxsmb10.sys Tue Jul 14 02:24:08 2009 (4A5BC218)
fffff880`03e91000 fffff880`03ea7000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`03ea7000 fffff880`03ea8480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`03ea9000 fffff880`03efa000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`03efa000 fffff880`03f06000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`03f06000 fffff880`03f11000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`03f11000 fffff880`03f20000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`03f20000 fffff880`03fa3000   csc      csc.sys      Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03fa3000 fffff880`03fc1000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`03fc1000 fffff880`03fd2000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03fd2000 fffff880`03ff5000   aswSP    aswSP.SYS    Tue Sep 07 17:52:07 2010 (4C865197)
fffff880`03ff5000 fffff880`04000000   rdpbus   rdpbus.sys   Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`04200000 fffff880`0423a000   aswMonFlt aswMonFlt.sys Tue Sep 07 17:47:32 2010 (4C865084)
fffff880`0423a000 fffff880`0425b000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`0425f000 fffff880`042a2000   ks       ks.sys       Tue Jul 14 03:00:31 2009 (4A5BCA9F)
fffff880`042a2000 fffff880`042b4000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`042b4000 fffff880`0430e000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`0430e000 fffff880`04319000   flpydisk flpydisk.sys Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`04319000 fffff880`0432e000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`0432e000 fffff880`0434f000   AtiHdmi  AtiHdmi.sys  Wed Sep 30 16:54:46 2009 (4AC36326)
fffff880`0434f000 fffff880`0438c000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`0438c000 fffff880`043ae000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`043ae000 fffff880`043b3200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`043b4000 fffff880`043d7000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`043d7000 fffff880`043ec000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`04800000 fffff880`04846000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`04846000 fffff880`0486a000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`0486a000 fffff880`0489c000   Rt64win7 Rt64win7.sys Thu Feb 26 11:04:13 2009 (49A65B0D)
fffff880`0489c000 fffff880`048a7000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`048a7000 fffff880`048b8000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`048b8000 fffff880`048c5000   fdc      fdc.sys      Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`048c5000 fffff880`048d1000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`048d1000 fffff880`048da000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`048da000 fffff880`04efc000   atikmdag atikmdag.sys Wed Nov 04 18:11:41 2009 (4AF1A7BD)
fffff880`04efc000 fffff880`04ff0000   dxgkrnl  dxgkrnl.sys  Tue Jul 14 02:38:56 2009 (4A5BC590)
fffff880`04ff0000 fffff880`05000000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`05c00000 fffff880`05cb6000   netr7364 netr7364.sys Fri Mar 13 05:13:08 2009 (49B9CF44)
fffff880`05cb9000 fffff880`05f14d80   RTKVHD64 RTKVHD64.sys Fri Sep 03 11:02:27 2010 (4C80AB93)
fffff880`05f15000 fffff880`05f23000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`05f23000 fffff880`05f2f000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`05f2f000 fffff880`05f38000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`05f38000 fffff880`05f4b000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`05f4b000 fffff880`05f57000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`05f57000 fffff880`05f74000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`05f74000 fffff880`05f75f00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`05f76000 fffff880`05f81580   ElanFltr ElanFltr.sys Wed May 19 10:24:25 2010 (4BF39229)
fffff880`05f82000 fffff880`05f90000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`05f90000 fffff880`05fa9000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`05fa9000 fffff880`05fb1080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`05fb2000 fffff880`05fc0000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`05fc0000 fffff880`05fcd000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`05fcd000 fffff880`05fda000   vwifibus vwifibus.sys Tue Jul 14 03:07:21 2009 (4A5BCC39)
fffff880`05fda000 fffff880`05fe8000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`05fe8000 fffff880`05ff1000   aswFsBlk aswFsBlk.SYS Tue Sep 07 17:47:09 2010 (4C86506D)
fffff880`07c00000 fffff880`07c69000   srv2     srv2.sys     Tue Jul 14 02:25:02 2009 (4A5BC24E)
fffff880`07c73000 fffff880`07cc2000   atksgt   atksgt.sys   Sun May 17 16:36:34 2009 (4A1012E2)
fffff880`07cc2000 fffff880`07ccf000   lirsgt   lirsgt.sys   Sun May 17 16:06:57 2009 (4A100BF1)
fffff880`07ccf000 fffff880`07cde000   npf      npf.sys      Tue Oct 20 21:00:19 2009 (4ADDFAB3)
fffff880`07cde000 fffff880`07d84000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`07d84000 fffff880`07d8f000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`07d8f000 fffff880`07dbc000   srvnet   srvnet.sys   Tue Jul 14 02:24:58 2009 (4A5BC24A)
fffff880`07dbc000 fffff880`07dce000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`08431000 fffff880`084c9000   srv      srv.sys      Tue Jul 14 02:25:11 2009 (4A5BC257)
fffff960`000f0000 fffff960`003ff000   win32k   win32k.sys   unavailable (00000000)
fffff960`00480000 fffff960`0048a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00630000 fffff960`00657000   cdd      cdd.dll      unavailable (00000000)
fffff960`00870000 fffff960`008d1000   ATMFD    ATMFD.DLL    unavailable (00000000)
Unloaded modules:
fffff880`084c9000 fffff880`0853a000   spsys.sys
    Checksum:  00000000
fffff880`0189e000 fffff880`018ac000   crashdmp.sys
    Checksum:  00000000
fffff880`018ac000 fffff880`018b8000   dump_ataport
    Checksum:  00000000
fffff880`018b8000 fffff880`018c1000   dump_atapi.s
    Checksum:  00000000
fffff880`018c1000 fffff880`018d4000   dump_dumpfve
    Checksum:  00000000
I know the culprit now. It's my video card memory. I ran VMT and it ended up with a Memory_Management BSOD. Thank you for your time cybercore.
Problem solved :)
