Windows 7 NEED HELP WITH BSOD , not sure what caused recently started crashing while gaming
sanityx
Please help me! I got this recently while playing game. I have attached the relevant files according to the rules.
  • W7F_02-06-2013.rar
  • SPD INFO.txt
sanityx
This was from the event viewer.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2013-06-01T19:00:39.254811900Z" />
<EventRecordID>6512</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Ethan-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">59</Data>
<Data Name="BugcheckParameter1">0xc0000005</Data>
<Data Name="BugcheckParameter2">0xfffff80002def0cd</Data>
<Data Name="BugcheckParameter3">0xfffff8800392d140</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
usasma
Fantastic Member
There are enough signs here that that I have to wonder about this installation. Should this be a pirated copy of Windows, please be aware that we may not be able to fix it (as the hacks that were done to activate it will cause the OS to behave differently than we expect it to). If that's the case, our efforts to help may just waste your time. Secondly, the forum rules prohibit assisting with pirated software - so the topic would be closed if that is the case.
SP1 isn't installed, please do the following:
Installing Windows 7 Service Pack 1
1. Visit the PC manufacturer's website and update ALL drivers. DO NOT use Windows Update or the "Update drivers" function of Device Manager.
2. Check Device Manager for any unknown/disabled devices - if there are unknown/disabled devices, fix them with the latest drivers from the device manufacturer's website (not the PC Manufacturer)
3. Visit Windows Update and get all updates (may take repeated visits)
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1: Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1 from the Microsoft Download Center
5. Visit Windows Update and get any other available updates. May take repeated visits, but keep it up until you get several "Windows is updated" results.
If you're having difficulties with installing a Service Pack, please use the SURTool from this link: What is the System Update Readiness Tool?
Also, check out this troubleshooting link from Microsoft: Troubleshoot problems installing Service Pack 1 (SP1) for Windows 7 and Windows Server 2008 R2
I have had limited success in installing updates/Service Packs when using a "clean boot". I suspect that I'm just bypassing the problem - and that it can come back to bite me in the butt later on.
FYI - most systems have 160 or more updates after installing SP1
Your Death Adder drivers date from 2007. Those are known to have BSOD issues with Windows systems. Please update them to the latest, Win7 compatible version.
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Microsoft (R) Windows Debugger Version 6.2.9200.16384 AMD64
Loading Dump File [C:\Users\Owner\Downloads\W7F_02-06-2013\W7F_02-06-2013\060213-18501-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols;srv*c:\SymcachePublic*http://ctxsym.citrix.com/symbolsad/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.17273.amd64fre.win7_gdr.130318-1532
Machine Name:
Kernel base = 0xfffff800`02c4c000 PsLoadedModuleList = 0xfffff800`02e88e70
Debug session time: Sat Jun  1 15:00:00.125 2013 (UTC - 4:00)
System Uptime: 0 days 1:29:30.607
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 3B, {c0000005, fffff80002def0cd, fffff8800392d140, 0}
Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+241 )
Followup: Pool_corruption
2: kd> !analyze -v; lmtsmn; !sysinfo cpuspeed; !sysinfo SMBIOS
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002def0cd, Address of the instruction which caused the bugcheck
Arg3: fffff8800392d140, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`02def0cd 4c3910          cmp     qword ptr [rax],r10
CONTEXT:  fffff8800392d140 -- (.cxr 0xfffff8800392d140)
rax=bffff8a010377530 rbx=0000000000000004 rcx=fffffa8003adfbc0
rdx=fffff8a001ec67e0 rsi=0000000000000000 rdi=fffff8a00b3ac790
rip=fffff80002def0cd rsp=fffff8800392db10 rbp=0000000000000000
 r8=fffff8a00a5e1690  r9=fffff8a001ec69f0 r10=fffff8a001ec6a00
r11=0000000000000001 r12=fffffa8003adf500 r13=0000000000000000
r14=000000000000000f r15=0000000000000001
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010246
nt!ExDeferredFreePool+0x241:
fffff800`02def0cd 4c3910          cmp     qword ptr [rax],r10 ds:002b:bffff8a0`10377530=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
PROCESS_NAME:  explorer.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002df04c1 to fffff80002def0cd
STACK_TEXT:
fffff880`0392db10 fffff800`02df04c1 : 00000000`0000000f fffff8a0`0b1f77f0 00000000`000100db fffff880`0392e100 : nt!ExDeferredFreePool+0x241
fffff880`0392dba0 fffff880`03fdc2b9 : 00000000`0000000f 00000000`00000000 00000000`63644356 00000000`00000596 : nt!ExFreePoolWithTag+0x411
fffff880`0392dc50 fffff880`03fd0c8f : 00000000`00000000 fffff800`02cd7d02 00000000`00000000 fffff900`c302b000 : dxgkrnl!CCD_BTL::RetrieveConnectivitySetId+0x191
fffff880`0392dcd0 fffff880`03f80567 : 00000000`0000000f 00000000`00000000 00000000`00000000 fffff960`001fc569 : dxgkrnl!CCD_TOPOLOGY::RetrievePersisted+0x73
fffff880`0392df50 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : dxgkrnl!DxgkGetPathsModality+0x337
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ExDeferredFreePool+241
FOLLOWUP_NAME:  Pool_corruption
IMAGE_NAME:  Pool_Corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: Pool_Corruption
STACK_COMMAND:  .cxr 0xfffff8800392d140 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!ExDeferredFreePool+241
fffff880`040a1000 fffff880`040df000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f9e000 fffff880`00ff5000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cda000 fffff880`02d63000   afd      afd.sys      Tue Dec 27 22:59:08 2011 (4EFA940C)
fffff880`0414c000 fffff880`04162000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`010a1000 fffff880`010ac000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00c8d000 fffff880`00c96000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01077000 fffff880`010a1000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`008b0000 fffff960`00911000   ATMFD    ATMFD.DLL    Sun Dec 16 09:40:45 2012 (50CDDD6D)
fffff880`00dba000 fffff880`00dc6000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`01833000 fffff880`0183a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03ebd000 fffff880`03ece000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02b3c000 fffff880`02b5a000   bowser   bowser.sys   Wed Feb 23 00:15:06 2011 (4D6497DA)
fffff960`007d0000 fffff960`007f7000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`01800000 fffff880`0182a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00e0c000 fffff880`00ecc000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01985000 fffff880`019b5000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cfe000 fffff880`00d5c000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01072000   cng      cng.sys      Fri Jun 01 23:19:52 2012 (4FC98658)
fffff880`00db1000 fffff880`00dba000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0413c000 fffff880`0414c000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`044c1000 fffff880`044cf000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03e1c000 fffff880`03e9f000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`045fc000 fffff880`045ff180   dadder   dadder.sys   Thu Aug 02 05:33:03 2007 (46B1A4CF)
fffff880`03e9f000 fffff880`03ebd000   dfsc     dfsc.sys     Tue Apr 26 22:57:39 2011 (4DB78623)
fffff880`02cb4000 fffff880`02cc3000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0196f000 fffff880`01985000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0443d000 fffff880`0445f000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`045d4000 fffff880`045dd000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`044cf000 fffff880`044db000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`045dd000 fffff880`045f0000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`045f0000 fffff880`045fc000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03f0a000 fffff880`03ffe000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`05360000 fffff880`053a6000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`010f8000 fffff880`0110c000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010ac000 fffff880`010f8000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`013cf000 fffff880`013d9000   Fs_Rec   Fs_Rec.sys   Wed Feb 29 22:54:36 2012 (4F4EF2FC)
fffff880`01935000 fffff880`0196f000   fvevol   fvevol.sys   Wed Jan 23 22:02:05 2013 (5100A42D)
fffff880`011a2000 fffff880`011eb000   fwpkclnt fwpkclnt.sys Thu Jan 03 22:00:34 2013 (50E645D2)
fffff880`04135000 fffff880`0413bc00   GEARAspiWDM GEARAspiWDM.sys Thu May 03 15:56:17 2012 (4FA2E2E1)
fffff800`02c03000 fffff800`02c4c000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`053a6000 fffff880`053ca000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04465000 fffff880`044c1000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`053ca000 fffff880`053db000   HECIx64  HECIx64.sys  Thu Sep 17 15:54:16 2009 (4AB293E8)
fffff880`03e00000 fffff880`03e19000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`053ec000 fffff880`053f4080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`04870000 fffff880`0487e000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`02a74000 fffff880`02b3c000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0192c000 fffff880`01935000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`040df000 fffff880`040fd000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`03ef4000 fffff880`03f0a000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`040fd000 fffff880`0410c000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bc7000 fffff800`00bd1000   kdcom    kdcom.dll    Sat Feb 05 07:21:45 2011 (4D4D40D9)
fffff880`044dd000 fffff880`04520000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013a4000 fffff880`013be000   ksecdd   ksecdd.sys   Fri Jun 01 22:47:00 2012 (4FC97EA4)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Jun 01 23:20:48 2012 (4FC98690)
fffff880`0445f000 fffff880`04464200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`015ea000 fffff880`015ff000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`019b5000 fffff880`019d8000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ca6000 fffff880`00cea000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`02de6000 fffff880`02df4000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04861000 fffff880`04870000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`02cc3000 fffff880`02cd0000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c73000 fffff880`00c8d000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0110c000 fffff880`01144000   MpFilter MpFilter.sys Wed Oct 31 18:43:06 2012 (5091A97A)
fffff880`02b5a000 fffff880`02b72000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02b72000 fffff880`02b9f000   mrxsmb   mrxsmb.sys   Tue May 03 22:51:06 2011 (4DC0BF1A)
fffff880`02b9f000 fffff880`02bed000   mrxsmb10 mrxsmb10.sys Fri Jul 08 22:44:55 2011 (4E17C0A7)
fffff880`02a00000 fffff880`02a23000   mrxsmb20 mrxsmb20.sys Tue May 03 22:51:05 2011 (4DC0BF19)
fffff880`0149b000 fffff880`014a6000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e00000 fffff880`00e0a000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01144000 fffff880`011a2000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02ca9000 fffff880`02cb4000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0191a000 fffff880`0192c000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014cd000 fffff880`015bf000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04186000 fffff880`04192000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04192000 fffff880`041c1000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0458c000 fffff880`045a1000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02dd7000 fffff880`02de6000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d63000 fffff880`02da8000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`02a23000 fffff880`02a44000   NisDrvWFP NisDrvWFP.sys Wed Oct 31 18:43:30 2012 (5091A992)
fffff880`014a6000 fffff880`014b7000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c9d000 fffff880`02ca9000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c4c000 fffff800`03226000   nt       ntkrnlmp.exe Mon Mar 18 23:32:06 2013 (5147DC36)
fffff880`01203000 fffff880`013a4000   Ntfs     Ntfs.sys     Fri Apr 12 08:03:39 2013 (5167F81B)
fffff880`0182a000 fffff880`01833000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`045a1000 fffff880`045d4000   nvhda64v nvhda64v.sys Mon Feb 25 00:27:35 2013 (512AF647)
fffff880`0487f000 fffff880`05360000   nvlddmkm nvlddmkm.sys Sun May 12 15:09:45 2013 (518FE8F9)
fffff880`02db1000 fffff880`02dd7000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`04118000 fffff880`04135000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00d9c000 fffff880`00db1000   partmgr  partmgr.sys  Sat Mar 17 01:12:46 2012 (4F641D4E)
fffff880`00d5c000 fffff880`00d8f000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00c5c000 fffff880`00c63000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00c63000 fffff880`00c73000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013be000 fffff880`013cf000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07ca4000 fffff880`07d4a000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04400000 fffff880`0443d000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cea000 fffff880`00cfe000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04162000 fffff880`04186000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`041c1000 fffff880`041dc000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`041dc000 fffff880`041fd000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04000000 fffff880`0401a000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c4c000 fffff880`02c9d000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`04856000 fffff880`04861000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`0187d000 fffff880`01886000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019eb000 fffff880`019f4000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019f4000 fffff880`019fd000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`018e0000 fffff880`0191a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`013d9000 fffff880`013f1000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0401c000 fffff880`040a1000   Rt64win7 Rt64win7.sys Fri Jun 10 02:33:15 2011 (4DF1BAAB)
fffff880`07d4a000 fffff880`07d55000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0410c000 fffff880`04118000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02c00000 fffff880`02c1d000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`018d8000 fffff880`018e0000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`07c00000 fffff880`07c95000   srv      srv.sys      Thu Apr 28 23:13:05 2011 (4DBA2CC1)
fffff880`07d94000 fffff880`07dfb000   srv2     srv2.sys     Thu Apr 28 23:12:51 2011 (4DBA2CB3)
fffff880`07d55000 fffff880`07d82000   srvnet   srvnet.sys   Thu Apr 28 23:12:35 2011 (4DBA2CA3)
fffff880`0401a000 fffff880`0401b480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Thu Jan 03 22:03:34 2013 (50E64686)
fffff880`07d82000 fffff880`07d94000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`015dd000 fffff880`015ea000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`015bf000 fffff880`015dd000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02c38000 fffff880`02c4c000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00500000 fffff960`0050a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03ece000 fffff880`03ef4000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04520000 fffff880`04532000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`044db000 fffff880`044dcf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`053db000 fffff880`053ec000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04532000 fffff880`0458c000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04800000 fffff880`04856000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00d8f000 fffff880`00d9c000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0183a000 fffff880`01848000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01848000 fffff880`0186d000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0148b000 fffff880`0149b000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00dc6000 fffff880`00ddb000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0188c000 fffff880`018d8000   volsnap  volsnap.sys  Thu Sep 06 10:55:02 2012 (5048B946)
fffff880`02c1d000 fffff880`02c38000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`0186d000 fffff880`0187d000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ecc000 fffff880`00f8e000   Wdf01000 Wdf01000.sys Wed Jul 25 22:25:13 2012 (5010AA89)
fffff880`00f8e000 fffff880`00f9e000   WDFLDR   WDFLDR.SYS   Wed Jul 25 22:29:04 2012 (5010AB70)
fffff880`02da8000 fffff880`02db1000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00070000 fffff960`00386000   win32k   win32k.sys   Thu Feb 28 22:31:58 2013 (5130212E)
fffff880`00ff5000 fffff880`00ffe000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
Unloaded modules:
fffff880`07e57000 fffff880`07ec8000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`019b5000 fffff880`019c3000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019c3000 fffff880`019cf000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`019cf000 fffff880`019d8000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`019d8000 fffff880`019eb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
CPUID:        "Intel(R) Core(TM) i3 CPU         560  @ 3.33GHz"
MaxSpeed:     3330
CurrentSpeed: 3341
[SMBIOS Data Tables v2.6]
[DMI Version - 0]
[2.0 Calling Convention - No]
[Table Size - 2346 bytes]
[BIOS Information (Type 0) - Length 24 - Handle 0000h]
  Vendor                        American Megatrends Inc.
  BIOS Version                  V1.2
  BIOS Starting Address Segment f000
  BIOS Release Date             02/05/2010
  BIOS ROM Size                 200000
  BIOS Characteristics
       04: - ISA Supported
       07: - PCI Supported
       09: - Plug and Play Supported
       11: - Upgradeable FLASH BIOS
       12: - BIOS Shadowing Supported
       14: - ESCD Supported
       15: - CD-Boot Supported
       16: - Selectable Boot Supported
       17: - BIOS ROM Socketed
       19: - EDD Supported
       23: - 1.2MB Floppy Supported
       24: - 720KB Floppy Supported
       25: - 2.88MB Floppy Supported
       26: - Print Screen Device Supported
       27: - Keyboard Services Supported
       28: - Serial Services Supported
       29: - Printer Services Supported
       30: - CGA/Mono Services Supported
       32: - BIOS Vendor Reserved
  BIOS Characteristic Extensions
       00: - ACPI Supported
       01: - USB Legacy Supported
       04: - LS120-Boot Supported
       05: - ATAPI ZIP-Boot Supported
       08: - BIOS Boot Specification Supported
       10: - Specification Reserved
  BIOS Major Revision           8
  BIOS Minor Revision           15
  EC Firmware Major Revision    255
  EC Firmware Minor Revision    255
[System Information (Type 1) - Length 27 - Handle 0001h]
  Manufacturer                  MSI
  Product Name                  MS-7637
  Version                       1.0
  Serial Number
  UUID                          00000000-0000-0000-0000-000000000000
  Wakeup Type                   Power Switch
  SKUNumber                     To Be Filled By O.E.M.
  Family                        To Be Filled By O.E.M.
[BaseBoard Information (Type 2) - Length 15 - Handle 0002h]
  Manufacturer                  MSI
  Product                       H55-GD65 (MS-7637)
  Version                       1.0
  Serial Number
  Asset Tag
  Feature Flags                 09h
       -510648864: - (null)
       -510648816: - (null)
  Location                      To Be Filled By O.E.M.
  Chassis Handle                0003h
  Board Type                    0ah - Processor/Memory Module
  Number of Child Handles       0
[System Enclosure (Type 3) - Length 21 - Handle 0003h]
  Manufacturer                  MSI
  Chassis Type                  Desktop
  Version                       1.0
  Serial Number
  Asset Tag Number
  Bootup State                  Safe
  Power Supply State            Safe
  Thermal State                 Safe
  Security Status               None
  OEM Defined                   0
  Height                        0U
  Number of Power Cords         1
  Number of Contained Elements  0
  Contained Element Size        0
[Processor Information (Type 4) - Length 42 - Handle 0004h]
  Socket Designation            CPU1
  Processor Type                Central Processor
  Processor Family              c6h - Specification Reserved
  Processor Manufacturer        Intel
  Processor ID                  55060200fffbebbf
  Processor Version             Intel(R) Core(TM) i3 CPU         560  @ 3.33GHz
  Processor Voltage             00h -
  External Clock                133MHz
  Max Speed                     3333MHz
  Current Speed                 2933MHz
  Status                        Enabled Populated
  Processor Upgrade             Other
  L1 Cache Handle               0005h
  L2 Cache Handle               0006h
  L3 Cache Handle               0007h
  Serial Number
  Asset Tag Number
  Part Number                   To Be Filled By O.E.M.
[Cache Information (Type 7) - Length 19 - Handle 0005h]
  Socket Designation            L1-Cache
  Cache Configuration           0080h - WT Enabled Int NonSocketed L1
  Maximum Cache Size            0080h - 128K
  Installed Size                0080h - 128K
  Supported SRAM Type           0001h - Other
  Current SRAM Type             0001h - Other
  Cache Speed                   0ns
  Error Correction Type         ParitySingle-Bit ECC
  System Cache Type             Instruction
  Associativity                 4-way Set-Associative
[Cache Information (Type 7) - Length 19 - Handle 0006h]
  Socket Designation            L2-Cache
  Cache Configuration           0081h - WT Enabled Int NonSocketed L2
  Maximum Cache Size            0200h - 512K
  Installed Size                0200h - 512K
  Cache Speed                   0ns
  Error Correction Type         Multi-Bit ECC
  System Cache Type             Unified
  Associativity                 8-way Set-Associative
[Cache Information (Type 7) - Length 19 - Handle 0007h]
  Socket Designation            L3-Cache
  Cache Configuration           0182h - WB Enabled Int NonSocketed L3
  Maximum Cache Size            1000h - 4096K
  Installed Size                1000h - 4096K
  Cache Speed                   0ns
  Associativity                 16-way Set-Associative
[Memory Controller Information (Type 5) - Length 24 - Handle 0008h]
  Error Detecting Method        06h - 64-bit ECC
  Error Correcting Capability   04h - None
  Supported Interleave          03h - One Way Interleave
  Current Interleave            03h - One Way Interleave
  Maximum Memory Module Size    0dh - 8192MB
  Supported Speeds              0001h - Other
  Supported Memory Types        0500h - DIMM SDRAM
  Memory Module Voltage         3.3V
  Number of Memory Slots        4
  Memory Slot Handle            0009h
  Memory Slot Handle            000ah
  Memory Slot Handle            000bh
  Memory Slot Handle            000ch
  Enabled Err Correcting Caps   04h - None
[Memory Module Information (Type 6) - Length 12 - Handle 0009h]
  Socket Designation            DIMM1
  Bank Connections              01h - 1 0
  Current Speed                 1ns
  Current Memory Type           0500h - DIMM SDRAM
  Installed Size                8bh - 2048 [double bank]
  Enabled Size                  8bh - 2048 [double bank]
  Error Status                  00h - [No Errors]
[Memory Module Information (Type 6) - Length 12 - Handle 000ah]
  Socket Designation            DIMM2
  Bank Connections              23h - 3 2
  Current Speed                 35ns
  Installed Size                7fh - [Not Installed] [single bank]
  Enabled Size                  7fh - [Not Installed] [single bank]
[Memory Module Information (Type 6) - Length 12 - Handle 000bh]
  Socket Designation            DIMM3
  Bank Connections              45h - 5 4
  Current Speed                 69ns
[Memory Module Information (Type 6) - Length 12 - Handle 000ch]
  Socket Designation            DIMM4
  Bank Connections              67h - 7 6
  Current Speed                 103ns
[Physical Memory Array (Type 16) - Length 15 - Handle 002ch]
  Location                      03h - SystemBoard/Motherboard
  Use                           03h - System Memory
  Memory Error Correction       03h - None
  Maximum Capacity              8388608KB
  Memory Error Inf Handle       [Not Provided]
  Number of Memory Devices      4
[Memory Array Mapped Address (Type 19) - Length 15 - Handle 002dh]
  Starting Address              00000000h
  Ending Address                003effffh
  Memory Array Handle           002ch
  Partition Width               04
[Memory Device (Type 17) - Length 28 - Handle 002eh]
  Physical Memory Array Handle  002ch
  Memory Error Info Handle      [Not Provided]
  Total Width                   64 bits
  Data Width                    64 bits
  Size                          2048MB
  Form Factor                   09h - DIMM
  Device Set                    [None]
  Device Locator                DIMM1
  Bank Locator                  BANK0
  Memory Type                   0fh - SDRAM
  Type Detail                   0080h - Synchronous
  Speed                         0MHz
  Manufacturer                  Manufacturer00
  Serial Number
  Asset Tag Number
  Part Number                   ModulePartNumber00
[Memory Device Mapped Address (Type 20) - Length 19 - Handle 002fh]
  Ending Address                001fffffh
  Memory Device Handle          002eh
  Mem Array Mapped Adr Handle   002dh
  Partition Row Position        01
  Interleave Position           [None]
  Interleave Data Depth         01
[Memory Device (Type 17) - Length 28 - Handle 0030h]
  Total Width                   [Unknown]
  Data Width                    [Unknown]
  Size                          [Not Populated]
  Device Set                    [None]
  Device Locator                DIMM2
  Bank Locator                  BANK1
  Memory Type                   02h - Unknown
  Type Detail                   0004h - Unknown
  Speed                         0MHz
  Manufacturer                  Manufacturer01
  Serial Number
  Asset Tag Number
  Part Number                   ModulePartNumber01
[Memory Device Mapped Address (Type 20) - Length 19 - Handle 0031h]
  Ending Address                00000000h
  Memory Device Handle          0030h
[Memory Device (Type 17) - Length 28 - Handle 0032h]
  Total Width                   64 bits
  Data Width                    64 bits
  Size                          2048MB
  Device Set                    [None]
  Device Locator                DIMM3
  Bank Locator                  BANK2
  Speed                         0MHz
  Manufacturer                  Manufacturer02
  Serial Number
  Asset Tag Number
  Part Number                   ModulePartNumber02
[Memory Device Mapped Address (Type 20) - Length 19 - Handle 0033h]
  Starting Address              00200000h
  Ending Address                003fffffh
  Memory Device Handle          0032h
[Memory Device (Type 17) - Length 28 - Handle 0034h]
  Device Set                    [None]
  Device Locator                DIMM4
  Bank Locator                  BANK3
  Speed                         0MHz
  Manufacturer                  Manufacturer03
  Serial Number
  Asset Tag Number
  Part Number                   ModulePartNumber03
[Memory Device Mapped Address (Type 20) - Length 19 - Handle 0035h]
  Memory Device Handle          0034h
Top Bottom
