BugCheck 3B, {c0000005, fffff88004b3c817, fffff8800832e900, 0}
[B]atikmdag.sys Thu Nov 25 21:46:44 2010[/B]
Probably caused by : atikmdag.sys ( atikmdag+90817 )
Loading Dump File [F:\a\Minidump\D M P\DMP\011611-8829-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c1d000 PsLoadedModuleList = 0xfffff800`02e5ae50
Debug session time: Sun Jan 16 15:54:47.114 2011 (UTC - 5:00)
System Uptime: 0 days 9:53:22.987
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Followup: MachineOwner
4: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff88004b3c817, Address of the instruction which caused the bugcheck
Arg3: fffff8800832e900, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
atikmdag+90817
fffff880`04b3c817 8b4820 mov ecx,dword ptr [rax+20h]
CONTEXT: fffff8800832e900 -- (.cxr 0xfffff8800832e900)
rax=0000000000000000 rbx=fffffa800764aa40 rcx=fffffa8005f50890
rdx=0000000000000001 rsi=0000000000000015 rdi=fffffa8007e2f010
rip=fffff88004b3c817 rsp=fffff8800832f2d0 rbp=fffffa8005f50890
r8=0000000000000015 r9=fffff88004efe970 r10=0000000000000000
r11=fffff8800832f420 r12=0000000000000000 r13=fffffa800c689d00
r14=0000000000000001 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
atikmdag+0x90817:
fffff880`04b3c817 8b4820 mov ecx,dword ptr [rax+20h] ds:002b:00000000`00000020=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x3B
PROCESS_NAME: dwm.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff88004b3c817
STACK_TEXT:
fffff880`0832f2d0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : atikmdag+0x90817
FOLLOWUP_IP:
atikmdag+90817
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: atikmdag+90817
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4cef1f94
STACK_COMMAND: .cxr 0xfffff8800832e900 ; kb
FAILURE_BUCKET_ID: X64_0x3B_atikmdag+90817
start end module name
fffff880`045c1000 fffff880`045ff000 1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00e00000 fffff880`00e57000 ACPI ACPI.sys Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`0421f000 fffff880`042a9000 afd afd.sys Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`01650000 fffff880`01666000 AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0121b000 fffff880`01226000 amdxata amdxata.sys Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`09620000 fffff880`0962b000 asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`013ca000 fffff880`013d3000 atapi atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`013d3000 fffff880`013fd000 ataport ataport.SYS Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`05933000 fffff880`05953000 AtihdW76 AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
fffff880`04aac000 fffff880`052bd000 atikmdag atikmdag.sys Thu Nov 25 21:46:44 2010 (4CEF1F94)
fffff880`04747000 fffff880`04793000 atikmpag atikmpag.sys Thu Nov 25 21:16:47 2010 (4CEF188F)
fffff880`02e33000 fffff880`02e3a000 Beep Beep.SYS Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04615000 fffff880`04702000 BHDrvx64 BHDrvx64.sys Mon Nov 15 18:11:35 2010 (4CE1BE27)
fffff880`044c8000 fffff880`044d9000 blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0494a000 fffff880`04968000 bowser bowser.sys Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`007a0000 fffff960`007c7000 cdd cdd.dll Tue Nov 02 00:59:22 2010 (4CCF9AAA)
fffff880`02e00000 fffff880`02e2a000 cdrom cdrom.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cf4000 fffff880`00db4000 CI CI.dll Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`015b6000 fffff880`015e6000 CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c96000 fffff880`00cf4000 CLFS CLFS.SYS Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`016e1000 fffff880`01754000 cng cng.sys Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`047eb000 fffff880`047fb000 CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`04823000 fffff880`0482c000 cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`02fb6000 fffff880`02fc4000 crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`044aa000 fffff880`044c8000 dfsc dfsc.sys Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0449b000 fffff880`044aa000 discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0163a000 fffff880`01650000 disk disk.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05990000 fffff880`059b2000 drmk drmk.sys Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`08799000 fffff880`087ac000 dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0867d000 fffff880`08799000 dump_iaStor dump_iaStor.sys Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`0585c000 fffff880`05868000 Dxapi Dxapi.sys Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`052bd000 fffff880`053b1000 dxgkrnl dxgkrnl.sys Mon Nov 01 22:51:31 2010 (4CCF7CB3)
fffff880`053b1000 fffff880`053f7000 dxgmms1 dxgmms1.sys Mon Nov 01 22:50:56 2010 (4CCF7C90)
fffff880`04702000 fffff880`0470b000 easytthr easytthr.sys Sun Aug 29 10:10:54 2010 (4C7A6A6E)
fffff880`04400000 fffff880`04476000 eeCtrl64 eeCtrl64.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`09600000 fffff880`09620000 ENG64 ENG64.SYS Mon Dec 13 20:47:30 2010 (4D06CCB2)
fffff880`04476000 fffff880`0449b000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`09630000 fffff880`097ea000 EX64 EX64.SYS Mon Dec 13 20:55:48 2010 (4D06CEA4)
fffff880`04a98000 fffff880`04aa5000 fdc fdc.sys Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01272000 fffff880`01286000 fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01226000 fffff880`01272000 fltmgr fltmgr.sys Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01765000 fffff880`0176f000 Fs_Rec Fs_Rec.sys Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01600000 fffff880`0163a000 fvevol fvevol.sys Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01800000 fffff880`0184a000 fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`031f9000 fffff800`03242000 hal hal.dll Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04a00000 fffff880`04a24000 HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05800000 fffff880`0585c000 HdAudio HdAudio.sys Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`02f18000 fffff880`02f31000 HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`059f7000 fffff880`059ff080 HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`059e9000 fffff880`059f7000 hidusb hidusb.sys Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`04882000 fffff880`0494a000 HTTP HTTP.sys Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`019e2000 fffff880`019eb000 hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`012ae000 fffff880`013ca000 iaStor iaStor.sys Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`04546000 fffff880`045c1000 IDSvia64 IDSvia64.sys Fri Nov 05 17:13:11 2010 (4CD47367)
fffff880`04731000 fffff880`04747000 intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`047db000 fffff880`047ea880 intelsmb intelsmb.sys Wed May 13 03:31:00 2009 (4A0A7734)
fffff880`0482c000 fffff880`04836000 IOCBIOS IOCBIOS.SYS Thu Jul 09 13:47:22 2009 (4A562D2A)
fffff880`011b0000 fffff880`011dd000 Ironx64 Ironx64.SYS Fri Nov 12 18:06:50 2010 (4CDDC88A)
fffff880`04793000 fffff880`047db000 k57nd60a k57nd60a.sys Sun Apr 26 07:23:05 2009 (49F44419)
fffff880`01400000 fffff880`0140f000 kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0486e000 fffff880`0487c000 kbdhid kbdhid.sys Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba7000 fffff800`00bb1000 kdcom kdcom.dll Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0586f000 fffff880`058b2000 ks ks.sys Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`016c7000 fffff880`016e1000 ksecdd ksecdd.sys Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`019a5000 fffff880`019d0000 ksecpkg ksecpkg.sys Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`059b2000 fffff880`059b7200 ksthunk ksthunk.sys Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02f31000 fffff880`02f46000 lltdio lltdio.sys Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`059c6000 fffff880`059e9000 luafv luafv.sys Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c3e000 fffff880`00c82000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`02f5e000 fffff880`02f68000 mio mio.sys Wed Oct 13 11:32:10 2010 (4CB5D0FA)
fffff880`059b8000 fffff880`059c6000 monitor monitor.sys Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`00fe0000 fffff880`00fef000 mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`02f83000 fffff880`02f90000 mouhid mouhid.sys Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`01125000 fffff880`0113f000 mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`04968000 fffff880`04980000 mpsdrv mpsdrv.sys Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`04980000 fffff880`049ad000 mrxsmb mrxsmb.sys Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`049ad000 fffff880`049fb000 mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`04800000 fffff880`04823000 mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01200000 fffff880`0120b000 msahci msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02e98000 fffff880`02ea3000 Msfs Msfs.SYS Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e60000 fffff880`00e6a000 msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01669000 fffff880`016c7000 msrpc msrpc.sys Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`0453b000 fffff880`04546000 mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`019d0000 fffff880`019e2000 mup mup.sys Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01853000 fffff880`01945000 ndis ndis.sys Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04600000 fffff880`0460c000 ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`00fb1000 fffff880`00fe0000 ndiswan ndiswan.sys Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0591e000 fffff880`05933000 NDProxy NDProxy.SYS Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`0431d000 fffff880`0432c000 netbios netbios.sys Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`042a9000 fffff880`042ee000 netbt netbt.sys Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01945000 fffff880`019a5000 NETIO NETIO.SYS Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02fdd000 fffff880`02fee000 Npfs Npfs.SYS Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0452f000 fffff880`0453b000 nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c1d000 fffff800`031f9000 nt ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01413000 fffff880`015b6000 Ntfs Ntfs.sys Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02e2a000 fffff880`02e33000 Null Null.SYS Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`042f7000 fffff880`0431d000 pacer pacer.sys Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00eaa000 fffff880`00ebf000 partmgr partmgr.sys Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e6a000 fffff880`00e9d000 pci pci.sys Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0120b000 fffff880`0121b000 PCIIDEX PCIIDEX.SYS Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01754000 fffff880`01765000 pcw pcw.sys Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`06ca0000 fffff880`06d46000 peauth peauth.sys Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05953000 fffff880`05990000 portcls portcls.sys Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c82000 fffff880`00c96000 PSHED PSHED.dll Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`00ed4000 fffff880`00ef8000 rasl2tp rasl2tp.sys Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`011dd000 fffff880`011f8000 raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`00db4000 fffff880`00dd5000 raspptp raspptp.sys Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`015e6000 fffff880`01600000 rassstp rassstp.sys Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`044de000 fffff880`0452f000 rdbss rdbss.sys Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02e7d000 fffff880`02e86000 RDPCDD RDPCDD.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02e86000 fffff880`02e8f000 rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02e8f000 fffff880`02e98000 rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`017bb000 fffff880`017f5000 rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02f46000 fffff880`02f5e000 rspndr rspndr.sys Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02f90000 fffff880`02fb6000 RzSynapse RzSynapse.sys Wed Dec 15 05:32:19 2010 (4D089933)
fffff880`06d46000 fffff880`06d51000 secdrv secdrv.SYS Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0184a000 fffff880`01852000 spldr spldr.sys Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`08c42000 fffff880`08d01000 SRTSP64 SRTSP64.SYS Fri Nov 19 19:17:58 2010 (4CE713B6)
fffff880`04200000 fffff880`04216000 SRTSPX64 SRTSPX64.SYS Fri Nov 19 19:18:10 2010 (4CE713C2)
fffff880`06c00000 fffff880`06c96000 srv srv.sys Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`06d90000 fffff880`06df7000 srv2 srv2.sys Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`06d51000 fffff880`06d7e000 srvnet srvnet.sys Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04aa5000 fffff880`04aa6480 swenum swenum.sys Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`0113f000 fffff880`011b0000 SYMDS64 SYMDS64.SYS Fri Oct 15 13:53:54 2010 (4CB89532)
fffff880`01000000 fffff880`010c9000 SYMEFA64 SYMEFA64.SYS Mon Nov 15 16:56:23 2010 (4CE1AC87)
fffff880`043c1000 fffff880`043f7000 SYMEVENT64x86 SYMEVENT64x86.SYS Fri Jul 30 19:05:59 2010 (4C535AD7)
fffff880`0435b000 fffff880`043c1000 SYMNETS SYMNETS.SYS Tue Nov 30 18:24:40 2010 (4CF587B8)
fffff880`01a03000 fffff880`01c00000 tcpip tcpip.sys Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`06d7e000 fffff880`06d90000 tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02fee000 fffff880`02ffb000 TDI TDI.SYS Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01286000 fffff880`012a4000 tdx tdx.sys Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`04347000 fffff880`0435b000 termdd termdd.sys Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00400000 fffff960`0040a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`0470b000 fffff880`04731000 tunnel tunnel.sys Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`02ea3000 fffff880`02ef7000 udfs udfs.sys Mon Jul 13 19:23:37 2009 (4A5BC1F9)
fffff880`058b2000 fffff880`058c4000 umbus umbus.sys Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`02f68000 fffff880`02f82c00 usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04836000 fffff880`04853000 usbccgp usbccgp.sys Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`05868000 fffff880`05869f00 USBD USBD.SYS Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04a87000 fffff880`04a98000 usbehci usbehci.sys Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`058c4000 fffff880`0591e000 usbhub usbhub.sys Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04a31000 fffff880`04a87000 USBPORT USBPORT.SYS Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04853000 fffff880`0486e000 USBSTOR USBSTOR.SYS Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`04a24000 fffff880`04a31000 usbuhci usbuhci.sys Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00e9d000 fffff880`00eaa000 vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02e3a000 fffff880`02e48000 vga vga.sys Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02e48000 fffff880`02e6d000 VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00ebf000 fffff880`00ed4000 volmgr volmgr.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010c9000 fffff880`01125000 volmgrx volmgrx.sys Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0176f000 fffff880`017bb000 volsnap volsnap.sys Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`0432c000 fffff880`04347000 wanarp wanarp.sys Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02e6d000 fffff880`02e7d000 watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00efe000 fffff880`00fa2000 Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00fa2000 fffff880`00fb1000 WDFLDR WDFLDR.SYS Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`042ee000 fffff880`042f7000 wfplwf wfplwf.sys Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a0000 win32k win32k.sys Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`053f7000 fffff880`05400000 wmiacpi wmiacpi.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00e57000 fffff880`00e60000 WMILIB WMILIB.SYS Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02ef7000 fffff880`02f18000 WudfPf WudfPf.sys Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`08d01000 fffff880`08d32000 WUDFRd WUDFRd.sys Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`097ea000 fffff880`097fb000 WinUsb.sys
Checksum: 00000000
ImageSize: 00011000
fffff880`08d32000 fffff880`08da3000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`09600000 fffff880`09620000 ENG64.SYS
Checksum: 00000000
ImageSize: 00020000
fffff880`09636000 fffff880`097f0000 EX64.SYS
Checksum: 00000000
ImageSize: 001BA000
Checksum: 00000000
ImageSize: 00071000
fffff880`019eb000 fffff880`019f9000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`02eae000 fffff880`02fca000 dump_iaStor.
Checksum: 00000000
ImageSize: 0011C000
fffff880`02fca000 fffff880`02fdd000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
