Windows 7 Need help with Graphics lagging, CPU, and more.
scaleblue
So i play CA (Combat arms, a first person shooter) at around 30-50 frames per second.
sometimes with tweaks i can get to around 43-57 consistent frames per second.
I CAN PROVIDE MORE INFO IF YOU ASK.
3 Incidents:THE MAIN TOPIC OF THIS PROBLEM
On three different computer i have had One moment of insane and godly frames per second around 300-400frames per second
-First time was on my macbook(Dual core 2.6ish GHz /Nvidia, 256 dedicated RAM/ 4GB RAM/)
I installed bootcamp and after a year or so of consistent lagging around 60 frames per second i was lagging in combat arms more , so i reinstalled my Nvidia graphics driver
After i reinstalled i was able to play CA On full graphics Anti-asling x8 anisotropy x8
overall settings high, and still run at around 200+ frames per second
On CA, fallout 3 new vegas, and some others.
As soon as i restarted my laptop it was back to same old laggy 50-60 frames per second.
-On a Metal laptop I had (for like 3 months before i discovered that buzzing feeling was the comp shocking me for those months)I was playing and randomly one night it started running at insane frames per second, i dont remember too much but it was fallout 3 on low then, full graphics.
And most recent on my current AMD quad core:
I was playing laggy games around 20-30 frames per second with lots of freezes.
I reinstalled my graphics drivers and instantly my games were running full graphics and the insane 200-300 frames per second.
Now currently I am running at 30-50 frames per second with rarely any freezes.
MY current laptop: CA 25-55 frames per second
Gateway - Windows 7 home premium 64 BIT
AMD Quadcore 1.5Ghz A8-3500m
4GB RAM DDR3, I did have 6GB but i gave 2GB to my Brother, it only caused me to be at current lower -10 frames per second.
640GB HardDrive space
AMD 6620G, 512 dedicated ram.
1366 x 768 and my VGA Display 1360 x 768.
Macbook/bootcamp:CA 30-80 frames per second
Windows 7 Ultimate 64Bit
dual core 2.6ish GHz
256 dedicated RAM
6GB RAM
250HD space
Gamebooster report has more info
Programs & settings I use
- I sometimes use Gamebooster which gives me +5-10fps
- I also have been trying recently the
windows media player booster program with no signs of fps gain.
- I have fully updated windows 7
- I just now reinstalled my graphics driver with no improvement.
- I reinstalled CA alot and do gain too around consistent 50-65 frames per second frames per second for like 3 days.
-I used overdrive for month and it hurt my comp
It did not boost me and it caused my games to jitter and screech, it also caused my laptop to have other erratic problems
(I even set it to run at just over 100% CPU and had same effects)
I run on the lowest graphics on CA and AMD AMD is set to no v-sync, no antiasling, no anisotropy no triple buffer, and such with 30-50 frames still.
- I have tried in lower resolution screens with only small 10 frames per second.
- I have defragged.
Ideas
-On the macbook and this AMD quad core i had been playing for over 10 hours
one person told me it takes times for the comp to heat up and then it will run faster
(Problem is I play around 14 hours per day, and it does get faster but only up to around +10 frames and MUCH faster loading speeds)
If this is true, then how could i implement this and keep my comp in correct temperature.
(I have a fan and when i rarely have used it I think it slows my comp down)
-MY CPUs on this quad core never go above 25%
my GPU according to system monitor Gets maxed out during current CA gameplay
Maybe i can somehow get my comp to use my CPUs instead of my GPU?
-I heard the having 3D vision installed on the Nvidia computers sometimes lags people up so i made sure to disable featues like that when i reinstalled, but im not sure if i disabled anything, maybe you know of some feature i should disable.
I think it was prob some feature/setting not being installed with my drivers.
or some setting put in by windows the the AMD/Nvidia driver messed with.
(maybe reinstalling cleared a cache that lags me)
Why it cant be some things.
-I was not running game booster or any program like that.
-I was not running on low graphics i was running on max, after i saw that i was running so fast on low graphics, in attempt to sea how much it could handle.
I had no overdrive.
-I did no hardware changes at all within at least 1-2 months of the 3 incidents.
(probably longer like 1 year)
-I have reinstalled my windows 7 comp and instantly installed CA and then played it with only consistent 50-60 frames.
-Its not CA because i have tried reinstalling and then not installing CA and still ran slow on fallout 3, and even Runescape.
-I have played on no page file, and on 7GB page file
-I have tried turning off themes, running gamebooster, defragging. and it is pretty smooth but still a measly 43-60 frames per second.
-I was playing On 1280 X 800 res during incident.
I defragment.
Current game speeds
AMD
Skyrim 30-40frames per second
None of the weak fixes are what im after im after those moments of pure..........insanity...
Where i had 300-400 frames per second.
but maybe a weak fix will be all i need to tide it over.
I got 10 headshots in a row easily on CA where 10 headshots in a row is as rare as winning lottery.
I dont want to post this and watch it get ignored like most forums.
I know its possible because it happened to me three times, and on this AMD laptop.
I dont think this is a gaming topic because its about graphics, not a specific game.
It also effected the rest of my system at least a little, that i could load games and such faster.
This is unrelated to this problem but im thinking about buying a 8GB RAM stick for my laptop i just want to know how much would that help. My teacher said that upgrading the ram will speed up my computer ALOT. (RAM is Cheap and yet expensive, I need a cheap 8GB high quality stick, newegg.com said $45 and at Freys instore it was like $25ish, but its like 100miles away now)
I have my CISCO IT essentials so i can easily handle windows tasks and i already have used MANY different tweaks of Regitry, and other system tweaks.
----------G----A---M----E---B----O---O---S---T--E----R--------------------
-----------------------R----E----P----O---R---T----------------------------------
Game Booster Diagnose Report v1.0
Version: 3.5.0.1526
Date: 2012/06/26 08:08:20
01 - Operating System
0101 - Operating System : Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
0102 - Language : English (Regional Setting: English)
0103 - BIOS : InsydeH2O Version CCB.03.61.13V1.04
0104 - Processor : AMD A8-3500M APU with Radeon(tm) HD Graphics (4 CPUs), ~1.5GHz
0105 - Memory : 4096MB RAM
0106 - Available OS Memory : 3562MB RAM
0107 - Page File : 1603MB used, 5520MB available
0108 - Windows Dir : C:\Windows
0109 - DirectX Version : DirectX 11
0110 - DX Setup Parameters : Not found
0111 - User DPI Setting : 96 DPI (100 percent)
0112 - System DPI Setting : 96 DPI (100 percent)
0113 - DWM DPI Scaling : Disabled
0114 - DxDiag Version : 6.01.7601.17514
02 - Processor
0201 - Caption : AMD A8-3500M APU with Radeon(tm) HD Graphics x4 ~1500MHz
0202 - Current Clock Speed : 1500MHz
0203 - L1 Cache : 512.00 KB
0204 - L2 Cache : 4.00 MB
03 - Video Adapter
0301 - Card Name : AMD Radeon HD 6620G
0302 - Manufacturer : Advanced Micro Devices, Inc.
0303 - Chip Type : ATI display adapter (0x9641)
0304 - DAC Type : Internal DAC(400MHz)
0305 - Device Key : Enum\PCI\VEN_1002&DEV_9641&SUBSYS_05991025&REV_00
0306 - Display Memory : 2022 MB
0307 - AdapterRAM : 512.00 MB
0308 - Current Mode : 1360 x 768 (32 bit) (60Hz)
0309 - Monitor Name : Generic PnP Monitor
0310 - Driver Name : aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
0311 - Driver Version : 8.17.0010.1124
0312 - Driver Language : English
0313 - DDI Version : 11
0314 - Driver Model : WDDM 1.1
0315 - Driver Beta : False
0316 - Driver Debug : False
0317 - Driver Date : 4/5/2012 19:20:04
0318 - Driver Size : 1067520
0319 - VDD : n/a
0320 - Mini VDD : n/a
0321 - Mini VDD Date : n/a
0322 - Mini VDD Size : 0
0323 - Device Identifier : {D7B71EE2-D501-11CF-F177-9325BEC2C535}
0324 - Vendor ID : 0x1002
0325 - Device ID : 0x9641
0326 - SubSys ID : 0x05991025
0327 - Revision ID : 0x0000
0328 - Driver Strong Name : oem25.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_Sumo_Mobile:8.961.0.0:pci\ven_1002&dev_9641
0329 - Rank Of Driver : 00E62001
0330 - Video Accel : ModeMPEG2_A ModeMPEG2_C
0331 - Deinterlace Caps : {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
0332 - D3D9 Overlay : Not Supported
0333 - DXVA-HD : Not Supported
0334 - DDraw Status : Enabled
0335 - D3D Status : Enabled
0336 - AGP Status : Enabled
0337 - Notes : No problems found.
0338 - OpenGL : 6.1.7600.16385 (win7_rtm.090713-1255)
04 - Memory
0401 - Total Memory : 3.48 GB
0402 - Free Memory : 2.21 GB
0403 - Total Pagefile : 6.96 GB
0404 - Free Pagefile : 5.39 GB
0405 - Bank Label : BANK0
0406 - Speed : 1066 MHz
0407 - Total Width : 64 Bits
0408 - Capacity : 2.00 GB
05 - Network
0501 - Description : Broadcom NetLink (TM) Gigabit Ethernet
0502 - Driver Date : 5-10-2011
0503 - Driver Version : 14.8.0.5
06 - Motherboard
0601 - Model : SJV50-SB
0602 - Manufacturer : Gateway
07 - Sound Device
0701 - Description : Speakers (Realtek High Definition Audio)
0702 - Default Sound Playback : True
0703 - Default Voice Playback : True
0704 - Hardware ID : HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_10250599&REV_1001
0705 - Manufacturer ID : 1
0706 - Product ID : 100
0707 - Type : WDM
0708 - Driver Name : RTKVHD64.sys
0709 - Driver Version : 6.00.0001.6602
0710 - Driver attributes : Final Retail
0711 - Date and Size : 3/27/2012 17:03:36
0713 - Driver Provider : Realtek Semiconductor Corp.
0714 - Min/Max Sample Rate : 5374206, 5374206
0715 - Static/Strm HW Mix Bufs : 5374206, 5374206
0716 - Static/Strm HW 3D Bufs : 5374206, 5374206
0717 - HW Memory : 5374214
0718 - Voice Management : False
0719 - EAX(tm) 2.0 Listen/Src : False, False
0720 - I3DL2(tm) Listen/Src : False, False
0721 - Notes : No problems found.
08 - Hard Disk
0801 - Model : TOSHIBA MK6459GSXP ATA Device
0802 - Media Type : Fixed hard disk media
0803 - Size : 596.17 GB
0804 - Interface Type : Serial ATA
0805 - Driver Date : 6-21-2006
0806 - Driver Version : 6.1.7600.16385
0807 - Caption : C:\
0808 - Capacity : 578.07 GB
0809 - Free Space : 256.63 GB
0810 - Drive Type : 3-Fixed
0811 - File System : NTFS
09 - Process
0901 - 000 Idle 0 0 0
0901 - 004 System 0 0 0
0901 - 114 smss.exe 0 0 0 normal
0901 - 1e4 csrss.exe 0 0 0 normal
0901 - 22c wininit.exe 0 0 0 high
0901 - 270 services.exe 0 0 0 normal
0901 - 280 lsass.exe 0 0 0 normal
0901 - 288 lsm.exe 0 0 0 normal
0901 - 320 svchost.exe 0 0 0 normal
0901 - 370 svchost.exe 0 0 0 normal
0901 - 3f4 svchost.exe 0 0 0 normal
0901 - 1b8 svchost.exe 0 0 0 normal
0901 - 1e8 svchost.exe 0 0 0 normal
0901 - 418 svchost.exe 0 0 0 normal
0901 - 4d4 svchost.exe 0 0 0 normal
0901 - 5d4 svchost.exe 0 0 0 normal
0901 - 648 dsiwmis.exe 0 0 0 normal C:\Program Files (x86)\Launch Manager
0901 - 684 ePowerSvc.exe 0 0 0 normal
0901 - 6a4 svchost.exe 0 0 0 normal
0901 - 878 svchost.exe 0 0 0 normal
0901 - ab4 svchost.exe 0 0 0 normal
0901 - c44 dllhost.exe 0 0 0 normal
0901 - d4c svchost.exe 0 0 0 normal
0901 - ec4 spoolsv.exe 0 0 0 normal
0901 - f14 csrss.exe 2 170 78 normal
0901 - c88 winlogon.exe 2 6 0 high
0901 - f74 LMutilps32.exe 2 14 4 normal C:\Program Files (x86)\Launch Manager
0901 - a5c taskhost.exe 2 21 15 normal
0901 - 658 dwm.exe 2 19 2 high
0901 - 8e4 explorer.exe 2 341 239 normal
0901 - dbc RAVCpl64.exe 2 54 19 normal
0901 - d04 PresentationFontCache.exe 0 0 0 normal
0901 - 9b4 taskhost.exe 2 14 4 normal
0901 - e98 atiesrxx.exe 0 0 0 normal
0901 - 9dc atieclxx.exe 2 9 7 normal
0901 - c04 Fuel.Service.exe 0 0 0 normal
0901 - 824 MOM.exe 2 10 9 normal
0901 - 840 CCC.exe 2 73 61 normal
0901 - 568 firefox.exe 2 66 58 normal C:\Program Files (x86)\Mozilla Firefox
0901 - 3d4 plugin-container.exe 2 33 38 normal C:\Program Files (x86)\Mozilla Firefox
0901 - 9e8 GameBooster.exe 2 1597 95 normal C:\Program Files (x86)\IObit\Game Booster 3
0901 - 9a4 gbtray.exe 2 54 43 normal C:\Program Files (x86)\IObit\Game Booster 3
0901 - e60 FPSClient.exe 2 35 27 normal C:\Program Files (x86)\IObit\Game Booster 3
0901 - 11c WmiPrvSE.exe 0 0 0 normal
0901 - e40 WmiPrvSE.exe 0 0 0 normal
0901 - d00 audiodg.exe 0 0 0
10 - Service
1001 - Application Experience - [C:\Windows\system32\svchost.exe -k netsvcs]
1001 - AMD External Events Utility - [C:\Windows\system32\atiesrxx.exe]
1001 - Windows Audio Endpoint Builder - [C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - Windows Audio - [C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted]
1001 - Base Filtering Engine - [C:\Windows\system32\svchost.exe -k LocalServiceNoNetwork]
1001 - Background Intelligent Transfer Service - [C:\Windows\System32\svchost.exe -k netsvcs]
1001 - Computer Browser - [C:\Windows\System32\svchost.exe -k netsvcs]
1001 - Cryptographic Services - [C:\Windows\system32\svchost.exe -k NetworkService]
1001 - DHCP Client - [C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted]
1001 - DNS Client - [C:\Windows\system32\svchost.exe -k NetworkService]
1001 - Dritek WMI Service - [C:\Program Files (x86)\Launch Manager\dsiwmis.exe]
1001 - Extensible Authentication Protocol - [C:\Windows\System32\svchost.exe -k netsvcs]
1001 - ePower Service - [C:\Program Files\Gateway\Gateway Power Management\ePowerSvc.exe]
1001 - Windows Event Log - [C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted]
1001 - COM+ Event System - [C:\Windows\system32\svchost.exe -k LocalService]
1001 - Function Discovery Provider Host - [C:\Windows\system32\svchost.exe -k LocalService]
1001 - Function Discovery Resource Publication - [C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation]
1001 - Windows Font Cache Service - [C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation]
1001 - Windows Presentation Foundation Font Cache 3.0.0.0 - [C:\Windows\Microsoft.Net\Framework64\v3.0\WPF\PresentationFontCache.exe]
1001 - Human Interface Device Access - [C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - HomeGroup Listener - [C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - HomeGroup Provider - [C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted]
1001 - IKE and AuthIP IPsec Keying Modules - [C:\Windows\system32\svchost.exe -k netsvcs]
1001 - IP Helper - [C:\Windows\System32\svchost.exe -k NetSvcs]
1001 - CNG Key Isolation - [C:\Windows\system32\lsass.exe]
1001 - Server - [C:\Windows\system32\svchost.exe -k netsvcs]
1001 - Workstation - [C:\Windows\System32\svchost.exe -k NetworkService]
1001 - TCP/IP NetBIOS Helper - [C:\Windows\system32\svchost.exe -k LocalServiceNetworkRestricted]
1001 - Windows Firewall - [C:\Windows\system32\svchost.exe -k LocalServiceNoNetwork]
1001 - Network Connections - [C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - Network List Service - [C:\Windows\System32\svchost.exe -k LocalService]
1001 - Network Location Awareness - [C:\Windows\System32\svchost.exe -k NetworkService]
1001 - Network Store Interface Service - [C:\Windows\system32\svchost.exe -k LocalService]
1001 - Peer Networking Identity Manager - [C:\Windows\System32\svchost.exe -k LocalServicePeerNet]
1001 - Peer Networking Grouping - [C:\Windows\System32\svchost.exe -k LocalServicePeerNet]
1001 - Program Compatibility Assistant Service - [C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - Plug and Play - [C:\Windows\system32\svchost.exe -k DcomLaunch]
1001 - Peer Name Resolution Protocol - [C:\Windows\System32\svchost.exe -k LocalServicePeerNet]
1001 - IPsec Policy Agent - [C:\Windows\system32\svchost.exe -k NetworkServiceNetworkRestricted]
1001 - Power - [C:\Windows\system32\svchost.exe -k DcomLaunch]
1001 - User Profile Service - [C:\Windows\system32\svchost.exe -k netsvcs]
1001 - Security Accounts Manager - [C:\Windows\system32\lsass.exe]
1001 - System Event Notification Service - [C:\Windows\system32\svchost.exe -k netsvcs]
1001 - Shell Hardware Detection - [C:\Windows\System32\svchost.exe -k netsvcs]
1001 - Print Spooler - [C:\Windows\System32\spoolsv.exe]
1001 - SSDP Discovery - [C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation]
1001 - Superfetch - [C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - Themes - [C:\Windows\System32\svchost.exe -k netsvcs]
1001 - Distributed Link Tracking Client - [C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - Desktop Window Manager Session Manager - [C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - Windows Defender - [C:\Windows\System32\svchost.exe -k secsvcs]
1001 - Windows Management Instrumentation - [C:\Windows\system32\svchost.exe -k netsvcs]
1001 - WLAN AutoConfig - [C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - Security Center - [C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted]
1001 - Windows Update - [C:\Windows\system32\svchost.exe -k netsvcs]
1001 - Windows Driver Foundation - User-mode Driver Framework - [C:\Windows\system32\svchost.exe -k LocalSystemNetworkRestricted]
1001 - AMD FUEL Service - [C:\Program Files\ATI Technologies\ATI.ACE\Fuel\Fuel.Service.exe /launchService]
11 - Windows Express
1101 - System Score : 5.9
1102 - Memory Score : 5.9
1103 - CPU Score : 6.6
1104 - Graphics Score : 5.9
1105 - Gaming Score : 6.5
1106 - Disk Score : 5.9
12 - Event Log
1201 - Time : 6/26/2012 8:48:55 PM
1202 - Source : WinMgmt
1203 - Description : Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
1201 - Time : 6/26/2012 8:30:04 PM
1202 - Source : Application Hang
1203 - Description : The program explorer.exe version 6.1.7601.17567 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
Process ID: fd4
Start Time: 01cd53064db9af16
Termination Time: 0
Application Path: C:\Windows\explorer.exe
Report Id: 9b95fa7e-bf8a-11e1-876f-b870f4b31d76
1201 - Time : 6/26/2012 12:53:55 AM
1202 - Source : Application Error
1203 - Description : Faulting application name: WLXPhotoGallery.exe, version: 15.4.3555.308, time stamp: 0x4f596a69
Faulting module name: atidxx32.dll, version: 8.17.10.342, time stamp: 0x4dddd162
Exception code: 0xc0000005
Fault offset: 0x0000e2a4
Faulting process id: 0x8e0
Faulting application start time: 0x01cd52f315cd647f
Faulting application path: C:\Program Files (x86)\Windows Live\Photo Gallery\WLXPhotoGallery.exe
Faulting module path: C:\Windows\system32\atidxx32.dll
Report Id: 592a60dc-bee6-11e1-876f-b870f4b31d76
1201 - Time : 6/25/2012 9:31:57 PM
1203 - Description : Faulting application name: Engine.exe, version: 0.0.0.0, time stamp: 0x4fd800ca
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc00000fd
Fault offset: 0x73bee2d4
Faulting process id: 0xf08
Faulting application start time: 0x01cd52d449c626a7
Faulting application path: C:\Nexon\Combat Arms\Engine.exe
Faulting module path: unknown
Report Id: 225568f9-beca-11e1-876f-b870f4b31d76
1201 - Time : 6/25/2012 12:44:43 PM
1201 - Time : 6/26/2012 10:44:08 PM
1202 - Source : Service Control Manager
1203 - Description : The AMD External Events Utility service terminated unexpectedly. It has done this 1 time(s).
1201 - Time : 6/26/2012 8:47:39 PM
1203 - Description : The Cyberlink RichVideo64 Service(CRVS) service terminated unexpectedly. It has done this 1 time(s).
1201 - Time : 6/26/2012 8:47:36 PM
1203 - Description : The PnkBstrA service terminated unexpectedly. It has done this 1 time(s).
1201 - Time : 6/26/2012 8:35:21 PM
1203 - Description : The Volume Shadow Copy service terminated unexpectedly. It has done this 1 time(s).
1201 - Time : 6/26/2012 8:35:12 PM
1203 - Description : The Windows Defender service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 60000 milliseconds: Restart the service.
End of file - 23098 Bytes
