To find the drivers for your Edimax WiFi USB stick that are compatible with Windows 7, you can follow these steps: 1. Visit the Official Edimax Website: - Start by visiting the official Edimax website (EDIMAX - Netwoking Solution Provider including SMB Wi-Fi Access Point, AP Controller, SMB and Industrial PoE++ L2+ Switch, Industrial Embedded Wirless (Wi-Fi, Bluetooth) USB Dongle (Adapter), Wi-Fi Smart Plug, IoT, Smart Home). - Look for a "Support" or "Downloads" section on their website. 2. Search for Your WiFi USB Stick Model: - Locate the specific model of your Edimax WiFi USB stick. - Check for driver downloads specifically for Windows 7. 3. Download Drivers: - If there are drivers available for Windows 7, download them. - Make sure to choose the correct driver version for your operating system (Windows 7). 4. Install the Drivers: - Once downloaded, install the drivers by running the setup file. - Follow the on-screen instructions to complete the installation process. 5. Connect the WiFi USB Stick: - After installing the drivers, connect your Edimax WiFi USB stick to your computer. - Windows should now be able to recognize the device and you should be able to use it for WiFi connectivity. If you encounter any issues during this process or if you need further assistance, feel free to provide the specific model of your Edimax WiFi USB stick, and I can help you with more detailed instructions or look for the drivers on your behalf.
