Windows 7 netgear wg311v3 and levelone WNC-0301
Status
Not open for further replies.
daluur
Hi
I have recently installed Windows 7 rc, I had netgear wg311v3 as my wireless adapter but after I installed Windows 7, it didn't work (I coulnd't even see any wireless conections), I tried to do as sugested in this post Link Removed but after I had installed the program, nothing changed
then I bought LevelOne WNC-0301, in the hope that it might work. but almost the same, with the LevelOne adapter I can see the wireless conection, but I can't connect to it :S..
anyone knows what might be wrong, and/or know how to fix it?
Hi
Lack of Proper Win 7 driver is the cause in my opinion. You can check Device Manager> +Network Adapters and see how your netgear wg311v3 wireless PCI adapter is listed there? Look for Error symbols (! or?) and or ?Unknown Device entry for additional evidence.
I think Netgear has a Vista Beta driver for your netgear wg311v3 wireless PCI adapter you may try to install and try your luck. The download page: Windows Vista
Status
