Windows 7 Network and Sharing issue
Messarionovich
Recently, when I noticed that the wireless manager in the system tray seemed to be stuck on 'connecting to a network', when there's a blue spinning circle next to the hollow signal bars.
Confused, since I was already surfing the internet, I tried to access the Network and Sharing Center via right clicking on the wireless manager in the system tray. I found that the window came up, but refused to respond.
Convinced that this was just a fluke of some kind, I tried again. The same thing happened, no matter how many times I restarted.
All my other programs still work correctly, and troubleshooting comes up with nothing. I have scanned my computer with G Data 2010 and Norton Internet Security 2011, with no viruses showing up.
If anyone can help, it would be greatly appreciated, since the problem is occurring on a laptop, and not being able to connect to other wireless networks is going to be a problem for me in the future.
It seems like you are facing an issue with the wireless network connectivity on your laptop. Here are a few steps you can take to troubleshoot and potentially resolve the issue:
Troubleshooting Steps:​
  1. Restart the Wireless Adapter:
    • Open Device Manager (Press Windows + X, then select Device Manager).
    • Locate the Network Adapters section, expand it, and right-click on your wireless adapter.
    • Select Disable and wait for a few seconds, then right-click on it again and choose Enable.
    []Reset TCP/IP Stack:
    • Open Command Prompt as an administrator (search for cmd, right-click, and choose Run as administrator).
    • Type the following commands one by one and...
    • Type the following commands one by one and press Enter after each:
      • netsh winsock reset
      • netsh int ip reset
    • ]Restart your computer after running these commands.
    []Update Wireless Adapter Driver:
    • Visit the laptop manufacturer's website or the wireless adapter manufacturer's site to download and install the latest driver for your wireless adapter.
    ]Check for Windows Updates:
    • Make sure your system is up to date by checking for and installing any pending Windows updates.
    []Run Network Troubleshooter:
    • Use the built-in Windows Network Troubleshooter to diagnose and potentially fix network-related problems.
    ]Check Power Settings:
    • Ensure that your laptop's power-saving settings are not interfering with the wireless network adapter's performance. Adjust settings to prevent the adapter from turning off to save power.
    []Perform System Restore:
    • If the issue started recently, consider using System Restore to revert your system to a previous state when the wireless connectivity was working fine.
    ]Check Hardware Issues:
    • If none of the above steps work, there might be a hardware issue with the wireless adapter. Contact your laptop manufacturer's support for further assistance or consider getting the adapter checked.
      Additional Notes:​
      • Running multiple antivirus programs simultaneously (like G Data 2010 and Norton Internet Security 2011) can sometimes cause conflicts. Consider using only one antivirus program and ensure it is up to date.
      • It's also a good idea to restart your router or modem to rule out any network issues.
      By following these steps, you may be able to resolve the wireless network connectivity issue on your laptop. If the problem persists, feel free to provide more details for further assistance.
