Windows 7 Network bridge Help!
inverted31
Hello, I have my xbox 360 conected to the internet throught a internnet sharing connection on my pc, ive been told that if I bridge them instead it will be a faster connection. So i did but now i have no connection to the internet on either my xbox n'or my pc. I have no idea how to fix this, anything helps, thankyou.
Do I have this right?
PC>hard wired (by cable) to internet> XBOX>connected wirelessly to pc
If that is the case, what did you Bridge?, if you had connection you don't need to bridge anything, just remove everything from bridge and delete it.
