network card disable after low battery
We have a Dell laptop connected with cabled network/internet.
When the laptop goes on low battery, the network card is disabled.
So when you manually enable the network card again, everything works fine.
But the strange thing is that all the options in power management (allow computer to disable this device to save power) are NOT checked. So why is the network disabled? How can i care that the network won't disable anymore?
SO anyone with advice?
thanks
