I've just got an Acer 1810TZ laptop running Windows 7 Home and I've got some connectivity problems - i don't know if they are linked or separate issues.
Wireless connection
I'm trying to connect to the internet wirelessly through a Draytek Vigor2600G router. The router has got a Network key When I click on the Wireless Connections symbol in the bottom right hand corner the router is there (V2600G), I click on connect and get a message saying that Windows was unable to connect to V2600G. Troubleshooting doesn't identify any problems.
If I connect to the router with a cable then I can connect to the internet.
I've run the Internet Connectivity Evaluation Tool and got the following results:
Basic Internet Connectivity Test - Supported
Network Address Translator Type - Not supported
Traffic Congestion Test - supported
TCP High Performance Test - supported
UPnP Support Test - not supported
Multiple Simultaneous Connection States Test - supported
Conclusion states that the internet router should work just as well with Windows Vista (so presumably with Windows 7) as with current operating system (I use XP Professional on my desktop)
I've been to Network & Sharing Centre, Set up a new connection or network, Manually connect to a wireless network,. When I get to the screen for Network name, etc, I've put in the existing network name (V2600G), security type WEP and the 13 digit security key. It then tells me the network already exists and to use Connect to a Network and I'm back at the beginning again with Windows unable to connect. What am I doing wrong?
Home Network
My other problem is that I have an existing home network called Gallery which has 3 existing computers on (all running XP). On the new computer (assuming that it is connected to the router) how do I get the Acer onto the existing home network and able to see the other computers and them able to see the Acer?
Any suggestions would be gratefully received. Thanks
Wireless connection
Home Network
