Windows 10 Network issues
TBAF
Hello!
I'm currently using a Wireless network adapter for my PC, and haven't experienced any issues with it until now. I don't think it's to do with the Adapter.
(For context my wireless adapter is called "Wifi 2")
All of a sudden I get the yellow warning sign next to the WIFI symbol, I use Windows diagnostics and it says "Wifi 2" doesn't have a valid ip configuration, once I enter the IP/DNS I use Windows diagnostics again and a new error appears "DHCP is not enabled for "Wifi 2" " And it gives me the option to fix the problem, once I do this it gets rid of the IP I entered and I once again use Windows diagnostics and I'm back to square one " "Wifi 2" doesn't have a valid ip configuration" "
This is very frustrating and have possibly tried everything, from tinkering with the Admin panel for my router and giving my Tower a reserved IP for it.
Many thanks
Tom
If you have a firewall verify you're not blocking DHCP ports 67 and 68. You may also want to verify your router is serving DHCPv4. If that looks good try bouncing the router.
The last item would be to copy wireshark to the computer, install and do a capture filtered to dhcp and run ipconfig /renew save the capture and upload.
There are a lot of reasons you could be having an issue. The most common would be an incorrect configuration, a problem with the DHCP server (this is likely on your router) or a firewall configuration issue. I would reconfigure your system for DHCP on the adapter configuration. Download or copy this script to that machine Network Diagnostic Information and run it as administrator (right click, 'run as admin') and upload the log it likely will tell us what the issue is.
Open a Command prompt and type in ipconfig /release, then ipconfig /renew and finally ipconfig /all. Please post a message with the output to ipconfig /all. Here is a video about how to use Command prompt:
Sorry It says this file doesn't have a extension?
Start Time: 06/08/2018 - 19:31:55.48
=============== IP CONFIG ===============
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-7GO73J5
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 20:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter #6
Wireless LAN adapter Local Area Connection* 21:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #7
Wireless LAN adapter Local Area Connection* 22:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #8
Wireless LAN adapter WiFi 2:
Description . . . . . . . . . . . : 802.11ac Wireless LAN Card
Link-local IPv6 Address . . . . . :
Autoconfiguration IPv4 Address. . :
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 501763590
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-18-19-00-88-D7-F6-C8-13-F6
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
=============== ARP CACHE ===============
Interface: 127.0.0.1 --- 0x1
Internet Address Physical Address Type
224.0.0.22 static
224.0.0.251 static
239.255.255.250 static
Interface: 0.0.0.0 --- 0xffffffff
224.0.0.22 static
Interface: 169.254.213.29 --- 0x1d
169.254.255.255 ff-ff-ff-ff-ff-ff static
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
224.0.0.252 01-00-5e-00-00-fc static
239.255.255.250 01-00-5e-7f-ff-fa static
=============== WINS CACHE ==============
NetBIOS Names Resolution and Registration Statistics
Resolved By Broadcast = 0
Resolved By Name Server = 0
Registered By Broadcast = 6
Registered By Name Server = 0
Ethernet:
Node IpAddress: [0.0.0.0] Scope Id: []
No Connections
WiFi 2:
Node IpAddress: [169.254.213.29] Scope Id: []
No Connections
Local Area Connection* 16:
No Connections
Local Area Connection* 18:
No Connections
Local Area Connection* 19:
No Connections
No Connections
No Connections
No Connections
============= PROXY SETTINGS =============
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings
DisableCachingOfSSLPages REG_DWORD 0x0
IE5_UA_Backup_Flag REG_SZ 5.0
PrivacyAdvanced REG_DWORD 0x1
SecureProtocols REG_DWORD 0xa80
CertificateRevocation REG_DWORD 0x1
User Agent REG_SZ Mozilla/4.0 (compatible; MSIE 8.0; Win32)
ZonesSecurityUpgrade REG_BINARY 28B94C1611EFD301
WarnonZoneCrossing REG_DWORD 0x0
EnableNegotiate REG_DWORD 0x1
MigrateProxy REG_DWORD 0x1
ProxyEnable REG_DWORD 0x0
LockDatabase REG_QWORD 0x1d3ef221b406c3b
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Cache
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Connections
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Http Filters
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Lockdown_Zones
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\P3P
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Passport
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Wpad
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones
=============== HOSTS FILE ===============
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
=============== PING TESTs ===============
Ping request could not find host google.com. Please check the name and try again.
Pinging 8.8.8.8 with 32 bytes of data:
PING: transmit failed. General failure.
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Tracing route to 8.8.8.8 over a maximum of 2 hops
1 Transmit error: code 1231.
Trace complete.
=============== DNS TESTs ===============
So looks like you're getting a APIPA address which means either your computer is having problems communicating to the DHCP server or a problem on the DHCP server. I would remove any reserved addresses you have on the router. If you have mac filtering I would disable that. Then on the device run the commands ipconfig /relesae then ipconfig /renew
No operation can be performed on Ethernet while it has its media disconnected.
No operation can be performed on Local Area Connection* 23 while it has its media disconnected.
No operation can be performed on Local Area Connection* 24 while it has its media disconnected.
No operation can be performed on Local Area Connection* 25 while it has its media disconnected.
Wireless LAN adapter Local Area Connection* 23:
Wireless LAN adapter Local Area Connection* 24:
Wireless LAN adapter Local Area Connection* 25:
Link-local IPv6 Address . . . . . : fe80::a109:6807:a6f5:2236%3
Autoconfiguration IPv4 Address. . : 169.254.34.54
Okay! Thank you
Two questions
how to check if your firewall is blocking said ports manually
Andwhat bouncing the router means
Thank you!! ^ _ ^
Reboot(bounce) the router. Depends on the firewall in use. If it's Windows you can look in control panel .
DHCP wasn't on the list so I couldn't do it.
It's not a capture filter. It's a display you have to do it after you start the capture
Physical Address. . . . . . . . . : (it should be displayed)
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Your problem might be caused by one of these issues.
1) Your Physical Address is Missing. This means something is wrong with your wireless adapter.
Have you tried to uninstall and reinstall your wireless card driver?
2) As far as I can see your wireless card is standard 802.11ac.
Does your router support 802.11ac?
3) There are several Wireless LAN adapter Local Area Connection* on your computer. You should do some cleaning.
Again, have you tried to uninstall and reinstall your wireless card driver?
Livix07 not every device will show a physical address when they're not connected. 802.11ac cards always support at least 1 older protocol and these other adapters are virtual adapters often associated with a hyper visor.
