Windows 7 Network mapped drive to Windows 7 system dropping connection
jwright8
I have two Windows 7 Ultimate computers and around
10 Windows XP (Home and Professional, SP2 and SP3) computers trying to connect
to it. It's just a LAN (no internet access).
I have set all of the
password-protected sharing off on the Win 7 systems. I have tried opening up ALL
of the permissions and such (since security is not really an issue).
The
problem I'm having is this:
When I try to map the network drive, it won't
let me merely connect to it. So, I have to click map network drive on the XP
computer and hit "login with other credentials" and enter the username/pass for
the user account on the Win 7 machine (we'll say Bob for user and Smith for
password for the sake of example). It will mount the share (which is actually
the C:\ root of the drive) just fine.
The only problem is the moment you
restart the Windows XP system, it will lose the connection. My fix for it was to
create a .bat file that contained the following:
net use S: /delete
net use S: [URL="file://server1win7/server1win7"]  \\Server1Win7\server1win7[/URL] Smith /USER:\Bob /PERSISTENT:YES
net use T: /delete
net use T: [URL="file://server2win7/server2win7"]  \\Server2Win7\server2win7[/URL] Smith /USER:\Bob /PERSISTENT:YES
I put it in the Progam Files\Startup folder to run upon boot. For the most part,
it seems to work after a fashion. Some of the computers, though, will drop the
connection to the two Windows 7 systems and need to be rebooted 1-2 times before
they get it back again. Even clicking the .bat file manually will have the same
result (you will have to reboot) if it drops the connection while you're using
it. Plus, sometimes it doesn't map the drive correctly (I assume because the
batch file is running before the connection has a chance to initialize on the
LAN).
Any help would be much appreciated, as I am completely at a loss
here. Any solution that would allow me to map the network share for both of them
and it remain persistent would be wonderful.
PS - I've also tried adding
an "Everybody" user to the permissions on the Win 7 systems with full access,
but it only seemed to cause problems with the existing connections.
It might also be prudent to mention that both the Windows 7 and Windows XP
systems are all 32 bit. I've also disabled the firewalls on the two Windows 7
systems. Neither of them have any antivirus or security software installed.
Hello and welcome to the forum.
It would seem that this problem may have a work around by making the following two registry edits on the Windows 7 machines.
Take a look here Link Removed - Invalid URL and see if that helps with your issue.
Regards
Randy
Okay, it seems like that fixed my problem. I will post back on this topic if for some reason it doesn't, but I believe that should be it. Thank you very much for the help; I would have never figured that out!
Good to hear that you have managed to resolve your problem.
You're welcome and thank you for posting back and updating your thread with the solution that seems to have worked for you.
Yes, please keep us posted, I would be very interested in hearing if that is in fact a long term solution for you.
Regards
Randy
Okay, just checking back in while I'm thinking about this. The solution still is working wonderfully on my end, so I'd advise anyone with a similar problem to do the same. About 15-20 computers, all shutting down and booting back up at different times (including the two servers) and the drive letters seem to be preserved fine. Thanks again for your help!
Top Bottom
