Valinor
I'm having issues with connecting to my universities network.
When installing the network theres a point in the install that i need to uncheck the "validate server certificate" box. In Vista the install went fine but having issues in Windows 7.
In Vista when setting up the network i also uncheck that "validate server certificate" and then when I connect to the network a popup pops up that asks for "Additional Login Info". Then I use my universities username and password to connect.
In Windows 7 I dont get that popup. The popup only shows up when I check the "validate server certificate" but then I still cant connect. Unchecking that box just wont give me any "additional login info" popup.
Anyone have an idea how I still can connect to the network?
Thx
certificate validation
Something that worked for me on my university system.
Go to "Properties" -> Security -> Settings
Click on the appropriate Trust Root Certification Authority (mine was one of the THAWTE authorities)
Click OK
Click on network icon again and try to login.
Click OK
