Network Problem - Identifying then No Connections ???
SeFu
This problem started in Vista, I tried installing Windows 7 RC in hopes of a quick fix but with no luck.
=== Problem ===
After starting the computer it connects to the network fine and pulls a good IP. The connection will stay for a few minutes then just drop.
It will hang on "Identifying" for a bit and then simply lose all networks.
Wireless card will report "No Connections" and the net card reports to check the connection.
If I Disable/Enable the card it will fix the problem for a few minutes.
I have tried the registry edit that I found on the net for DhcpConnEnableBcastFlag but it has not worked. I am out of ideas...
Any help is appreciated, as of this moment the laptop is USELESS in terms of internet use...
:confused: :confused: :confused:
