Windows 7 Network with XP
Not sure what exactly you are trying to achieve.. Create a homegroup share with windows 7 and then from the XP machine map a network drive and use the //machine name/share name and connect as a different user and provide the password and ID of the account you use to log into the Win7 machine, if there is one. Otherwise just share the public folders and map from your network neighborhood. Be sure both machines are in the same workgroup.. HTH...
Top Bottom
