Mass93
Hey guys so i just installed W7 and i got a problem.. I have no sound at all. Im runnning intel pentium e2140 and asus p5gc-mx/1333 with on board sound, no sound card. when i click on the digital audio (s/dif) in the corner it shows that my speakers are not plugged in when they clearly are... i installed realtek hd audio but the same problem... any suggestions?
Thanks, MAss93
Hey MAss93, It seems like you're experiencing sound issues after installing Windows 7 on your system. Here are some steps you can try to troubleshoot and potentially fix the problem: 1. Check Physical Connections: - Ensure that your speakers are properly connected to the audio port on your motherboard. - Check if the speakers are powered on. 2. Update Drivers: - Make sure you have the latest drivers installed for your onboard sound device. - Visit the ASUS support website for your motherboard model (P5GC-MX/1333) and download the latest audio drivers specifically designed for Windows 7. 3. Verify Device Manager: - Right-click on the "Computer" icon on your desktop and select "Manage." - Go to "Device Manager" and check...
Hey MAss93, It seems like you're experiencing sound issues after installing Windows 7 on your system. Here are some steps you can try to troubleshoot and potentially fix the problem: 1. Check Physical Connections: - Ensure that your speakers are properly connected to the audio port on your motherboard. - Check if the speakers are powered on. 2. Update Drivers: - Make sure you have the latest drivers installed for your onboard sound device. - Visit the ASUS support website for your motherboard model (P5GC-MX/1333) and download the latest audio drivers specifically designed for Windows 7. 3. Verify Device Manager: - Right-click on the "Computer" icon on your desktop and select "Manage." - Go to "Device Manager" and check if there are any yellow exclamation marks next to your audio device. If so, it indicates a driver issue. 4. Enable Audio Device: - Go to the "Sound" settings in the Control Panel. - Check if the onboard audio device is enabled and set as the default playback device. 5. Test Sound Output: - Try plugging the speakers into a different device to ensure they are functioning correctly. - Test your onboard audio output by connecting headphones or another set of speakers to the audio port. 6. BIOS Settings: - Enter the BIOS setup during system startup and verify that the onboard audio is enabled. 7. Reinstall Realtek HD Audio Driver: - Uninstall the current Realtek HD Audio driver completely from the "Programs and Features" section in the Control Panel. - Reboot your system and then reinstall the latest version of the Realtek HD Audio driver. 8. Windows Troubleshooter: - Use the built-in Windows Troubleshooter to diagnose and potentially fix common audio issues. 9. Check for Windows Updates: - Ensure that your Windows 7 system is up to date with the latest patches and updates. By following these steps, you may be able to identify the root cause of the sound issue on your Windows 7 system and resolve it. Let me know if you need further assistance!
