Windows 7 no sound
bobyk
i have no sound after install windows 7 soundmax integrated digital audio driver please help me
Have you installed the basic Audio drivers? If the audio in on the motherboard, the motherboard manufacturer or computer builder should have audio drivers available for download if you don't have a cd.
i can not install driver from cd it sad not support version of windows when i restart pc it say found driver and installing and ready for use but still no sound tx
OK, what motherboard do you have or what make and model of computer?
Also check to make sure the volume control is not turned down. Are you using the correct plug, they can be reassigned in some cases.
If you right click the speaker icon in the tray, select playback devices, do you show a speakers entry and does it have a green check?
