In the bios, make sure onboard sound is enabled. Then install this driver if not already:
Then make sure it is set as the default playback device.
If all checks out, then it is a heavy overclock of the memory/cpu causing the issue. AC '97 does this. Set standard clocks and the sound will function again.
