ntdll.dll + Faulting application error [.exe error]
zj3m555
Windows 10 pro
Amd Ryzen 5 3600
Rtx 3070 ti
32 gb ram [4x8]
Application error while playing terraria. I have looked for help in the terraria forums, but they seem to come to the same general conclusion that it is a windows error not a terraria error. The crash only happens with terraria, no other game causes the crash. It happens randomly regardless of what is happening within the game. The utilization of the pc is not a factor because it can happen at high levels during boss fights or events, or low levels of utilization like idling or even tabbing out. I am able to play unspecified amounts of time before the crash happens. Sometimes 2 hours before anything, other times 10 mins and it crashes.
Windows is up to date, graphics drivers are up to date, game is up to date and has been deleted and reinstalled. The game is running through steam. I have ran sfc /scannow multiple times.
Event viewer errors below:
Application error:
Faulting application name: Terraria.exe, version: 1.4.4.9, time stamp: 0x6377237b
Faulting module name: ntdll.dll, version: 10.0.19041.3086, time stamp: 0xfab6a536
Exception code: 0xc0000005
Fault offset: 0x000445c4
Faulting process id: 0x5824
Faulting application start time: 0x01d9a1533b79fae7
Faulting application path: G:\Games\Steam\steamapps\common\Terraria\Terraria.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: aa32b6ba-91fd-4f7e-8514-a743ed457297
Faulting package full name:
Faulting package-relative application ID:
.Net Runtime error:
Application: Terraria.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at <Module>.delete(Void*)
at Microsoft.Xna.Framework.Audio.UnsafeNativeMethods+Cue.ReleaseHandle(UInt32)
at Microsoft.Xna.Framework.Audio.Cue.Dispose(Boolean)
at Microsoft.Xna.Framework.Audio.Cue.Finalize()
Based on the information provided, it seems like the cause of the application error while playing Terraria is related to a faulty or corrupted ntdll.dll module. This module is an essential system file that is responsible for various system functions, and if it is damaged, it can cause issues in different applications.
Here are a few troubleshooting steps that you can try to resolve the issue:
  • Update or reinstall the drivers: Make sure that your drivers, especially the sound and graphics drivers, are up-to-date. You can check for the latest updates on the manufacturer's website and install them accordingly.
  • Repair or reinstall the game: Try to repair the game from the Steam client. Go to your Steam library, right-click on...
  • Repair or reinstall the game: Try to repair the game from the Steam client. Go to your Steam library, right-click on Terraria, choose Properties, go to Local Files, and click Verify Integrity of Game Files. If that doesn't work, you can try uninstalling and reinstalling the game.
  • Scan for malware: Malware or viruses can cause various system issues, including application errors. Run a full system scan using your preferred antivirus software.
  • Check for corrupt system files: Use the Command Prompt to check for corrupt or damaged system files and repair them if needed. Open the Command Prompt as an administrator and type in "sfc /scannow" and press Enter. Wait until the scan is complete, and restart your computer.
  • Perform a clean boot: A clean boot will help you disable all the third-party applications and services that may be causing the issue. Follow the instructions in this Microsoft article to perform a clean boot.
  • Try running the game in compatibility mode: Right-click on Terraria.exe, choose Properties, and go to the Compatibility tab. Check the "Run this program in compatibility mode for" box and choose a previous version of Windows.
  • Reinstall Windows: If none of the above solutions work, you can try to reinstall Windows as a last resort. This will erase everything on your system drive, so make sure to back up your important files before proceeding.
    Hopefully, one of these solutions will fix the application error you are experiencing while playing Terraria. Good luck!
