Loading Dump File [F:\a\Minidump\D M P\DMP\123110-15865-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e19000 PsLoadedModuleList = 0xfffff800`03056e50
Debug session time: Fri Dec 31 08:37:42.235 2010 (UTC - 5:00)
System Uptime: 0 days 0:18:13.281
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck D1, {ffffffffffffff89, 2, 1, fffff880059962c7}
Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+37d2c7 )
Followup: MachineOwner
6: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
interrupt request level (IRQL) that is too high. This is usually
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: ffffffffffffff89, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff880059962c7, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800030c10e0
ffffffffffffff89
CURRENT_IRQL: 2
FAULTING_IP:
nvlddmkm+37d2c7
fffff880`059962c7 c3 ret
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xD1
PROCESS_NAME: plugin-contain
TRAP_FRAME: fffff88003126b60 -- (.trap 0xfffff88003126b60)
rax=0000000000000000 rbx=0000000000000000 rcx=fffffa8006540000
rdx=fffffa80036f92b0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff880059962c7 rsp=fffff88003126cf8 rbp=0000000000000000
r8=0000000000000000 r9=0000000000000004 r10=0000000000000001
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei ng nz na po nc
nvlddmkm+0x37d2c7:
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002e88ca9 to fffff80002e89740
STACK_TEXT:
fffff880`03126a18 fffff800`02e88ca9 : 00000000`0000000a ffffffff`ffffff89 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`03126a20 fffff800`02e87920 : 00000000`00000000 fffffa80`06540000 fffffa80`07212d90 fffff880`0480a7da : nt!KiBugCheckDispatch+0x69
fffff880`03126b60 fffff880`059962c7 : fffff880`057bd0ac fffffa80`06540000 00000000`00000000 00000000`00000002 : nt!KiPageFault+0x260
fffff880`03126cf8 fffff880`057bd0ac : fffffa80`06540000 00000000`00000000 00000000`00000002 00000000`00000002 : nvlddmkm+0x37d2c7
fffff880`03126d00 fffffa80`06540000 : 00000000`00000000 00000000`00000002 00000000`00000002 00000001`00000001 : nvlddmkm+0x1a40ac
fffff880`03126d08 00000000`00000000 : 00000000`00000002 00000000`00000002 00000001`00000001 fffffa80`03a40660 : 0xfffffa80`06540000
STACK_COMMAND: kb
FOLLOWUP_IP:
nvlddmkm+37d2c7
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nvlddmkm+37d2c7
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4cb9dd0e
FAILURE_BUCKET_ID: X64_0xD1_nvlddmkm+37d2c7
6: kd> !analyze -v
Arguments:
Debugging Details:
WRITE_ADDRESS: ffffffffffffff89
CURRENT_IRQL: 2
FAULTING_IP:
nvlddmkm+37d2c7
BUGCHECK_STR: 0xD1
nvlddmkm+0x37d2c7:
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
nvlddmkm+37d2c7
