[font=lucida console]**************************Thu Nov 1 09:00:44.092 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110112-17284-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:02:24.700[/B]
BugCheck Code: [B]BugCheck 1A, {5003, fffff70001080000, d87, d8900001b1e}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+2983f )[/B]
BugCheck Info: [B]MEMORY_MANAGEMENT (1a)[/B]
Arguments:
Arg1: 0000000000005003, The subtype of the bugcheck.
Arg2: fffff70001080000
Arg3: 0000000000000d87
Arg4: 00000d8900001b1e
BUGCHECK_STR: 0x1a_5003
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: [B]dwm.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_5003_nt!_??_::FNODOBFM::_string_+2983f[/B]
CPUID: "Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz"
MaxSpeed: 2400
CurrentSpeed: [B]2405[/B]
BIOS Version 0604
BIOS Release Date 07/16/2008
Manufacturer System manufacturer
Product Name P5E-VM HDMI
**************************Mon Oct 8 15:44:37.211 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100812-16083-01.dmp]
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 1:10:21.649[/B]
BugCheck Code: [B]BugCheck 1A, {5003, fffff70001080000, 5308, c9a0000a600}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+29dcf )[/B]
Arguments:
Arg3: 0000000000005308
Arg4: 00000c9a0000a600
PROCESS_NAME: [B]FlashPlayerPlu[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_5003_nt!_??_::FNODOBFM::_string_+29dcf[/B]
MaxSpeed: 2400
BIOS Version 0604
**************************Sat Sep 22 08:12:48.782 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092212-18595-01.dmp]
System Uptime:[B]0 days 0:02:39.779[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff960001a6079, 0, c0214018}[/B]
Probably caused by :[B]win32k.sys ( win32k!HANDLELOCK::vLockHandle+51 )[/B]
BugCheck Info: [B]KMODE_EXCEPTION_NOT_HANDLED (1e)[/B]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff960001a6079, The address that the exception occurred at
Arg4: 00000000c0214018, Parameter 1 of the exception
BUGCHECK_STR: 0x1E_c0000005_R
PROCESS_NAME: [B]firefox.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_win32k!HANDLELOCK::vLockHandle+51[/B]
MaxSpeed: 2400
BIOS Version 0604
**************************Sun Sep 16 15:41:41.797 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091612-15116-01.dmp]
System Uptime:[B]0 days 0:03:25.794[/B]
BugCheck Code: [B]BugCheck 24, {1904fb, fffff88002183e08, fffff88002183660, fffff880012373cb}[/B]
Probably caused by :[B]Ntfs.sys ( Ntfs!NtfsLookupAllocation+eb )[/B]
BugCheck Info: [B]NTFS_FILE_SYSTEM (24)[/B]
Arguments:
Arg1: 00000000001904fb
Arg2: fffff88002183e08
Arg3: fffff88002183660
Arg4: fffff880012373cb
PROCESS_NAME: [B]csrss.exe[/B]
BUGCHECK_STR: 0x24
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_DEREFERENCE
FAILURE_BUCKET_ID: [B]X64_0x24_Ntfs!NtfsLookupAllocation+eb[/B]
MaxSpeed: 2400
BIOS Version 0604
**************************Wed Sep 12 16:08:07.147 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091212-15709-01.dmp]
System Uptime:[B]0 days 0:02:35.129[/B]
*** WARNING: Unable to verify timestamp for intelppm.sys
*** ERROR: Module load completed but symbols could not be loaded for intelppm.sys
BugCheck Code: [B]BugCheck 1A, {5003, fffff70001080000, 68b, 4be00000d06}[/B]
Probably caused by :[B]intelppm.sys ( intelppm+39c2 )[/B]
Arguments:
Arg3: 000000000000068b
Arg4: 000004be00000d06
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_5003_intelppm+39c2[/B]
**************************Sun Sep 9 17:43:42.974 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090912-16380-01.dmp]
System Uptime:[B]0 days 0:01:06.582[/B]
BugCheck Code: [B]BugCheck 1A, {5003, fffff70001080000, 1f4a, 2e3900003e84}[/B]
Probably caused by :[B]hardware ( nt! ?? ::FNODOBFM::`string'+22274 )[/B]
Arguments:
Arg3: 0000000000001f4a
Arg4: 00002e3900003e84
PROCESS_NAME: [B]AvastSvc.exe[/B]
FAILURE_BUCKET_ID: [B]X64_IP_MISALIGNED[/B]
MaxSpeed: 2400
BIOS Version 0604
**************************Sun Sep 9 17:41:53.369 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090912-16894-01.dmp]
System Uptime:[B]0 days 5:30:34.485[/B]
BugCheck Code: [B]BugCheck A, {18, 2, 1, fffff80002cbb868}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ExpWorkerFactoryCheckCreate+1b0 )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
Arguments:
Arg1: 0000000000000018, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80002cbb868, address which referenced memory
BUGCHECK_STR: 0xA
FAILURE_BUCKET_ID: [B]X64_0xA_nt!ExpWorkerFactoryCheckCreate+1b0[/B]
MaxSpeed: 2400
BIOS Version 0604
**************************Fri Sep 7 12:07:25.238 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090712-22713-01.dmp]
System Uptime:[B]0 days 0:03:05.220[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff8800537f251, 0, 0}[/B]
Probably caused by :[B]hardware ( dxgmms1!VIDMM_GLOBAL::EndPreparation+29 )[/B]
Arguments:
Arg2: fffff8800537f251, The address that the exception occurred at
FAILURE_BUCKET_ID: [B]X64_IP_MISALIGNED_dxgmms1.sys[/B]
MaxSpeed: 2400
BIOS Version 0604
**************************Mon Aug 27 17:53:54.128 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\082712-15974-01.dmp]
System Uptime:[B]0 days 0:10:24.110[/B]
BugCheck Code: [B]BugCheck 50, {fffff88009809150, 0, fffff8800525c01a, 0}[/B]
Probably caused by :[B]dxgkrnl.sys ( dxgkrnl!DXGADAPTER::AcquireDdiSync+12 )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
Arguments:
Arg1: fffff88009809150, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff8800525c01a, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR: 0x50
FAILURE_BUCKET_ID: [B]X64_0x50_dxgkrnl!DXGADAPTER::AcquireDdiSync+12[/B]
MaxSpeed: 2400
BIOS Version 0604
[/font]
