NVIDIA quietly pushed a follow-up Game Ready release, GeForce 595.71 WHQL, on March 2, 2026 — a targeted hotfix meant to repair a string of fan- and sensor-related regressions that forced the company to pull its earlier 595.59 build — but the community response shows the “fix” is uneven and raises fresh questions about release QA and update best practices for GeForce users. (nvidia.com)
When NVIDIA released GeForce Game Ready driver 595.59 in late February 2026 it was intended to deliver performance optimizations and day‑one support for several recent titles. Within hours users began reporting critical hardware-control symptoms on RTX 50‑series cards: missing fan sensors in monitoring tools, ignored fan curves, fans failing to spin after an update, and in some cases reduced boost clocks and voltage capping. Those reports escalated rapidly across community forums and hardware news sites, prompting NVIDIA to remove the 595.59 downloads and recommend rolling back to the prior stable release while the engineering team investigated.
The withdrawal was abrupt and public: NVIDIA issued an update saying it had "discovered a bug in the Game Ready and Studio 595.59 WHQL drivers and removed the downloads temporarily" and advised affected users to roll back to version 591.86. The ecosystem reaction was immediate and vocal — affected users documented hardware monitoring anomalies and reported game stability problems tied to the pulled release.
In response, NVIDIA issued GeForce 595.71 WHQL on March 2, 2026 as a follow-up update that the company says addresses the most visible fan-monitoring and fan-stopping regressions introduced by 595.59. The release notes posted to NVIDIA’s driver/discussion infrastructure and the vendor’s forum thread list fixes specifically aimed at restoring accurate fan reporting and preventing fans from failing to spin after updates. Community-copied release-note fragments (and the forum thread that hosts them) are the primary public confirmation available at time of writing. (nvidia.com)
From a journalist’s vantage point: while AI tooling may accelerate development, it does not absolve human QA and end‑to‑end compatibility testing. NVIDIA’s public rollback and fast follow-up with 595.71 is the correct operational response — but the persistence of edge-case reports after the follow-up indicates that testing matrices or post‑commit monitoring could be improved. Transparency around test coverage, telemetry signals, and the scope of WHQL checks would help restore user trust, especially in highly visible regressions that affect hardware safety (fan control).
If you run a production PC or a heavily tweaked gaming rig, the safest posture remains conservative: document your known‑good driver baseline, hold off on day‑one updates for at least a short pilot window, and be prepared to roll back cleanly if you see abnormal sensor or fan behavior. NVIDIA’s quick rollback and targeted hotfix were the right operational choices; now the company’s engineering signals and transparency will determine whether confidence returns to pre‑incident levels.
Driver releases are increasingly complex, and the 595.59 → 595.71 sequence is a reminder that even mature vendors can ship regressions when the testing matrix is overwhelmed by new features, new hardware SKUs, and third‑party integration points. 595.71 is an important stopgap that solves the most visible safety and monitoring issues for many users, but it is not a blanket cure for every configuration. Treat the update as a cautious step forward: verify on a test machine, collect logs if you see trouble, and don’t hesitate to revert to a proven driver until the vendor’s signals — and the community’s corroboration — show the build is stable across the ecosystem. (nvidia.com)
Source: TechPowerUp NVIDIA Releases GeForce 595.71 WHQL Game Ready Drivers
Background
When NVIDIA released GeForce Game Ready driver 595.59 in late February 2026 it was intended to deliver performance optimizations and day‑one support for several recent titles. Within hours users began reporting critical hardware-control symptoms on RTX 50‑series cards: missing fan sensors in monitoring tools, ignored fan curves, fans failing to spin after an update, and in some cases reduced boost clocks and voltage capping. Those reports escalated rapidly across community forums and hardware news sites, prompting NVIDIA to remove the 595.59 downloads and recommend rolling back to the prior stable release while the engineering team investigated.The withdrawal was abrupt and public: NVIDIA issued an update saying it had "discovered a bug in the Game Ready and Studio 595.59 WHQL drivers and removed the downloads temporarily" and advised affected users to roll back to version 591.86. The ecosystem reaction was immediate and vocal — affected users documented hardware monitoring anomalies and reported game stability problems tied to the pulled release.
What 595.71 Claims to Fix — The Verifiable Changes
NVIDIA’s follow-up build lists discrete fixes that map directly to the most salient user complaints from the 595.59 incident. The elements highlighted in the public feedback thread and mirrored across community reporting include:- HW monitoring compatibility: repairs for utilities not detecting all fans on the GPU (bug tracking references appearing in the release material).
- Fans not spinning after driver updates: a specific fix for one-or-more fans failing to start following a driver install.
Community Reaction: Short-Term Relief, Long-Term Skepticism
Early reaction to 595.71 has been mixed. Some users report the driver restored fan monitoring in HWiNFO, GPU‑Z, and OEM utilities, while others continue to see anomalies — notably:- LFC (Low‑Frame Compensation / variable-refresh heuristics) misfires that engage at higher frame rates than expected, causing refresh‑rate doubling at steady 60 FPS on some monitors.
- Persistent signs of voltage capping and tamped boost behavior on select RTX 50 and high‑end RTX 40 cards.
- Continued game-specific performance and stability outliers for titles that previously reported regressions (some players still rolling back to older drivers for best results).
Why This Happened: A Technical and Organizational Reading
There are several plausible, non‑conspiratorial explanations for how a widely disruptive regression like the 595.59 fan/sensor problem made it into a WHQL‑certified build, and why a rapid follow-up build like 595.71 was required quickly after:- The modern GPU driver is no longer just a display driver; it exposes multiple OS, firmware, and user‑space interfaces — from sensor APIs and fan control to telemetry, DLSS/upscaling hooks, and kernel‑mode power management. Even a small change to a monitoring or thermal-control layer can ripple across tools and vendor utilities.
- The release cadence for Game Ready builds has accelerated in recent years to chase day‑one game support and feature parity (DLSS, ray tracing improvements, new GPU SKUs), which compresses testing windows and increases the chance a regression gets out the door. Veteran users and industry watchers have observed this cadence squeeze before.
- WHQL certification verifies certain Windows driver model standards at a Microsoft level, but it does not guarantee interoperability with every third‑party monitoring tool, OEM BIOS variation, or third‑party kernel extension; this gap can lead to regressions that are discovered only post‑release by the installed base.
What To Do Right Now: Practical Guidance for Windows Users
If you rely on a GeForce card for gaming, content creation, or professional work, follow these prioritized steps. This is a concise, pragmatic checklist that balances safety and recovery speed.- Check your current driver version: open the NVIDIA Control Panel or the GeForce app and confirm the driver version string (e.g., 595.71, 591.86). If you updated to 595.59 and are experiencing fan/sensor or stability issues, do not ignore them — act now.
- If you installed 595.59 and have issues, roll back immediately to the last known good driver (NVIDIA advised rollback to 591.86 when 595.59 was delisted). For most users, the GeForce app rollback via the Drivers tab (three‑dot menu) is the smoothest path.
- If the GeForce app cannot restore stability, perform a clean uninstall and reinstall using DDU (Display Driver Uninstaller) in Windows Safe Mode, then install the driver version you want (many enthusiasts prefer to wait 48–72 hours after a hotfix release to let community reports settle).
- If you’re on 595.71 and see continuing anomalies, document your observations (exact GPU SKU, OS build, BIOS version, OEM utility versions, and monitoring logs), then either:
- Roll back to the last stable driver that worked for you, OR
- File a detailed bug report to NVIDIA’s Driver Feedback Forum (attach logs and steps to reproduce). (nvidia.com)
- Disable automatic driver updates in the GeForce app until you’ve confirmed the update’s stability for your card and use case.
- Keep GPU firmware (VBIOS) and motherboard BIOS up to date, because mismatches sometimes aggravate driver-level fan management issues.
- For enterprise or content‑creation systems, defer driver updates for at least one week after release and pilot the update on a test bench before rolling company‑wide. This is inexpensive insurance against regressions.
Step‑by‑Step: How to Roll Back Using the NVIDIA App (short)
- Open the GeForce app.
- Click the Drivers tab.
- Select the three‑dot menu next to the installed driver entry.
- Choose "Reinstall previous driver" or select the desired version from the list.
- Reboot and verify fan monitoring in HWiNFO/GPU‑Z and that your OEM fan curve/tool shows expected behavior.
Broader Implications: QA, Release Cadence, and the “AI Coding” Chatter
Community threads have also seeded a second narrative: that driver engineering has changed — faster release cycles, heavier automation, and greater reliance on tools that may obscure regression paths. Some posters attribute recent string of driver missteps to over‑reliance on automated testing or to emergent issues introduced by ML/AI in code generation and testing pipelines. Those claims are largely speculative in public forums, but they reflect a trust problem: users expect core hardware control layers to be rock‑solid, and rapid, visible regressions erode confidence.From a journalist’s vantage point: while AI tooling may accelerate development, it does not absolve human QA and end‑to‑end compatibility testing. NVIDIA’s public rollback and fast follow-up with 595.71 is the correct operational response — but the persistence of edge-case reports after the follow-up indicates that testing matrices or post‑commit monitoring could be improved. Transparency around test coverage, telemetry signals, and the scope of WHQL checks would help restore user trust, especially in highly visible regressions that affect hardware safety (fan control).
Technical Notes and What We Could Verify
- The core timeline — 595.59’s withdrawal and the subsequent 595.71 follow-up — is corroborated across multiple independent outlets and forum logs. VideoCardz and PCWorld documented NVIDIA’s removal of the 595.59 package and the rollback guidance; community threads and NVIDIA’s own forum thread recorded the 595.71 follow-up and the specific fan/sensor fixes. These are the load‑bearing facts for the story.
- The precise low‑level cause (a single malformed API change vs. a regression in the thermal control daemon vs. a partner firmware sensitivity) is not publicly confirmed in a vendor engineering post‑mortem. NVIDIA’s public messaging has focused on mitigation and fixes rather than root‑cause disclosure. When vendors are under pressure to restore stability, the initial communications often prioritize remediation. That means some technical assertions circulating in social media are plausible but not independently verifiable without official post‑mortem details from NVIDIA.
- Bug tracking references quoted in forum snippets (e.g., internal ticket IDs shown in release-note excerpts) are useful for correlating individual reports to fixes, but they do not, by themselves, disclose the underlying code change. We flag any claim that asserts a certitude about root cause as unverified unless NVIDIA publishes internal details or a formal post‑mortem.
Risk Analysis: Why Driver Hygiene Matters
Device drivers are privileged software components that can materially affect hardware behavior. The 595.59/595.71 episode highlights several risks to manage:- Thermal and mechanical risk: fan and fan‑control regressions can increase component temperatures and accelerate wear, particularly in systems where fans do not spin at all after an update. This elevates the severity of what might otherwise be dismissed as a “mere” monitoring bug.
- Operational risk for creators and pros: content‑production pipelines often depend on predictable performance and thermal stability. Unplanned regressions can derail render farms, live‑stream setups, and time‑sensitive workloads.
- Security and stability: drivers run at high privilege. Rapidly staged updates without sufficient ecosystem testing create an environment where regressions and unintended interactions are more likely.
- Reputational risk for vendors: frequent rollbacks and hotfixes erode trust. For high‑commitment purchases (high‑end GPUs), persistent instability is a reputational liability for the vendor.
What to Watch Next
- NVIDIA forum and driver feedback posts over the next 48–72 hours for converging community signals: whether 595.71 progressively alleviates reported issues across a broad set of partner cards. (nvidia.com)
- Any NVIDIA-issued hotfixes or a point release (e.g., 595.72) that specifically addresses residual LFC / voltage-cap symptoms called out by users. Community reporting tends to coalesce quickly, and vendors sometimes issue micro‑patches in the week after a hotfix if telemetry shows persistence.
- Official NV engineering commentary or a more detailed release note explaining root cause and test updates; that transparency is the best signal that the vendor is closing process gaps.
Bottom Line
GeForce 595.71 WHQL is NVIDIA’s rapid, narrowly scoped response to a visible and high‑impact regression introduced by the earlier 595.59 driver. For many users it restores critical fan‑monitoring compatibility and prevents fans from remaining stalled after an update — which was the immediate, most dangerous symptom. However, the follow‑up has not been a universal cure: several users still report behavior that warrants caution, and there are lingering questions about test coverage, release cadence, and how changes to privileged hardware control layers are validated before WHQL builds are distributed.If you run a production PC or a heavily tweaked gaming rig, the safest posture remains conservative: document your known‑good driver baseline, hold off on day‑one updates for at least a short pilot window, and be prepared to roll back cleanly if you see abnormal sensor or fan behavior. NVIDIA’s quick rollback and targeted hotfix were the right operational choices; now the company’s engineering signals and transparency will determine whether confidence returns to pre‑incident levels.
