Windows Vista Obtain installation and upgrade privilege
greborior
How I can obtain "trustedinstaller" autorization programmatically valid for update too?
Hi! I'm not sure I know what you're talking about, but a lot of people try to shut it down. (trustedInstaller) The process uses 85-95 percent of your CPU... If you want to get rid of it you may lose some updates and or have problems with the UAC Link Removed - Invalid URL (I mis understood them, it is connected in some way to Windows Update)
trustedinstaller
When I install my program first time the folder list ever the trustedinstaller. My idea must be to use this user name for upgrade my program but I don't how?
Top Bottom
