- Thread Author
- #1
Hey there,
I have tried all the solutions that I could find at opening ports for a mud server i am trying to run, I have correctly forwarded my port on my router, Allowed the incoming/outbound connections on the firewall on both host computer and my laptop. I managed to only open the ports using a program called port forwarding wizard which I thought yes my problem solved but this opens it but then i cant use the port as it is currently using it
Is there any other solutions?
Thanks
Thanks
