[FONT=lucida console]**************************Fri Nov 2 20:38:53.069 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110212-36660-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 3:06:51.130[/B]
BugCheck Code: [B]BugCheck D1, {fffff80043a8da32, 2, 8, fffff80043a8da32}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiPageFault+260 )[/B]
BugCheck Info: [B]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/B]
Arguments:
Arg1: fffff80043a8da32, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: fffff80043a8da32, address which referenced memory
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xD1_CODE_AV_BAD_IP_nt!KiPageFault+260[/B]
CPUID: "Intel(R) Core(TM) i7 CPU 940 @ 2.93GHz"
MaxSpeed: 2930
CurrentSpeed: [B]2937[/B]
BIOS Version 2101
BIOS Release Date 09/19/2011
Manufacturer System manufacturer
Product Name System Product Name
**************************Fri Nov 2 17:30:00.202 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110212-39421-01.dmp]
System Uptime:[B]0 days 18:36:44.264[/B]
BugCheck Code: [B]BugCheck 50, {fffff8a041424940, 0, fffff880057b241d, 5}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_DEVICE::RemoveCommitment+2d )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
Arguments:
Arg1: fffff8a041424940, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff880057b241d, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000005, (reserved)
BUGCHECK_STR: 0x50
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_dxgmms1!VIDMM_DEVICE::RemoveCommitment+2d[/B]
MaxSpeed: 2930
BIOS Version 2101
**************************Thu Nov 1 22:51:18.616 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110112-39093-01.dmp]
System Uptime:[B]2 days 18:07:11.678[/B]
BugCheck Code: [B]BugCheck 50, {fffffa8050d36310, 0, fffff80003c09dd3, 5}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+264 )[/B]
Arguments:
Arg1: fffffa8050d36310, memory referenced.
Arg3: fffff80003c09dd3, If non-zero, the instruction address which referenced the bad memory
address.
BUGCHECK_STR: 0x50
PROCESS_NAME: [B]Wow.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_dxgmms1!VIDMM_GLOBAL::CloseOneAllocation+264[/B]
MaxSpeed: 2930
BIOS Version 2101
**************************Fri Oct 26 03:29:51.010 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102612-36379-01.dmp]
System Uptime:[B]0 days 2:31:03.071[/B]
BugCheck Code: [B]BugCheck 116, {fffffa80128cd4e0, fffff88004207008, 0, 2}[/B]
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by :[B]atikmpag.sys ( atikmpag+7008 )[/B]
BugCheck Info: [B]VIDEO_TDR_FAILURE (116)[/B]
Arguments:
Arg1: fffffa80128cd4e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88004207008, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
BUGCHECK_STR: 0x116
PROCESS_NAME: [B]csrss.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x116_IMAGE_atikmpag.sys[/B]
MaxSpeed: 2930
BIOS Version 2101
**************************Thu Oct 25 05:11:45.427 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102512-39827-01.dmp]
System Uptime:[B]0 days 8:37:39.378[/B]
BugCheck Code: [B]BugCheck 116, {fffffa800d9cf0f0, fffff88003f0e26c, 0, 2}[/B]
Probably caused by :[B]atikmpag.sys ( atikmpag+926c )[/B]
Arguments:
Arg1: fffffa800d9cf0f0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88003f0e26c, The pointer into responsible device driver module (e.g. owner tag).
BUGCHECK_STR: 0x116
MaxSpeed: 2930
BIOS Version 2101
**************************Wed Oct 24 20:32:25.306 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102412-39671-01.dmp]
System Uptime:[B]0 days 5:03:54.367[/B]
BugCheck Code: [B]BugCheck 116, {fffffa80106ea010, fffff8800420926c, 0, 2}[/B]
Arguments:
Arg1: fffffa80106ea010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8800420926c, The pointer into responsible device driver module (e.g. owner tag).
BUGCHECK_STR: 0x116
MaxSpeed: 2930
BIOS Version 2101
**************************Sun Oct 14 22:17:58.531 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-31200-01.dmp]
System Uptime:[B]0 days 5:09:31.451[/B]
BugCheck Code: [B]BugCheck 50, {fffff8a058280200, 1, fffff880061a9983, 5}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VidMmDestroyAllocation+43 )[/B]
Arguments:
Arg1: fffff8a058280200, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff880061a9983, If non-zero, the instruction address which referenced the bad memory
address.
BUGCHECK_STR: 0x50
FAILURE_BUCKET_ID: [B]X64_0x50_dxgmms1!VidMmDestroyAllocation+43[/B]
MaxSpeed: 2930
BIOS Version 2101
**************************Sun Oct 14 16:48:24.603 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-44397-01.dmp]
System Uptime:[B]0 days 0:10:18.634[/B]
BugCheck Code: [B]BugCheck 1E, {0, 0, 0, 0}[/B]
*** WARNING: Unable to verify timestamp for Lachesis.sys
*** ERROR: Module load completed but symbols could not be loaded for Lachesis.sys
Probably caused by :[B]Lachesis.sys ( Lachesis+1081 )[/B]
BugCheck Info: [B]KMODE_EXCEPTION_NOT_HANDLED (1e)[/B]
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
BUGCHECK_STR: 0x1E
FAILURE_BUCKET_ID: [B]X64_0x1E_Lachesis+1081[/B]
MaxSpeed: 2930
BIOS Version 2101
**************************Sun Oct 14 16:18:54.970 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101412-40107-01.dmp]
System Uptime:[B]0 days 16:55:41.000[/B]
BugCheck Code: [B]BugCheck D1, {fffff80043a93e7a, 2, 8, fffff80043a93e7a}[/B]
Arguments:
Arg1: fffff80043a93e7a, memory referenced
Arg4: fffff80043a93e7a, address which referenced memory
BUGCHECK_STR: 0xD1
MaxSpeed: 2930
BIOS Version 2101
**************************Sat Oct 13 23:21:17.240 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101312-47970-01.dmp]
System Uptime:[B]2 days 3:05:52.270[/B]
BugCheck Code: [B]BugCheck D1, {fffff80043ac7a32, 2, 8, fffff80043ac7a32}[/B]
Arguments:
Arg1: fffff80043ac7a32, memory referenced
Arg4: fffff80043ac7a32, address which referenced memory
BUGCHECK_STR: 0xD1
PROCESS_NAME: [B]virtualdj_pro.[/B]
MaxSpeed: 2930
BIOS Version 2101
[/FONT]
