Password - How to not use?
John Stock
Hi, Just started with W7. Need to enter password each time log on. I'm the only user. How to stop the need to provide password each time...just wish W7 to start?
Thanks. John
Super Sarge
Simple go to Control panel then select User Accounts you should see something that says Make changes to your password then below it it should say remove your password. Then follow the instructions
