Problem affecting my 2 laptops
Both of my pcs would start up normally but on another day they does not start up normally, it will show windows is starting then the screen goes black and windows doesn't load. Sometimes instead of the above occurring, after turning on or restarting both my pcs the launch startup repair and start normally page would show up. This seems to occur after I downloaded any software or used windows update.
For my Acer Aspire 5551-2384 laptop, after experiencing the problem for a while I then looked for solution to the problem and I came across bootrec/?,I used it and it fixed the startup problem and it worked. But a yesterday the startup problem returned. Again I tried bootrec and I input bootrec/scanos and it said no windows is installed.
For my HP Pavilion dv5000/dv5178us it was not booting up in windows either and I used bootrec/fixboot and /fixmbr but they did not fix it so I input bootrec/scanos to check if windows was installed and it said no windows was installed. After I proceeded to find software to fix the startup problem but none were able to fix it. I then reinstall windows 7 Home Premium to see if this will fix the problem but the startup problem came back after I update the pc using windows update. I decided to wipe the hard drive so I did, reinstalled windows 7 then upgraded some outdated software and downloaded conexant high definition audio to reinstall my audio. After I restarted my pc the startup problem came back so I re-wipe the hard drive again and reinstall windows7, downloaded the windows update along with google chrome and zone alarm anti-virus + firewall then when the windows update was finished I restarted the pc and again the startup problem is still there. What should I do to correct the startup problem.
N.B. Both pc running windows 7 Home Premium
